50" SINGLE ROW PANDEMIC LED Light bar FEATURES 4D Optics YOU HAVEN'T SEEN AWESOME YET - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > 50" SINGLE ROW PANDEMIC LED Light bar FEATURES 4D Optics YOU HAVEN'T SEEN AWESOME YET
Unread 06-29-2015, 07:27 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Check out Pandemic's latest Single Row LED Light Bars. Get that low profile look that other's only wish they could achieve without sacrificing lighting performance. Meant for tight spaces, or if you just like the clean sleek look of single row, then this bar is for you. We stepped it up from our standard 5 Watt Osram LEDs to the latest high performing 7 Watt Phillips LEDs. Light up your future in style, and get to your destination with confidence.
4D PMMA Optics - MAGNIFIES the light output to give you unmatched distance.
Combo beam pattern - you will see a spot pattern AND a Elliptical pattern. Elliptical pattern will give you your peripheral light as well as keeping it in a tight focus.
Housing - complete with Stainless Steel Mil-Spec Breather allowing your light bar to breath properly. Adjusting to cold and warm temps. Giving it a stronger and more reliable seal. Constructed with a Stainless Cord Relief.
Mounting brackets - are nice Stainless Steel mounting with hardware. With a new Triangle Design, making it the most stable and adjustable mount yet!
These bars are available in
12"
20"
30"
40"
50"
Here is the 50" LED SINGLE ROW LIGHT BAR
They all come with the new Stainless Steel mounting feet with the new Triangle design.
Single Row even has the Dual Mounting Points, making them completely adjustable.
These bars are raising the bar for Single Row. With their killer design and quality of the housings. Great Light!
These have been our most popular series by far.
Need a quote? Contact Erin@Rockridge4wd.com today!
sales@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
Unread 07-07-2015, 03:17 PM   #2
Rockridge4WD
Vendor
2010 JK Wrangler
We are wanting your INPUT
**Special Promotion**
We want YOU to run PANDEMIC. Yes, Pandemic IMPORTS LED Lighting, but who doesn't these days? Just because something is made in China doesn't mean it's poor quality and that you shouldn't buy it. Lets say brand "A" is made in China and brand "B" is also made in China. The difference is brand A is purchasing the lowest end of the "quality spectrum" and brand B might be purchasing the middle quality products. Then there is Pandemic...They purchase from the higher end of the spectrum. The same factory can make the full range and what comes along with that is they vary in price. The LED Bars on Ebay and Amazon are not the same as Rigid, Vision X, Engo or PANDEMIC. They may "share" a few similar "looking" characteristic's like, they all use a Die cast aluminum housing that appears to be the same, but is in fact NOT. The quality is simply not there. The "Binning" of the LED chips themselves are much lower, optics are NOT the same, housings are NOT the same, circuit boards are NOT the same and the wiring is not the same. Something as simple as a plug on the end, costs more money....at the purchasing level. Things that "BRAND A" doesn't care about. You get the point? Maybe not, but we figured we should try and help you all make somewhat of an educated purchasing decision.
We just hate to see you buy a "throw away bar". Why spend $200 on a light that won't last, nor does it even COMPARE to the light output. Why not just buy a smaller, better quality bar that will last and put out just the same amount of light, if not more? That's the solution, if budget is an issue.
Lets talk about warranties. Most will "claim" a 1, 2, 3 year or maybe even lifetime warranty. Wanting to compare, we purchased one of these cheaper bars and guess what? 6 LEDs were burned out when we fired it up, screws were stripped out, silicone globs coming out of the housing and scratches covered up with permanent marker (really?)!!! Ours at the time came with a 1 year warranty. Did they warranty it? NOPE! Why wouldn't you choose an actual company to purchase from? A company that offers a real LIFETIME WARRANTY? One that actually has a website? One that has product actually in stock and in the UNITED STATES and a brand name to stand behind it? Why should you care about the brand? Easy, its someone to hold accountable and write reviews about. This tends to get the attention of the brand and usually will get you somewhere should a problem arise. Plain and simple....ebay or amazon reviews are not going to get the word out if you have an issue.
Put that extra $200 towards a product that can hang with the big dogs! A product you will be proud to run on your Jeep. A product that will set you APART from this flooded industry! You will be DIFFERENT and you WILL LOVE IT! The best part....Pandemic will still not break the bank.
Pandemic is a new and upcoming brand, brought to you by ROCKRIDGE 4WD.
Bringing you our WORLD WIDE known Taillight Conversion Kits for JK's, LED Light Bars from 6"-50" in Double Row, Single Row, Curved. Quad Lights, Rock Lights, even LED HEADLIGHTS in 7" Round and more.
Now, we are doing a special promotion to our customers that are willing to write us an honest review on the light that you install. We are doing a little bit off the top with FREE SHIPPING. Then once you install, write a review and support it with pictures, we will then issue you a credit BACK to your card. Sound good? We think so!
Doesn't have to be a 50" just ANY Pandemic LED light. So email me direct at Erin@Rockridge4wd.com and let me know what light you are after and I can then let you know what rebate you will qualify for, if you do a review.
We would really like to some of the Single Rows out there and seen as they are different then anything else out there. However, we do have other styles to choose from.
Click here to view all PANDEMIC!
Unread 01-08-2016, 05:04 PM   #3
Rockridge4WD
Vendor
2010 JK Wrangler
50" single row bars on sale now!! stand out from the rest with a BAD A LED light bar from PANDEMIC-USA!
The single row bars are very slim and make for a nice low profile off road light that really cranks out the light!! Just over 20,000 lumens and 336w!
Email me for the sale priceEric@Rockridge4wd.com
Unread 01-13-2016, 01:25 PM   #4
Rockridge4WD
Vendor
2010 JK Wrangler
Looking for a bright and affordable light bar with awesome WARRANTY? Contact me direct for a hook Miguel@Rockridge4wd.com
