2014 KL Trailhawk LED Fog lights - JeepForum.com
post #1 of 5 Old 09-14-2017, 10:56 AM Thread Starter
JG14
Hey there,
I've slowly been getting the itch to start "upgrading" my KL a bit, and one area I think would be fun is the fog lights. The other day I saw a 14-17 Cherokee Trailhawk with LED (maybe HID?) fog lights and they looked really slick when coupled with the standard day-time running LED's. The problem is I'm not sure where to start.
I've found a few vendors that sell LED fog lights, but most note that light modifications will be required (welding, cutting, drilling). Seeing as how I'm a novice with this kind of thing I don't want to screw anything up, so I was hoping any of the more experienced members could point me in the right direction (or GIVE me direction). I have to imagine there's a set of LED fog lights that simply replace the factory pair but I can't seem to find any info.
JG14 is offline
post #2 of 5 Old 09-24-2017, 10:37 PM
fireman591
I just put a set of led bulbs in the existing housings. Very bright white that matches the DRLs. Alla Lighting 80W High Power Osram Xtremely Super Bright 2504 PSX24W LED Bulbs White for Fog Light Lamp. Got them at Amazon
fireman591 is offline
post #3 of 5 Old 10-14-2017, 07:05 AM
Pat2016jeepTH
New member here and proud new owner of a 2016 TH Cherokee, my first truck ever!!
And foglamp upgrade will also be my first mod... I was looking at the exact led bulbs mentionned above but just wondering if any error message will appear or do I need a bus-decoder harness?
Thanks for your help!
Pat2016jeepTH is offline
post #4 of 5 Old 10-14-2017, 09:34 AM
Cards81fan
Cards81fan's Avatar
2014 KL Cherokee
I just replaced my fog lamps this week with the Alla bulbs. No issues at all, no error messages. I wouldn't say they are notably brighter on road, but aesthetically they look better.
Just a pain removing the 3-year old bulbs with a brittle base; the plastic tabs broke off but I still got the bulbs removed with gentle use of needle-nose pliers to pull the tabs and old bulb out without damaging the lamp housing itself. It's a 10 min job if you get the old bulbs out okay.
Mindset, skillset, toolset - in that order!
Cards81fan is offline
post #5 of 5 Old 10-15-2017, 09:07 AM
fireman591
No error messages
