1989 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 4.2L Models with Aisin Brand - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > 1989 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 4.2L Models with Aisin Brand
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!
Unread 07-29-2015, 08:44 AM   #1
1ATony
Vendor
SHOP HERE 1989 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 4.2L Models with Aisin Brand Transmission (Exedy)
FREE SHIPPING
This clutch set includes:
  • Clutch Disk
  • Outside Diameter Size - 265mm (10 1/2")
  • Spline Diameter - 1 1/8"
  • Number of Splines - 10
  • Pressure Plate
  • Throw-out Bearing
  • Alignment tool
  • Installation guide
  • Slave cylinder included
  • Fits the following Jeep engines as listed:
  • L6; 4.0L; Non-Turbo; Gas
  • L6; 4.2L; Non-Turbo; Gas
  • For 1989 Model year - Only fits models with the AISIN AX15 Manual Transmission
Does not fit models with the Peugeot BA10 Manual Transmission
To determine which manual transmission you have:
AISIN MT AX15:
  • Has the Identification: 53005385
  • Peugeot BA10 (AM XJ & MJ):
  • Case splits length wise down the middle
  • Length: 16 7/8 "
  • May have "SIMI" & 3.283... cast into the front & side of the case
ALSO FITS THESE VEHICLES
VEHICLE FIT
  • 1989 Jeep Cherokee Clutch Kit with Slave Cylinder for L6 4.0L Models with Aisin Brand Transmission (Exedy)
  • 1990-1992 Jeep Cherokee Clutch Kit with Slave Cylinder for L6 4.0L (Exedy)
  • 1989 Jeep Comanche (MJ) Clutch Kit with Slave Cylinder for L6 4.0L Models with Aisin Brand Transmission (Exedy)
  • 1990-1992 Jeep Comanche (MJ) Clutch Kit with Slave Cylinder for L6 4.0L (Exedy)
  • 1989 Jeep Wagoneer Clutch Kit with Slave Cylinder Models with Aisin Brand Transmission (Exedy)
  • 1990 Jeep Wagoneer Clutch Kit with Slave Cylinder (Exedy)
  • 1989 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 4.2L Models with Aisin Brand Transmission (Exedy)
  • 1990 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 4.2L (Exedy)
  • 1991-1992 Jeep Wrangler Clutch Kit with Slave Cylinder for L6 4.0L (Exedy)
VISIT US HERE FOR JEEP REPAIR PARTS
1ATony is offline   Reply With Quote Quick reply to this message
