2001-2004 Jeep Grand Cherokee Power Window Regulator with Motor Front Driver Side - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > 2001-2004 Jeep Grand Cherokee Power Window Regulator with Motor Front Driver Side
JK specific skid plates from Clayton Off Road Mfg.RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comStainless Steel Door Hinge Pins
Unread 02-12-2014, 12:53 PM   #1
1ATony
Vendor
VISIT US HERE FOR GREAT PRICES 2001-2004 Jeep Grand Cherokee Power Window Regulator with Motor Front Driver Side
FREE SHIPPING ON ALL ORDERS IN THE LOWER 48 STATES!!!
This replacement window regulator is just what you need to get your vehicle in good working form again!
Specifications:
Fits LH (Driver Side) FRONT
Power operation
Replaces dealer part numbers: 55363287AA, 55363287AB, 55363287AC, 55363287AD
Includes the power window motor
100% tested prior to leaving factory
Direct replacement
Built to strict quality control standards
This window regulator makes a great replacement and has good cost savings over the dealer part.
Installation
This repair is easier than you may think. You'll find our installation videos helpful. In our experience removing and replacing the door panel is the most involved step in the repair. On most vehicles this only requires removing a few screws and push in clips.
You'll get a great feeling of accomplishment after you complete this repair knowing you saved money, and you didn't have to give up your car for a day at the repair shop. Your passengers and other drivers will be amazed.
Fit guaranteed
1A Auto will refund you with no hassle, if this Window regulator does not fit the application stated.
You can use your existing hardware and wiring harnesses. This Regulator will install just as your original does. Save time and money.
Quality
Be confident this part will work right. Every regulator is tested after assembly to make sure all mechanisms are working correctly.
It is important that your new regulator works for a long period of time. The design of this regulator is tested to withstand 10,000 cycles. That is enough to raise and lower your window 3 times per day for 9 years.
Nothing is more frustrating than taking your car apart and finding the part you purchased does not fit. You want the part to fit. This design is test fit on an actual door. When you install it, you will have no issues.
Value
Windows that don't work can be frustrating. They can also hurt your vehicles value. An inoperable window could mean $200-$500 discounted off a dealer trade value or asking price.
Some shops and dealers charge more for parts and repairs when they think you don't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly repair bill.
Lifetime Warranty
This item is backed by a manufacturer's Limited Lifetime Warranty. In the event this item should fail due to manufacturing defects during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
HOLLANDER #: 125-02861, 125-02836L
OE #: 55363287AD, 55394227AC
PARTSLINK #: CH1350122
DORMAN #: 741-556
1ATony is offline   Reply With Quote
Unread 02-21-2014, 01:22 PM   #2
1ATony
Vendor
bump
Unread 02-26-2014, 02:47 PM   #3
1ATony
Vendor
ttt
