2003-2004 Jeep Grand Cherokee Front Brake Pad & Rotor Kit Semi-Metallic - JeepForum.com
post #1 of 1 Old 06-24-2014, 03:21 PM Thread Starter
1ATony
Vendor
1ATony's Avatar
VISIT US HERE FOR GREAT PRICES 2003-2004 Jeep Grand Cherokee Front Brake Pad & Rotor Kit Semi-Metallic
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!!
Hearing squeaking noises from the wheels? This may be the wear tabs on the brake shoes saying, "it is time for replacement." Aging brakes can also result in a pulsation from the brake pedal or long stopping distances. Brakes should be inspected every 10,000 miles or any time the tires are removed. They may need frequent replacement such as every 20,000 miles if used in stop and go traffic. Brakes can last longer if the vehicle is used primarily for long highway trips.
Kit specifications:
Fits both LH (Driver Side) & RH (Passenger Side) FRONT
Rotors with 5 Lug Holes
No core charge
Direct replacements
Professional Grade SEMI-METALLIC Disc Brake Pads
Correct for models with Akebono Calipers
See attached picture for caliper reference
NOTE: For 2002 models you can find the production date of your vehicle on either the outer edge of the driver's front door or on the latch piller that the door closes on.
NOTE: Jeep used 2 different types of brake calipers on the Grand Cherokee, Akebono, and Teves. This brake pad & rotor kit is only correct for Akebono brand calipers. The easy way to tell the difference is if you look at your front and rear calipers and they are different you have the Akebono's in the front. If they all look the same you have the Teves style. This kit is correct for Akebono calipers only.
This front brake pad & rotor kit makes a great replacement and has an excellent value over the price of dealer brake pads & rotors.
SHOP HERE FOR AWESOME
1ATony is offline
You may not post new threads
