1991-1999 Jeep Cherokee Exhaust Manifold & Gasket Kit for L6 4.0L (High Quality) Stai - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > 1991-1999 Jeep Cherokee Exhaust Manifold & Gasket Kit for L6 4.0L (High Quality) Stai
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Stainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 03-07-2014, 11:18 AM   #1
1ATony
Vendor
VISIT US HERE FOR GREAT PRICES 1991-1999 Jeep Cherokee Exhaust Manifold & Gasket Kit for L6 4.0L (High Quality) Stainless Steel
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!!!
Specifications:
Brand New High Quality Exhaust Manifold Kit
2 bolt exhaust flange
Includes Gaskets and Hardware
Direct replacement
Stainless Steel
Gasket install kit included
Benefits of this manifold
High temperature welds to promote better metal integration at jointed areas. This is shown by high temperature color patterns near welds.
Wide surface weld patterns used in joint areas for superb strength and shock resistance.
Uses same material for welds throughout construction to allow for the same cooling and expansion rates to promote durability and reduce failure. This can be seen by the same dull color of weld bead vs tubing material.
Precision ground flanges to give best possible mating surfaces to bolt against cylinder head
More precise radius bends allowing for better alignment between exhaust pipe and cylinder head flange
Lifetime Warranty
This item is backed by a manufacturer's Limited Lifetime Warranty. In the event this item should fail due to manufacturing defects during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
HOLLANDER #: 327-1533
DORMAN #: 674-196
Click Here^^ For a Great Selection Of Auto Repair Parts
1ATony is offline   Reply With Quote
Unread 05-19-2014, 02:41 PM   #2
1ATony
Vendor
ttt
