NorCal chat and banter - Page 27 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South West USA > California Jeep Forum > Northern California > NorCal chat and banter
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO 8.8 Swap Kit w/ TRUSS for JeepsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-05-2013, 07:45 PM   #391
102joe
I thought my fuel pump was bad turned out the filter in the tank was cloged swaped in a new one no issues for 2 years now . Hope you have the same luck pumps are pricy .
REAL JEEPS HAVE LEAF SPRINGS
NO REALY ,, IT IS HIP TO BE SQUAIR
102joe is offline   Reply With Quote Quick reply to this message
Unread 12-06-2013, 08:26 AM   #392
Agent620
I changed the filter on top of the pump a while back, that fixed it for a month and now its back to hard starts. The filter is half the price of a pump, so I might as well replace the whole thing if I am doing it again. I also want to clean the tank out.
[B][COLOR="Blue"]Thanks to Anticanman who gave me a membership![/COLOR][/B]
[QUOTE=Anticanman;15443763]Chris Hansen is reading this thread.
If you've ever been in that traffic, you would have ground down the steering wheel with a death grip too. "Just ****ing GOOOOOO!!!!"[/QUOTE]
[QUOTE=Luuca;15713642]I pitty anyone who tries to reach into that netting unaware.[/QUOTE]
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2013, 11:24 AM   #393
connor0770
could be the fuel pressure regulator in your pump? Might be draining the fuel out of your rail, which is why you have to prime it.
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2013, 11:38 AM   #394
Agent620
I replaced it once already with a brand new regulator.
'99 TJ (DD)
'89 XJ (WIP)
Unread 12-09-2013, 10:26 PM   #395
Anticanman
Follow me
Anticanman's Avatar
Is your Schrader valve on the fuel rail bad? It would cause air to enter.
Luck Favours The Prepared
"Whiskey is for drinking, Water is for fighting over" - Mark Twain
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 09:06 AM   #396
Agent620
I have no idea what that is. How do I check it?
'99 TJ (DD)
'89 XJ (WIP)
Unread 12-10-2013, 09:31 AM   #397
Jam86
Ever ridden a bicycle? The part where you fill up your tire is a Schrader valve. Cheap and easy fix
Jam86 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2013, 10:43 AM   #398
Agent620
Ah, I just know them as valve stems. I cant find a parts store that have any though. Or is it just a bike valve stem that fits on the fuel rail?
'99 TJ (DD)
'89 XJ (WIP)
Unread 12-10-2013, 11:42 AM   #399
102joe
I belive so , look In tire section my slime plug kit I got a Target has them in it
Unread 12-10-2013, 11:55 AM   #400
Agent620
Thanks, will do that today.
'99 TJ (DD)
'89 XJ (WIP)
Unread 12-11-2013, 09:47 AM   #401
fast540
a bicycle valve is actually a presta valve a shrader valve is an automotive type that has been used in some low end bicycle applications
fast540 is offline   Reply With Quote Quick reply to this message
Unread 12-11-2013, 09:50 AM   #402
102joe
Will a tire valve work ?
Unread 12-11-2013, 10:17 AM   #403
Jam86
Any bicycle ive ever dealt with has been a schrader valve, more robust, easily found, easily replaced, and no locknut to deal with. Im fairly sure that any bicycle now a days will use a schrader valve with an exception for a racing bicycle (like tour de france racing not your typical walmart racing bike) and the reasoning for this is because the tires are too narrow for the schrader valve.
Unread 12-11-2013, 10:23 AM   #404
102joe
I think the shrader valve is what he needs to fix his fuel rail
Unread 12-11-2013, 10:27 AM   #405
Jam86
Yes it is that would be the cheaper and easier solution. As long as its the only problem. Not sure if an auto parts store would have them I don't see why not. Should come in a package with like 4 of them and a tool to change them out. DONT torque it in there just be easy with it or you can damage it.
