Quantcast 6 cyl high performance mounts YJ, TJ, XJ, MJ - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > 6 cyl high performance mounts YJ, TJ, XJ, MJ
Old 02-14-2006, 11:39 PM   #1
Brown Dog
Vendor
Brown Dog's Avatar
Attachment 14062
http://www.browndogindustries.com
For these applications:
Wrangler YJ : 1987-1995
Comanche MJ : 1986-1992 4WD
Cherokee XJ : 1984-2001 4WD
Wrangler TJ : 1997-2003
Engine : 6-Cyl
Bracket Opening : 3.25"
Engine Position : Stock
Click to enlarge
These motor mounts are stock height and bolt directly on the original base found on Jeep YJ, TJ, XJ & MJ 4x4s, but that's where the similarity to stock mounts ends.
The Brown Dog demands over-engineering, because it can be a long, long walk to civilization out here in the desert. We believe our mounts are the strongest on the market. We use a full two and a half inch plate steel, double welded joints to provide the most strength possible, while retaining some vibration dampening. 20-ton crush tests have never shown a structural failure of any kind.
This mount is the last mount you'll ever need. If the bushings wear out you can buy replacements from us, but the mount will go on and on. The Brown Dog gives you his word.
Depending on your Jeep, you may need to replace your engine mount brackets to upgrade to high performance mounts (see note below). Measure the opening of the bracket where the motor mount is inserted. The ideal opening is 3 1/4 inches. If it is 2 3/4 inches, we are developing a solution for your AMC YJ. Larger openings can be shimmed (follow directions included with mounts). Most Chrysler YJ mounts that are narrow can be slightly ground to fit (instructions included).
Note: If you have a YJ, we STRONGLY recommend replacing your stock engine mount brackets with our high performance brackets. In some YJ's, the stock right bracket commonly fails during extreme use. With the torsional forces involved, don't risk a failure and damage.
The Brown Dog Promise.
Brown Dog products are designed for high performance applications and off highway use. No one can predict the forces a vehicle will encounter in extreme conditions that are beyond the vehicle's original design parameters. We feel that our products will continue to perform as designed when other products would break. We will replace any product that fails due to a defect in assembly (broken weld). We cannot be responsible for forces so extreme that the integrity of plate or tubular steel becomes compromised. But if you manage to do that, we certainly want to see a picture of it.
Hey, we go out and do the same stuff you do, and we try to break it, but we don't hold others responsible for the results of our strange behavior. Have fun, be safe.
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Join our FaceBook group
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% MADE IN AMERICA
OFFROAD-REVIEW of Browndog Superkit
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" BFG Mud Terrains
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Glock Forum
