Is there more ground clearance with the Off Road Suspension? - JeepForum.com
post #1 of 19 Old 11-12-2013, 10:19 AM Thread Starter
shark715
2014 KL Cherokee
If I order the Active Drive II (which includes Off Road Suspension) on a Limited does anyone know the details of the Off Road Suspension? Does it include additional ground clearance (versus the standard suspension)? Thanks in advance for your help.
shark715 is offline
post #2 of 19 Old 11-12-2013, 01:58 PM
Zoramac
2014 KL Cherokee
I do believe that that active drive 2 gives an additional 1" of ground clearance and a 4WD Low. (tires on the Trailhawk give it the additional 1") I'm 99% positive I read that somewhere, but cant seem to find where it was at the moment.
Zoramac is offline
post #3 of 19 Old 11-12-2013, 02:20 PM
NHPATRIOT
2014 KL Cherokee
I have read the same thing. ADII gives you the same suspension as the TH comes with and with the same size tires you would have the same 1" extra in height/GC.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline
post #4 of 19 Old 11-20-2013, 04:44 PM
WildcatRider
WildcatRider is offline
post #5 of 19 Old 12-08-2013, 08:53 PM
dsg76
Similar question- Is the actual ride different from the ADI (Limited) to ADII (TH)? I know the TH has an extra 1", but since i will be doing mostly normal road driving on the TH, I dont want a rougher ride.
dsg76 is offline
post #6 of 19 Old 12-09-2013, 06:51 AM
NHPATRIOT
2014 KL Cherokee
There will most likely be different springs and stiffer shocks. Ride will definitely suffer on road compared to ADI. May not be a big difference to you but the only way to know would be to test drive an ADI/ADII and see to be sure.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
post #7 of 19 Old 12-09-2013, 09:04 AM
rebelbowtie
Where are they measuring the ground clearance? At the skid plates? Clamshell differential? Or the actual lowest part of the vehicle ie the LCA? Because actual ground clearance would be the same regardless of suspension since tire height is the only thing that actually increases the clearance at the control arms. Manufactures do this kind of misdirection a lot, Toyota did it with the 3rd gen 4Runner claiming ridiculous 15" of ground clearance but the actual ground clearance is around 10". They measured and advertised the clearance at the front clamshell differential and not the actual lowest point which was the rear lower control arms and shock mounts since they hang down below the axle.
They did that so they could say it had higher ground clearance than Jeep Wrangler.
rebelbowtie is offline
post #8 of 19 Old 12-09-2013, 01:50 PM
Jimd0313
1983 CJ7
There is no additional "ground clearance" with Active Drive II. The Trailhawk has a 1 inch "ride height" difference, but the ground clearance is 8.7 inches across the board.
Jimd0313 is offline
post #9 of 19 Old 12-09-2013, 04:51 PM
NHPATRIOT
2014 KL Cherokee
Not according to Jeep.
Ground clearance by model...
2014 Cherokee Sport = 7.9"
2014 Cherokee Latitude = 8.2"
2014 Cherokee Limited = 8.2"
2014 Cherokee Trailhawk = 8.8"
I believe if you add ADII to the Latitude or Limited you end up with the same as the TH( might need the 245/17's too? ).
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
post #10 of 19 Old 12-11-2013, 01:12 PM
Jimd0313
1983 CJ7
Originally Posted by WildcatRider View Post
See page 13. Ground Clearance Specs listed as the same. Where are you getting your numbers from?
Jimd0313 is offline
post #11 of 19 Old 12-11-2013, 01:16 PM
Jimd0313
1983 CJ7
Looks like we have conflicting information. Jeep website states the numbers you listed above, but the vehicle literature books state differently.
Jimd0313 is offline
post #12 of 19 Old 12-11-2013, 01:56 PM
thegreatnardini
I test-drove two limited models, one with and one without ADII, the ADII model had more ground clearance.
thegreatnardini is offline
post #13 of 19 Old 12-11-2013, 02:07 PM
rebelbowtie
What size tires were on the vehicles? And where was the ground clearance measured?
post #14 of 19 Old 12-11-2013, 04:08 PM
thegreatnardini
Unfortunately I didn't get that info (I wanted a trailhawk so I wasn't paying too much attention to the other models), all I can say is that when they were parked next to each-other the ADII one was slightly taller by an inch or so and they seemed to have the same size tires. I did snag a picture of the ADII one, if anyone has an ADI picture to compare it to.
post #15 of 19 Old 12-11-2013, 06:07 PM
NHPATRIOT
2014 KL Cherokee
Just the tire size difference alone will negate them all having exactly the same GC.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
