2007-2011 Jeep JK Wrangler Long Arm at Rockridge4wd.com - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > 2007-2011 Jeep JK Wrangler Long Arm at Rockridge4wd.com
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSOPTIC ARMOR WINDOWS all sale now !!!!!!!!FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 01-10-2013, 01:31 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
2007-2011 Rough Country Jeep JK Wrangler Long Arm Suspension/ upgrade kit
Gain the absolute best in off-road articulation and a host of impressive features with this all-inclusive package. There are no obstacles you can't tackle with our front and rear Y-link Suspension setup featuring HUGE adjustable 2" lower control arms and X-Flex Joints. This Dual Y-link Suspension setup with longer travel arms doesn't just prevent binding and rear-steer, it gives you unparalelled axle flex while keeping pinion angles optimized - letting you negotiate trails on your terms. Combine that power with OEM style Clevite Bushings, Sway Bar Disconnects, and our Large diameter Performance 2.2 Shocks and you've got a rig that's ready to go where most wouldn't dare.
The JK Long Arm Kit is built to withstand the harshes of off-road mayhem. A beefy crossmember with frame strengthening brackets gives your JK new, stronger mounting points while a 1/4" thick steel skid plate keeps everything protected from off-road hazards. This kit also includes sway-bar disconnects, stainless steel brake lines, and and adjustable front track bar.
Rough Country Long Arm Upgrade For 4" - 6" Lifts - 2007-2011 Jeep JK Wrangler - ALL Unlimited Sport Rubicon & Sahara Models
Front: Sway-bar disconnects, stainless steel brake lines, HD lower skid plate, X-Flex lower control arms and upper radius arms, crossmember w/frame strengthening brackets & hardware.
Rear: Stainless steel brake lines, X-Flex lower control arms and upper radius arms & hardware.
Rough Country Long Arm Suspension 4" Lift - 2007-2011 Jeep JK Wrangler - 2 DOOR
Front: Lifted coil springs, adjustable track bar, sway-bar disconnects, stainless steel brake lines, HD lower skid plate, X-Flex lower control arms and upper radius arms, crossmember w/frame strengthening brackets & hardware.
Rear: Lifted coil springs, coil correction plates, track bar bracket, sway-bar links, stainless steel brake lines, X-Flex lower control arms and upper radius arms & hardware.
Shocks: (4) High Performance 2.2 series
Click image for larger version
Name:	RC 4 In Long Arm Suspension Kit.jpg
Rough Country Long Arm Suspension 4" Lift - 2007-2011 Jeep JK Wrangler Unlimited - 4 DOOR
Rough Country Long Arm Suspension 6" Lift - 2007-2011 Jeep JK Wrangler Unlimited - 4 DOOR
INSTALLATION INSTRUCTIONS
http://www.roughcountry.com/install/921786000.pdf
Blake
sales@rockridge4wd.com
www.Rockridge4wd.com
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote
Unread 01-10-2013, 02:15 PM   #2
mogo116
hey I ordered stuff for my tj from you awhile back just picked up a 2 door 13' rubicon what kind of lifts do you have for it?>
[B]98 TJ RED built nicely - SOLD 12/31/12
89 YJ BLACK stock great shape- Traded in 1/5/13
13 JK 2DR RUBI CRUSH ORANGE - picked up 1/09/13[/B]
[B][COLOR="Orange"]MY BUILD[/COLOR][/B]
[URL="http://www.jeepforum.com/forum/f22/no-pulp-2dr-13-jk-rubicon-build-1461729/"]http://www.jeepforum.com/forum/f22/no-pulp-2dr-13-jk-rubicon-build-1461729/[/URL]
[B]Registry[/B]
[URL="http://www.jeepforum.com/forum/f288/no-pulp-1462178/"]http://www.jeepforum.com/forum/f288/no-pulp-1462178/[/URL]
mogo116 is offline   Reply With Quote
Unread 01-10-2013, 03:14 PM   #3
Rockridge4WD
Vendor
2010 JK Wrangler
We carry BDS, ROUGH COUNTRY, ZONE, Rubicon Express, TeraFlex 2.5", 3.25", 3.5", 3.75", 4", 5", 5.5" and 6" lift kits for your 13' rubicon if you want to contact us at www.Rockridge4wd.com or you can call our toll free #888-411-8493
Blake
www.rockridge4wd.com
Unread 03-05-2013, 04:04 PM   #4
Rockridge4WD
Vendor
2010 JK Wrangler
Do you have a 07-11 jeep wrangler jk, If yes Rockridge 4wd has the long arm upgrade for you by Rough Country
Get yours today here
Blake
Blake@Rockridge4wd.com
