SHOP HERE 1989 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 4.2L Models with Aisin Brand Transmission (Exedy)
FREE SHIPPING
This clutch set includes:
- Clutch Disk
- Outside Diameter Size - 265mm (10 1/2")
- Spline Diameter - 1 1/8"
- Number of Splines - 10
- Pressure Plate
- Throw-out Bearing
- Alignment tool
- Installation guide
- Slave cylinder included
- Fits the following Jeep engines as listed:
- L6; 4.0L; Non-Turbo; Gas
- L6; 4.2L; Non-Turbo; Gas
- For 1989 Model year - Only fits models with the AISIN AX15 Manual Transmission
To determine which manual transmission you have:
AISIN MT AX15:
- Has the Identification: 53005385
- Peugeot BA10 (AM XJ & MJ):
- Case splits length wise down the middle
- Length: 16 7/8 "
- May have "SIMI" & 3.283... cast into the front & side of the case
ALSO FITS THESE VEHICLES
VEHICLE FIT
- 1989 Jeep Cherokee Clutch Kit with Slave Cylinder for L6 4.0L Models with Aisin Brand Transmission (Exedy)
- 1990-1992 Jeep Cherokee Clutch Kit with Slave Cylinder for L6 4.0L (Exedy)
- 1989 Jeep Comanche (MJ) Clutch Kit with Slave Cylinder for L6 4.0L Models with Aisin Brand Transmission (Exedy)
- 1990-1992 Jeep Comanche (MJ) Clutch Kit with Slave Cylinder for L6 4.0L (Exedy)
- 1989 Jeep Wagoneer Clutch Kit with Slave Cylinder Models with Aisin Brand Transmission (Exedy)
- 1990 Jeep Wagoneer Clutch Kit with Slave Cylinder (Exedy)
- 1989 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 4.2L Models with Aisin Brand Transmission (Exedy)
- 1990 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 4.2L (Exedy)
- 1991-1992 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 4.0L (Exedy)
