9th Gear? - JeepForum.com
post #1 of 9 Old 05-07-2015, 06:28 AM Thread Starter
JeepTB
9th Gear?
I was going 84 MPH on a flat road and I wanted to check what gear I was in. It showed 8th. What does it take to get into 9th?
JeepTB is offline
post #2 of 9 Old 05-07-2015, 08:42 AM
zander21510
Throttle has to be just right and you need to be on a slight downhill grade or better.
zander21510 is offline
post #3 of 9 Old 05-07-2015, 11:13 AM
hooptycuztom
I've never seen ours use 9th..
Even when you shift it the number goes to 9 but the rpm don't change..
hooptycuztom is offline
post #4 of 9 Old 05-07-2015, 11:38 AM
zander21510
That's because it's not a "manu-matic". It's Electronic Range Selection, it just sets the highest gear you can go to, the shift is still determined by the computer.
post #5 of 9 Old 05-08-2015, 05:40 AM
hooptycuztom
But what's the point of having a 9spd if it never uses 9th..
post #6 of 9 Old 05-08-2015, 08:13 AM
zander21510
It's the "one transmission for all" mindset FCA has...their plan is to put the same transmission in EVERY SINGLE front-wheel-drive based vehicle they build. The 4-bangers see 9th much more often.
post #7 of 9 Old 05-08-2015, 11:30 AM
hooptycuztom
Well there 1 trans for all is a piece of crap.. maybe they need to try again
post #8 of 9 Old 05-08-2015, 11:40 AM
Professur
It's the numbers game. More must be better. You buy a computer scanner that does 1600dpi .... every photo in every magazine you've ever looked at is at 75dpi. The only reason for 1600dpi? It sells.
Professur is offline
post #9 of 9 Old 05-08-2015, 01:45 PM
hooptycuztom
No less is more.. all there doing is over complicating things.. to the point they can't even make it shift right nor have any idea how to fix the disaster trans there using .
My old th350 trans work just fine in my 72 blazer and 75 chevy truck.. and there 40yrs old.. 3 spd works like a charm..
I'll take 10 mpg in them and no ac over the cherokee any day.. this thing was nothing but A problem since day 1
