2014 Cherokee in Transport Mode? - JeepForum.com
post #1 of 14 Old 12-13-2013, 04:13 PM Thread Starter
tptman
2014 KL Cherokee
I took my brand new (524 miles) Cherokee Limited for service today for two reasons; a) Check engine light was on and b) Heater fan would not come on. I was advised that these two issues were due to the fact that the car was still in "ship mode" vs. "customer mode". Apparently, the dealer is supposed to put the car in customer mode as part of the prep process. I did not see anything in the display indicating the car was in ship mode, so I was very surprised when I heard this was the cause. I assume I am being given the straight scoop on this...anyone else ever hear of this happening?
tptman is offline
post #2 of 14 Old 12-13-2013, 04:31 PM
sfdxsm
2014 KL Cherokee
Not surprised. A lot of times it is hard to tell. My Audi has the same setting and through a diagnostic system that a lot of people use, you can set the car back into transport mode. I accidentally did it once and for a week could not figure out why the radio and hvac were not working right. Eventually solved it going through the diagnostic settings but nothing on the dash indicated what was up.
Weird that you didn't have issues BEFORE or see any symptoms.
sfdxsm is offline
post #3 of 14 Old 12-13-2013, 04:50 PM Thread Starter
tptman
2014 KL Cherokee
Thanks and yes, I was thinking the same thing...very odd that I had no issues prior to today. Everything was working fine.
tptman is offline
post #4 of 14 Old 12-13-2013, 06:45 PM
sfdxsm
2014 KL Cherokee
I would ask them to tell you a little more about what faults might have been thrown or any other info. Heater fan not coming and a check engine light indicate something happened that the transport mode was disabling or not letting happen properly. Hopefully it's just a random fault that isn't anything to worry about and not something more major like a faulty cooling system for the engine/tranny from the mode. I'd certainly ensure I got details so you a) can understand if you have future issues if there is any relation b) have something documented in case there are problems in the future you can show dealership fault.
I'm being a little dramatic but I started down the road of a lemon low and moss act complaints with the FTC and having records helped on a car.
sfdxsm is offline
post #5 of 14 Old 12-15-2013, 02:44 PM Thread Starter
tptman
2014 KL Cherokee
Thanks...that's good advice. The good news is that I haven't seen the check engine light come back on, but the heater fan problem is still there. Very strange...I started the car and let it idle in the driveway for a good five minutes or so and the heater fan finally came on. Later in the day, I went for a drive and the heater never came on. When I returned home, as I was making the right turn into my driveway, the fan came on for about 2 seconds and then stopped. I sat in the car and the fan never came back on. Tried manually adjusting the fan....nothing. I hit the defrost button to see if it would work and the fan came on. After that, the heater fan worked in auto and manual modes. It may be premature, but I am already starting to research the NJ lemon law just in case. It's a shame because I really like the car, but this is a $35,000+ vehicle and I should not have to be wasting my time dealing with things like this....this isn't feeling right.
tptman is offline
post #6 of 14 Old 12-15-2013, 04:05 PM
sfdxsm
2014 KL Cherokee
I can tell you from my research that Lemon Law and specifically in NJ requires the same issue 3 times to be reported and attempted to be fixed before you can make a claim. Once you hit that 3 problems though NJ offers a task force who will review your case and help file.
So you'll need to take the Jeep in 3 times for the same problem first. Keep every receipt showing the customer complaint and the dealership's findings to ensure you can prove your case. For example with me, all 4 times I took my other car in for a specific problem, it shows both my complaint (same one each time) and then the outcome of the fix (or non fix in some cases).
http://www.njconsumeraffairs.gov/ocp/lemonlaw.htm
Is your heat not working or you just don't hear the fan coming on? The fan won't always run but if you're blowing hot air then no issue. Especially in these temps and I see you're near me so I know it's been cold.
sfdxsm is offline
post #7 of 14 Old 12-15-2013, 06:21 PM Thread Starter
tptman
2014 KL Cherokee
Thanks again. The fan never comes on, even if I manually override with the knob or soft keys. I tried increasing the temp setting to see if that helped, but still nothing. It's freezing in the car even after driving for 30 minutes or more. Will post an update when I have more info.
tptman is offline
post #8 of 14 Old 12-16-2013, 09:49 PM Thread Starter
tptman
2014 KL Cherokee
Update: Still having issues with blower not operating properly. Came on after 40 minute drive this morning (upper 20s/low 30s outside temp). Check engine light has reappeared also. Took the car back to the dealer and the technician told me he is getting codes that relate to the blower circuit/module. He also said that the ck engine light is on that same circuit. He is going to reach out to Chrysler’s technical team for advice before replacing parts that may or may not correct the problem. I was given a Chrysler case number by the service advisor in the event that I need to speak with someone about the problem. Service expects to have an answer in a day or two.
tptman is offline
post #9 of 14 Old 12-16-2013, 09:53 PM
Jeffro06
Jeffro06's Avatar
Update: Still having issues with blower not operating properly. Came on after 40 minute drive this morning (upper 20s/low 30s outside temp). Check engine light has reappeared also. Took the car back to the dealer and the technician told me he is getting codes that relate to the blower circuit/module. He also said that the ck engine light is on that same circuit. He is going to reach out to Chryslerís technical team for advice before replacing parts that may or may not correct the problem. I was given a Chrysler case number by the service advisor in the event that I need to speak with someone about the problem. Service expects to have an answer in a day or two.
That sucks...it seems the new model gremlins are alive and well in the new Cherokee. (Or the Jeep gods are taking out revenge )
Jeffro06 is offline
post #10 of 14 Old 12-23-2013, 02:58 PM Thread Starter
tptman
2014 KL Cherokee
Yep...sucks big time. Car has been in the shop since last Wed. After consultation with Chrysler, they determined that the blower motor and blower module had to be replaced. They also said that the ck engine light is on the same circuit as the blower, so that is why the light was coming on. In additional to all of this, the collision warning system is not working no matter how I have it set. I rapidly approached a car at a stop light and nothing....no brake assist, warning, etc. Maybe I'll get lucky and find out that this system is on the blower circuit also! So far, my experience with the 2014 Cherokee has been a big disappointment. Was really looking forward to enjoying my new Jeep and hopefully, that day will still come.
tptman is offline
post #11 of 14 Old 01-02-2014, 02:52 PM Thread Starter
tptman
2014 KL Cherokee
Another quick update...they replaced the blower module and motor and guess what, the problem remains unresolved! Car has been in the shop over two weeks now and they are now telling me that the problem might be a loose ground or short somewhere. They said the blower motor comes on and off when making a right turn. Getting very close to filing a lemon law claim. Any advice would be appreciated.
tptman is offline
post #12 of 14 Old 04-05-2014, 07:10 AM
Liana46
Updates?
Hi....anything new on your situation?
Liana46 is offline
post #13 of 14 Old 06-01-2014, 01:08 PM
Scottlarock
How to get a jeep cherokee out of ship mode
Hold up arrow on the left of the steering wheel while also holding hazard defrost and tune/enter knob all for about 10 seconds.... it will reboot it into regular mode make sure the brightness is turned up aswell!!
Scottlarock is offline
post #14 of 14 Old 06-01-2014, 01:19 PM
Scottlarock
yes i wrote the answer under you
