14 Bolt Trusses from RuffStuff! - JeepForum.com
post #1 of 5 Old 11-21-2012, 01:42 PM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
Ok already! Yes we took our time in making these but it was worth the wait
We don't copy other companies products and when another company made a better truss we stood back and watched and learned, what did we learn? We decided they had a pretty good idea but we found ways to do it better, for less...
First off, we did not create an Ibeam, while strong it is welded to only one side of the axle. I have seen way too many warped axle housings simply because of that. When you apply a ton of heat to one side without doing the same to the other side what do you guess the odds are that you just warped that axle housing?
Ours are like all of our trusses for our Custom Axle Housings where the weld points are opposed 180 degrees so when welding you are heating both sides of the tubes evenly and minimizing warp! Thats right, we create a Torsion Box rather than an Ibeam. Just another way to add heaps of strength while minimizing weight.
Another thing we do is make the Pinion Support part of the package. I do not want to encourage you to weld the housing to the casting only to watch it crack off later, or even worse and warp or crack the casting. The Pinion Support is also made with oval holes so you can run it with or without a Pinion Guard
Garett will complete a 4 link package using these tommorrow morning and it will have a ton of options like adding a Diff Cover or Pinion Guard or Disc Brake Brackets at discounted prices. Or multiple link options from our Horizontal 4 Link brackets to the simple and inexpensive choices like our link tabs...
Right now the price looks like it will be $190 for the Truss and Pinion Support
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #2 of 5 Old 11-24-2012, 12:56 PM Thread Starter
Dan Fredrickson
Vendor
Something new and in every way simply more than the others
Dan Fredrickson
post #3 of 5 Old 12-06-2012, 01:16 PM Thread Starter
Dan Fredrickson
Vendor
These have a bunch of options to save you money, you can add a Diff Cover, Disc Brake brackets, or Pinion Guard at the same time for a discounted price and the JPFORM discount code will add an even greater discount
Dan Fredrickson
post #4 of 5 Old 12-10-2012, 01:49 PM Thread Starter
Dan Fredrickson
Vendor
Lots of them out the door already, show us some pics in use!
Dan Fredrickson
post #5 of 5 Old 05-13-2013, 03:27 PM Thread Starter
Dan Fredrickson
Vendor
I am posting this here because Jeepforum cannot get its sh** together enough to fix my account and I don't want you guys to miss this sale entirely. I first posted this Friday morning on 66 other sites but this one just doesn't care to fix something I paid for!
This is for those of you that were left home this weekend. Thatís right, all you Motherís need a push to get it in gear and this should be enough to do the trick! For the Mothers day weekend only, starting NOW until Monday at 6PM (PST) everything is 20% off. Plug in MOTHER as the discount code to get these prices
We havenít had stock levels this high in 6 years so we are ready for you and with 700 parts we are only out of stock on 4 of them thanks to todays Heim delivery! Get on it, timesí flying byÖ
And while you're at it sign up for our mailing list so you don't miss these offers in the future!
Off-Road Fabrication Parts - RuffStuff Specialties
Dan Fredrickson
You may not post new threads
