2011 RIPP Superchargers NOW AVAILABLE! - JeepForum.com
post #1 of 1 Old 11-30-2011, 05:14 PM Thread Starter
REBELOFFROAD
Vendor
REBELOFFROAD's Avatar
2011 Jeep JK owners - time to add some pep to your step!
2011 GEN2 Jeep Wrangler JK Supercharger Kit V3 Si-Trim Stage 2 Intercooler
MSRP: $5,684.95
Rebel: $4,999.95
Save $685.00!
http://www.rebeloffroad.com/RIPP_Sup...lers_s/256.htm
RIPP Superchargers is proud to announce the 2011 Jeep Wrangler Supercharger kit. Producing 230 rear wheel HP and 240ft/lbs of rear wheel torque. Complete systems are fully calibrated, plug and play ready, featuring the self contained V-3 Si-Trim centrifugal supercharger with air-to-air front mounted intercooler. The complete system will boost your stock 2011 Jeep form 140 rear wheel hp to 230HP* and 240lb/ft* torque with 7-8 PSI from the V-3 supercharger at the factory redline.
Complete System Included:
Vortech V-3 Si-trim compressor with 3.60' drive pulley
Peak Manifold boost pressure: 7-8 psig @ redline on stock engine
RIPP Pre-Programmed Plug & Play Electronics with a safe, custom calibration for 91-octane fuel
Fuel system upgrade includes plug and play fuel injectors
Air inlet assembly includes: High-flow roto-molded ducting and high flow air filter
Silicone couplers and reducers with stainless steel clamps
RIPP PCV and breather hose provisions for both automatic and manual transmission applications
Easy to follow instructions
Hardware One Year warranty
Discharge components include:
Welded air/air charge cooler
Mandrel bent aluminum charge tubes for high flow and minimal weight
Stainless steel clamps
Silicone couplers
Quiet Race Bypass Valve Installation time is rated at 8 hours
WARNING: CHECK WITH LOCAL EMISSIONS REGULATIONS BEFORE INSTALLING. MAY NOT SATISFY LOCAL SMOG/CARB REQUIREMENTS. FOR OFF ROAD USE ONLY.
Bond Gilmer - President / Rebel Leader
- 866 900 8841
Visit us on:
REBELOFFROAD is offline
RIPP Black Firday Thru Cyber Monday 2011 RIPPMODS Vendor Display 0 11-24-2011 07:46 AM
RIPP MODS Superchargers now at KrawlOff-Road.com KrawlOff-Road Vendor Display 0 08-27-2011 11:43 AM
You may not post new threads
