Nor Cal Off Road - Page 41 - JeepForum.com
post #601 of 9541 Old 05-15-2009, 12:05 AM
connor0770
hhahaha, yea there is alot of BS in here. i think we should catch up to the colorado thread hahhah they are on page like 734 or somehting like that
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #602 of 9541 Old 05-15-2009, 12:07 AM
Goobersbro
Originally Posted by NorcalYJ92 View Post
have you installed lockers?
i may order some.
what size tires you running i seen in the other thread that your soa and running the stock axles so im assuming you have 33s-35s in that case i would buy an Aussie locker and throw it up front there pretty easy to install and help abunch then i would save up and do a 8.8 with Limited slip or leave it open and install a locker of your choice
My marshmallow build
Goobersbro is offline
post #603 of 9541 Old 05-15-2009, 12:12 AM
NorcalYJ92
35" tires.
how much approx is an aussie locker and does anyone know anything about posi-locks (cable type)?
Eat. Sleep. Jeep.
NorcalYJ92 is offline
post #604 of 9541 Old 05-15-2009, 12:14 AM
Sccafire
Hey NorcalYJ92 I had a thought to help with your commute for the run. If you are not working on the sunday before see if you can stay at somebodys place the night before.
Scott
"life is good at 2 MPH"
Sccafire is offline
post #605 of 9541 Old 05-15-2009, 12:14 AM
Goobersbro
35" tires.
yea you really need to upgrade that rear axle especially if you plan on locking it i used the stock vacuum set up but i did some improvements to it i used some of those clamps that you pinch and then release and they tighten... i put those over the hoses and then released it and it holds it on nice and tite and then just to be extra good and because i had nothing better to do i put rvt all around the bases they hold really good like to the point where i can flex the jeep and stretch the hoses and they still dont fall off
post #606 of 9541 Old 05-15-2009, 12:15 AM
Sccafire
35" tires.
OX locker is a cable type locker and posi-lock is for the front axle to engage 4wd.
Scott
Sccafire is offline
post #607 of 9541 Old 05-15-2009, 12:16 AM
Goobersbro
Originally Posted by Sccafire View Post
OX locker is a cable type locker.
he is refering to the vacuum disconect system that connects the two shafts on the passenger side. The tjs converted to a one piece shaft just like the xjs (although i have heard of some xjs having a disco too)
Norcal just google it or do a quick search in the yj tech forum also yet again on the trail run you can look at Bob (bigsquats) set up
post #608 of 9541 Old 05-15-2009, 12:19 AM
Sccafire
Correct! the Posi-lock is the brand name for the company that makes the cable system to replace the vacuum system.
http://www.4x4posi-lok.com/
Scott
Sccafire is offline
post #609 of 9541 Old 05-15-2009, 12:19 AM
connor0770
SLUMBER PARTYYYYYYY!!!!!!!!!!!!!!!!!!!!!
post #610 of 9541 Old 05-15-2009, 12:27 AM
NorcalYJ92
If anyone has a place to crash at on sunday it would deffinetly help the commute.
as far as the posi-lock does this set up look good?
http://sfbay.craigslist.org/nby/pts/1160138873.html
Eat. Sleep. Jeep.
post #611 of 9541 Old 05-15-2009, 12:30 AM
timatoe
timatoe's Avatar
im sorry i knew that sounded to far it was 3 hours and 20 minutes i did it this morning before work i probably should wake up earlier next time
it tells me i should go 99 to 50 but i know for a fact if i take 65 to 193 to 49 it will be faster i know this because i use to drive to auburn all the time and i can get to auburn pretty fast 49 is pretty windy but it wont be to bad it only adds 10 minutes going this way but i can make that up lol
I think you'd be better off, taking 65 to 80 to Sierra College to Hazel to 50, early enough in the morning there shouldn't be too much traffic. I'll be taking 49 all the way down to P'ville but only so I'm not dropping back west.
timatoe is online now
post #612 of 9541 Old 05-15-2009, 12:30 AM
Goobersbro
no because it cost 100 bucks you can do it for like less than 15
unless you plan on buying a locker and installing it before the run i would say just wait and look at Bob's set up and im not sure who else going has done it and then go from there but yea you can make one for way cheaper than 100 bucks
post #613 of 9541 Old 05-15-2009, 12:33 AM
connor0770
me and bob have it made (since we live so close)
post #614 of 9541 Old 05-15-2009, 12:34 AM
timatoe
timatoe's Avatar
I wouldn't pay $100 for one. Read this thread.... http://www.jeepforum.com/forum/f12/home-made-posi-lock-write-up-595515/
It's easy to do Bob and I both run a home made setup.
As far as the commute goes, I'm still down for camping Monday night if anyone else is interested. I would just figure a few beers, some grillin, then off in the morning.
post #615 of 9541 Old 05-15-2009, 12:37 AM
Goobersbro
so i gps'd it both ways and 50 is a little bit longer but according to time its the exact same rather i take 49 or 50 but 49 is a bit curvy same as 193
Old Florida Road RubiExpressTJ Vermont Jeep Forum 219 11-04-2013 12:09 PM
Possible Road closure in NH Schwalby North East USA 15 03-25-2009 06:53 AM
Road Trip! ClarkGriswold South East USA 18 02-04-2009 08:18 PM
New to Off Road Vethial South Central USA 1 10-24-2008 10:07 PM
Mass Off Road Circusfreaky North East USA 2 10-22-2007 07:22 AM
