1983-1986 Jeep CJ7 Cast Iron Exhaust Manifold for L4 2.5L - JeepForum.com
post #1 of 1 Old 01-06-2014, 01:12 PM Thread Starter
1Aauto
Vendor
1Aauto's Avatar
VISIT US HERE FOR GREAT PRICES 1983-1986 Jeep CJ7 Cast Iron Exhaust Manifold for L4 2.5L
FREE SHIPPING IN THE LOWER 48 STATES!!!
Our aftermarket manifolds are some of the highest quality replacements on the market!
If your vehicle's exhaust is getting loud and the exhaust noise is coming from under the hood or engine then you may need to fix a cracked exhaust manifold. Replacing a broken manifold is easiest with a direct replacement manifold that will fit correctly and bolt up to you original engine and exhaust system. This manifold is a direct fitting replacement.
This cast iron manifold has been designed to eliminate the faults of the original Jeep design.
Specifications:
Includes heat shield
2 bolt flange
Includes Gaskets and Hardware
Direct replacement
Replaces original manifolds that are cracked from thermal expansion and contraction
Corrosion resistant
Strengthened and redesigned in the vulnerable areas of failure
Now you can buy a high quality exhaust manifold that is built to strict quality control standards for about almost 1/3 the price of the dealer. REPLACE your broken, warped, or cracked one now with this great fitting, alternative.
Lifetime Warranty
This item is backed by a manufacturer's Limited Lifetime Warranty. In the event this item should fail due to manufacturing defects during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
HOLLANDER #: 327-1314, 327-01209T
DORMAN #: 674-225
I will be out of the office on 7/24/2017 and will return on 8/7/2017. PLEASE CALL OUR SALES STAFF WITH PRODUCT INQUIRIES 888-844-3393
1Aauto is offline
You may not post new threads
