2007 - 2011 Jeep JK Long Arm Lift Kits - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > 2007 - 2011 Jeep JK Long Arm Lift Kits
FS: Wranger BRIGHT License Plate LED! Just $3! Great valuePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-07-2013, 09:34 AM   #1
CCOR
Vendor
1979 CJ5
2007 - 2011 Jeep JK Long Arm Lift Kits by Rough Country
Call 855-572-GEAR Post Up, or PM to get your CCOR Discounted Price!
2007-2011 Jeep JK Wrangler 4"/6" Long Arm Upgrade
Kit Contents:
Front: Sway-bar disconnects, stainless steel brake lines, HD lower skid plate, X-Flex lower control arms and upper radius arms, crossmember w/frame strengthening brackets & hardware.
Rear: Stainless steel brake lines, X-Flex lower control arms and upper radius arms & hardware.
Applicable Models:
• 2007-2011 Jeep JK Wrangler (2 door)
• 2007-2011 Jeep JK Wrangler Unlimited (4 door)
Notes:
• Upgrades 4" or 6" kits only.
Benefits:
• Upgrades short arm kit to long arm.
• Dual Y-link suspension setup with longer travel arms.
• Prevents binding and rear-steer.
• Gain unparalelled axle flex while keeping pinion angles optimized.
• HD 1/4" thick skid plate protects transmission & transfer case.
• Lower X-Flex control arms feature:
• Massive flex joints with 2.5" diameter body and huge 1.25" threads
• OEM style Clevite rubber bushings
• All joints are fully rebuildable
• Fully greasable
• Adjustable retainer ring
• Lower joints pivot up to 35 degrees
• Made of 2" diameter heavy duty tubing
Specs:
• Part #: 790
• Install Time: 8 - 10 hours
2007-2011 Jeep JK Wrangler 4" Long Arm Suspension
Kit Contents:
Front: Lifted coil springs, adjustable track bar, sway-bar disconnects, stainless steel brake lines, HD lower skid plate, X-Flex lower control arms and upper radius arms, crossmember w/frame strengthening brackets & hardware.
Rear: Lifted coil springs, coil correction plates, track bar bracket, sway-bar links, stainless steel brake lines, X-Flex lower control arms and upper radius arms & hardware.
Shocks: (4) High Performance 2.2 series
Applicable Models:
Benefits:
• Increased ground clearance.
• Coil correction plates corrects the rear coil angle 10 degrees.
• Coil correction plates allows the rear coil springs to function more effeciently.
• Application valved Premium Performance 2.2 shocks
• Fully greasable
Specs:
• Part #: 786.22 - 2 door
• Part #: 787.22 - 4 door
2007-2011 Jeep JK Wrangler Unlimited 6" Long Arm Suspension
Kit Contents:
Front: Lifted coil springs, adjustable track bar, track bar bracket, pitman arm, sway-bar disconnects, stainless steel brake lines, HD lower skid plate, X-Flex lower control arms and upper radius arms, crossmember w/frame strengthening brackets & hardware.
Applicable Models:
Benefits:
• Fully greasable
Specs:
• Part #: 789.22
The first person to order anyone of these kits, then post back up on this forum about buying it from us get's $40 off are already low prices. Also you have a chance to get 10% rebate back from Rough Country directly. 10% back from Rough Country!
Thanks,
Bobby
Sales Manager
CCOR
855-572-GEAR
www.classiccityoffroad.com
To order call 706-559-9609
Randy's Gear Supply
CCOR is offline   Reply With Quote Quick reply to this message
Unread 01-08-2013, 08:51 AM   #2
CCOR
Vendor
1979 CJ5
Thanks,
Bobby
Sales Manager
CCOR
855-572-GEAR
Randy's Gear Supply
Unread 01-09-2013, 07:06 AM   #3
CCOR
Vendor
1979 CJ5
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 01-09-2013, 10:27 AM   #4
CCOR
Vendor
1979 CJ5
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 01-10-2013, 02:35 PM   #5
CCOR
Vendor
1979 CJ5
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 01-11-2013, 04:04 PM   #6
CCOR
Vendor
1979 CJ5
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 01-12-2013, 12:28 AM   #7
CCOR
Vendor
1979 CJ5
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 01-14-2013, 03:09 PM   #8
CCOR
Vendor
1979 CJ5
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 01-15-2013, 01:12 PM   #9
CCOR
Vendor
1979 CJ5
Bobby
Sales Manager
CCOR
706.207.4140
Randy's Gear Supply
Unread 01-16-2013, 10:20 AM   #10
CCOR
Vendor
1979 CJ5
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 01-18-2013, 09:39 AM   #11
CCOR
Vendor
1979 CJ5
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 01-22-2013, 10:14 AM   #12
CCOR
Vendor
1979 CJ5
Thanks for the orders,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 01-22-2013, 02:57 PM   #13
mogo116
anything for a 13 2 door rubicon?
[B]98 TJ RED built nicely - SOLD 12/31/12
89 YJ BLACK stock great shape- Traded in 1/5/13
13 JK 2DR RUBI CRUSH ORANGE - picked up 1/09/13[/B]
[B][COLOR="Orange"]MY BUILD[/COLOR][/B]
[URL="http://www.jeepforum.com/forum/f22/no-pulp-2dr-13-jk-rubicon-build-1461729/"]http://www.jeepforum.com/forum/f22/no-pulp-2dr-13-jk-rubicon-build-1461729/[/URL]
[B]Registry[/B]
[URL="http://www.jeepforum.com/forum/f288/no-pulp-1462178/"]http://www.jeepforum.com/forum/f288/no-pulp-1462178/[/URL]
mogo116 is offline   Reply With Quote Quick reply to this message
Unread 01-23-2013, 03:19 PM   #14
CCOR
Vendor
1979 CJ5
Yes the kit will work on a 13 its just they don't have the exhaust kit that reroutes available yet. So you can reroute it or get another exhaust kit and this lift will work!
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 01-25-2013, 11:57 AM   #15
CCOR
Vendor
1979 CJ5
Get yours installed here at the shop and we'll set you up with a package price with tires and wheels. We can regear your axles too!
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
