Northern California trail runs starter thread: - Page 17 - JeepForum.com
post #241 of 365 Old 02-03-2013, 04:09 PM
kennyboobear
Originally Posted by MrAugie View Post
Not sure what southbay driveline charges but I'm scoring a front driveline from Jason at Krawl Off Road. Give him shout out and he will give you the info. It's worth looking into. That, does cost anything. Mine will be here Wed
May look into it but I've had South Bay do some work in the past and they do a grand job of it. If nothing else I'll be going to Drivelines Inc in Mission Viejo, but am fairly sure South Bay will be able to fab me up some beef. He's a stand up guy that warrants all his work, and they're local!
He built some shafts for a buddy's Mog that are other worldly lol
SILVER JEEP CLUB MEMBER #46
Get
Originally Posted by GraKee99 View Post
Driving on snow is a lot like sex, it's a lot of fun but if you don't pay attention, you can really mess up someone's rear end.
Originally Posted by Gene Mooneyham
Not to burst your bubble, but California gets worse every year. Liberals, and illegals have ruined any chance California had to get turned around, it's a sinking ship.
kennyboobear is offline
post #242 of 365 Old 02-03-2013, 06:09 PM
MrAugie
Can I ask what kinda price for a front DS?
1310 or 1350? Just for info. I'm not looking to open some debate.
MrAugie is offline
post #243 of 365 Old 02-03-2013, 09:16 PM
kennyboobear
I'd assume fairly competitive prices. Bear in mind that Krawl is simply a reseller of other mass produced products, as opposed to a driveline shop specializing in just that. Generally, the Tom Wood's front shaft for a TJ goes for about 350.
In this case, I'll have a scratch built front DC driveline built, likely with thicker walls than the TW front shaft for right around 350 in cash. I'll confirm this after I talk to both them, and also drivelines inc tomorrow.
Get
post #244 of 365 Old 02-04-2013, 09:24 AM Thread Starter
bobthetj03
Can you squeeze a 1350 joint on the front DS of a TJ?
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #245 of 365 Old 02-05-2013, 11:08 PM
kennyboobear
I guess you could if you changed the output yoke on the D30 and likewise on the TCase.
That said, I'd rather the weak link be the U Joints than the tube itself. U Joints are a dime a dozen when you figure the cost of a centering kit, tube, fab work etc. haha
At the end of the day it's not about creating something that doesn't break, as the only way you can stop it from breaking is by leaving it in the garage. I think the real task is setting things up so that when something DOES break, it's a weak link you left in place, as that weak link was the least expensive/easiest thing to replace.
For the same reason, I won't be doing 35 splines in my 44. The breaking point ends up becoming the carrier/locker/spider gears, and frankly that's a hell of a lot more expensive/difficult to replace than an axle shaft
Get
post #246 of 365 Old 02-06-2013, 09:14 AM Thread Starter
bobthetj03
Makes sence to me!
Bob's boring build:
post #247 of 365 Old 02-06-2013, 10:42 AM
123nanez
Hey after that hollister trip. Whenever I accelerate from a complete stop, something from my rear end feels broken or shakes. The more I accelerate from a complete stop the more I here this thumping noise. After like 5-10 mph though it disappears. Only happens at the beggining and only from a complete stop. Anyone know what it can be? Bent driveshaft? And thing broken in axle? Or I joints. My driveshaft is stuff on their so the u joints are loose or broken but idk
123nanez is offline
post #248 of 365 Old 02-06-2013, 11:03 AM
Gofish TJ
I would inspect the u-joints, maybe pull the diff cover off look for any kind of metal shavings. Could be the bearing. Don't wait to long could get worse and turn into more $.
Gofish TJ is offline
post #249 of 365 Old 02-06-2013, 11:09 AM
123nanez
I have to drain the fluids if I remove the cover correct?
123nanez is offline
post #250 of 365 Old 02-06-2013, 11:13 AM Thread Starter
bobthetj03
Another new run in the works.....
http://www.jeepforum.com/forum/f317/...013-a-1474876/
Bob's boring build:
post #251 of 365 Old 02-06-2013, 11:13 AM
123nanez
Whoops this sometimes auto corrects my words wrong. But the u joints seem good because the driveshaft dosent move at all with my hand.
123nanez is offline
post #252 of 365 Old 02-06-2013, 11:15 AM
123nanez
Not too familiar with axle specifics. But what bearings?
123nanez is offline
post #253 of 365 Old 02-06-2013, 07:13 PM
Gofish TJ
They are the axle bearings on the inner pinion and outer pinion. You'll have to drain the oil and pull the cover. There may be others on here that know a little more. Anyone want to chime in?
post #254 of 365 Old 02-06-2013, 07:28 PM Thread Starter
bobthetj03
I would chime in, but I want to keep this thread on track. Sorry guys. Hope it's nothing too serious.
Bob's boring build:
post #255 of 365 Old 02-06-2013, 07:34 PM Thread Starter
bobthetj03
Here's another one....
http://www.jeepforum.com/forum/f317/.../#post14921102
Bob's boring build:
