Nor Cal Off Road - Page 435 - JeepForum.com
post #6511 of 9541 Old 05-14-2010, 10:03 AM
Goobersbro
so guys if I cut my breaks out how much am I looking at spending if I replace hardline and everything like a rough estimate....and can you splice a hard line??? Also if I were to cut would I cut on the soft line side or hard line side....the soft lines running down to the calipers are getting replaced with steel braded...
My marshmallow build
Goobersbro is offline
post #6512 of 9541 Old 05-14-2010, 10:23 AM
KMD
1976 CJ7
cutting is for hacks. but if you have to cut the soft line since you are replacing it with stainless braid anyways. You can resplice the hard lines but would need a flaring tool and some more line as well as a flare connector. Flaring tube is a little tricky.. They do make pre flared lines in various lengths that need to be bent to fit in place and they are under $10 a piece. try napa
KMD is offline
post #6513 of 9541 Old 05-14-2010, 10:43 AM
Sccafire
As far as removing the motor he has the tub off. It cannot get much easier than that. First put the cherry picker on, romove tranfer case for weight, with cherry picker holding weight remove both engine and trans at the same time. Then lower both so oil pan is barley off the ground and remove trans. Put motor on a stand. That is how I would do it.
With the brakes, cut the rubber lines. If you are not going to use the hardlines again then you can cut those. I personally would not splice the hardlines due to possible leakage. Jon, search the internet and junkyards possibly Davey's Jeeps and buy the complete pre bent brake lines. I do not think they are that exspensive. Anyway, brakes are not something you want to go cheap with or subpar work.
Scott
"life is good at 2 MPH"
Sccafire is offline
post #6514 of 9541 Old 05-14-2010, 11:07 AM
Goobersbro
rite I don't want to go cheap I'm just wondering a ball park range for my budget haha everything is budgeted and crap so I can have a deadline so if its going to cost more I have to push my finish date off ya know.....uhm I guess I'll just cut the soft lines and then maybe I can unthread thanks guys.... I'm about to pull the t case...just pulled all the shocks except one stubborn one I have to cut the mount its rear axle....And I have to remove the sway bar ....lol everyperson that like talks to me driving by or people who stop by are always like are you going to be able to put all of that back together...They are starting to make me nervous hahaha
post #6515 of 9541 Old 05-14-2010, 11:26 AM
Goobersbro
brake lines pulled yae now everything is officially stripped from the frame except the engine and the skid plate well and the leafs but those don't count...uhm another question should I drain the oil rite now.....the engine is just comming off the jeep and going into storage so should I leave the oil in it...does it matter??? also how is that going to work draining a cold engine???
post #6516 of 9541 Old 05-14-2010, 11:41 AM
timatoe
timatoe's Avatar
That does look like a crack to me too on the cylinder wall. I'd have that checked for sure if you're re-building. I thought you were getting a whole new engine though???
As for the brake lines, glad you got them off, but I'd replace them while they're easy to get at, especially if you've already had problems with them. Look here.... CUSTOM FORMED COMPLETE STAINLESS STEEL BRAKE LINE KITS - FOR JEEP, CJ AND WRANGLER - JCWhitney OR for less than half that price you could buy the stainless tube, and bend and flare all new lines. I personally wouldn't be trying to splice in any other lines to your existing stuff.
timatoe is offline
post #6517 of 9541 Old 05-14-2010, 02:34 PM
Goobersbro
yea at this point it looks like I will be replacing everything....SO I pulled the t case and found something that has me a bit worried rite now....I pulled it and a little bit of my gear oil came out of the transmission. I know this is normal...But the gear oil was a yellow color....SO I think I got mud and water in there when I went to PC last year with zac....The water was all in the jeep so I should have known better....I drove it home from pc and then started tearing it apart the next day so it was only driven home from sac...But that nasty stuff has been sitting in there since October....You guys think it has done any damage....also how do I get it all out??? Just buy a bunch of new oil and just flush it through???? Man now I"m super worried though. Can anything in there rust or you think its damaged at all? Should I take it in to the tranny shop??? I really don't want to have to spend more money on this rite now UGH...... It still shifts through the gears fine like its a little loud I think this is because I'm not sitting in the tub doing it. SO what are your guys opinions. I think I'm going to shoot a pm to mean max he seems pretty smart when it comes to this junk
post #6518 of 9541 Old 05-14-2010, 06:03 PM
bigsquat
i saw the pick and thought to myself"man that oil dosent look right" i was hopeing it was just water left over from pressure washing the tranny and skid. you are probably all right. since the water didnt seperate from the oil i dought it did much damage. if when you pull the drain plug and a lot of clear or rusty water runs out and then the oil ,then be afraid!.. i spent a while reading thru water in my manual tranny threads and most say just out in cheap gear oil or motor oil and run it till it warms up and do it again 3 times. since you cant do that i would just get the cheapest auto tranny fluid i could find and flush it with that a few times. i would be hesitant to use solvent or thinner or even alcohol(alcolhol would be great for water removal) due to seal damage. once your done with the build ,drain the last auto tranny fluid out(keep it in there while it sets to keep rust out) then add cheap gear oil and change it soon. then to a better grade and you should be good to go.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #6519 of 9541 Old 05-14-2010, 07:58 PM
Goobersbro
yea I'm such dumb butt I should have friggin changed it rite when I got home : ugh it totally slipped my mind I guess because of everything else I'm just scared because its sat 8 months with that water in there
post #6520 of 9541 Old 05-15-2010, 01:23 PM
Goobersbro
Hey tim what leafs are you using to go SOA with? I need to order mine within the next couple weeks along with spring perches...I'm going to go ahead and get a ruff stuff install kit for the 8.8 but who did you get your dana 30 spring perches and shock tabs through???
post #6521 of 9541 Old 05-15-2010, 02:50 PM
timatoe
timatoe's Avatar
I got all my shock tabs and U-bolts from Ruff Stuff, I got the front perches from Foothill Offroad in Auburn when they still had an actual store (now it's just online) they're the RE perches.
WFO Concepts also has a good selection of stuff, they're up here in Nevada County although they've got an Auburn address. I picked up their 12" shock hoops for the front, killer price @ $49 for the set, I was gonna go with the MORE kit for the front till I saw those.
I'm using the 2" BDS springs, I figured a ton of people run the 1.5" RE SOA springs so it should work out fine, plus I've had them on there for a while so they're broken in good.
timatoe is offline
post #6522 of 9541 Old 05-15-2010, 03:00 PM
Goobersbro
ah Okay well I just sent ALCAN springs in Colorado an Email lets see what they quote me back with....I asked for some stock heigth springs with mill wrap and something thats going to ride soft and flex awesome but I don't have to replace every year....I'm guessing they are gonna say somewhere in the 200 dollar a leaf range...Hopefully less but thats still do able..as for steering what did you do? I think I'm going to do the rocky mountain OTT its gonna run like 500$ though but it seems to be the best on the market
Also last question what are you doing for a ladder bar in the rear...I think I read you bought a M.O.R.E yea??? I'm gonna check out Ron's set up hopefully and a couple of other local guys and see what they did
post #6523 of 9541 Old 05-15-2010, 10:04 PM
timatoe
timatoe's Avatar
I ended up getting the JB4X4 bracket for the steering and yes the MORE anti-wrap bar when it was on sale for 20% off.
timatoe is offline
post #6524 of 9541 Old 05-17-2010, 12:39 AM
JeepDoo
Hey Bob did you upload that video of you blowing up the tire trying to seat it? I want to show it to one of my friends but I couldn't find it anywhere.
Hey hey, my my. Rock and roll will never die. - Neil Young
We've got too many gangsters doin dirty deeds. Too much corruption and crime in the street. It's time the long arm of the law put a few more in the ground. Send them all to their maker and he'll settle them down. - Toby Keith & Willie Nelson
Longboard Drunk, Jeep Naked, Ski Powder
and finish calculus homework
JeepDoo is offline
post #6525 of 9541 Old 05-17-2010, 10:32 AM
bigsquat
it might have been a little to much but it did seat and would have worked but there was a punture in the sidewall . maybe if the punture wasnt there it would have blown. it shot flames up the hill and set it on fire.
bigsquat is offline
Old Florida Road RubiExpressTJ Vermont Jeep Forum 219 11-04-2013 12:09 PM
Possible Road closure in NH Schwalby North East USA 15 03-25-2009 06:53 AM
Road Trip! ClarkGriswold South East USA 18 02-04-2009 08:18 PM
New to Off Road Vethial South Central USA 1 10-24-2008 10:07 PM
Mass Off Road Circusfreaky North East USA 2 10-22-2007 07:22 AM
