-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   6061 T6 Aluminum Wheel Adapters 5x4.5 to 5x5 (Allows JK Wheels on YJ, TJ, XJ) (http://www.jeepforum.com/forum/f43/6061-t6-aluminum-wheel-adapters-5x4-5-5x5-allows-jk-wheels-yj-tj-xj-1304803/)
Baseline 4x4 12-22-2011 09:38 PM
http://www.baseline4x4.com/images/ma...uggedridge.jpg
These hub centric spacers / adapters move your wheels out to help fit wider tires and give your vehicle a wider track and improve stability. Constructed of double anodized black extra thick 6061T6 aluminum for long life and extra corrosion resistance. All hardware is grade-8 for extra strength. Each part number comes as a spacer pair. Included are 10 pre-installed grade-8 wheel studs and 10 lug nuts.
http://www.baseline4x4.com/images/pr...n/15201.11.jpg
15201.11 - Wheel Adaptor Pair, Black, 5 On 4.5 To 5 On 5 Bolt Pattern, 1.375 Inch Thick, 1997-2006 TJ Wrangler, 1987-1995 YJ Wrangler, 1987-2001 XJ Cherokee
Baseline 4x4 12-27-2011 07:17 AM
Wheel spacers allow you to adjust your tire width to give the clearance and stance you are looking for.
Baseline 4x4 01-01-2012 08:52 AM
Wheel Spacers from Alloy USA are made of 6061 T6 material for strength
Baseline 4x4 01-04-2012 06:08 PM
Wheel spacers give your Jeep the stance needed for additional clearance for those critical suspension components.
Baseline 4x4 01-05-2012 12:23 PM
Alloy USA Wheel Spaces are made from 6061 T6 aluminum and use grade 8 hardware to provide you with optimum performance
Baseline 4x4 04-05-2012 06:17 AM
Rugged Ridge Wheel Spacers and Adapters available at discount prices.
The time now is 06:06 PM.
