Workout Basics/FAQ - JeepForum.com
post #1 of 28 Old 03-06-2013, 04:14 PM Thread Starter
BamaJeepman21
Workout Basics/FAQ
FAQ
Do I need supplements to gain muscle? Not at all. Don't feed into all the adds telling you you need 7 different supplements to gain muscle. Do they help? Certaintly. IMO there are only 3 kinds of supplements you should be taking. 1st is a good protien. Either a gainer or a lean whey high in protein will help build and repair your muscles after a workout. 2nd is a pre workout. I recommend taking a pre workout after spending a couple months in the gym to see how you do. If you feel you need the extra energy to push through your workouts, a pre workout will aid with that. 3rd is creatine monohydrate. There is alot to be said about that below. You can also throw in a multivitamin or fish oil to help with your bodies mineral balance.
Creatine
Is creatine a steriod? No. Do NOT believe anybody that tries to tell you this. Creatine is simply a natural substance created by the body to aid with energy.
Will creatine make me stronger? Potientally it can. Basically creatine works by drawing water into your muscles and keeping them hydrated. That will give a small strength gain since your muscles aren't dehydrated and more prone to failure.
How should I take creatine? To get your muscles saturated with it, it's often advised to load on it by taking up to 25g a day for a week. After the loading phase you should take 5g (teaspoon) a day. IMO the loading phase is unnecessary and saturation is easily achived by taking 5g a day for two weeks. Creatine will make you thirsty so drinking lots of water is a must!
Nutrition
Nutrition is often one of the most overlooked aspects of fitness. Most people think they can go get yoked in the gym and then hit up McDonalds for 5 BigMacs with no negative consequences. Technically, you could but it wouldn’t achieve the best results. You first need to determine your nutrition program. There are two styles of basic nutrition plans.
Finding your maintanence calories
Bulking
A bulk is generally regarded as a daily surplus of 250 calories. People new to weightlifting or wanting to gain mass need to bulk. Bulking can be split into 2 categories, a “clean bulk” or a “dirty bulk”. A clean bulk is a caloric surplus of up to around 800 calories. A dirty bulk is anything above 800. To support lean muscle gain with minimal fat gains, a clean bulk is the best idea. When you first start working out, you will notice "noob" gains almost immediatly. After awhile you'll see the gains slow down. This is when you've reached a plataue. Don't get discouraged since you aren't seeing immediate results. Just power through it and eat more.
Food sources for a bulk can usually be just about anything. I prefer to eat a normal days worth of food but at the end of my workout, drink some sort of protein shake. Protein shakes can be expensive so there are multiple alternatives of homemade ones.
Cutting
Once you’ve met your bulking needs and gotten to the size you want, now is the time to cut and show off all that hard work. With a cut you want to have a calorie deficit of -200 calories. You don’t want to do much more than that to minimize lean muscle loss. Remember, a cut takes time and patience. You do not want to try and crash cut in 3 weeks. That would be devastating to strength. Cardio is also very beneficial to a cut. It will help with losing calories and toning up your body depending on exercise. When cutting, you want to aim for around 12% body fat or less. With that lean of a body, you can definitely show off those muscles.
Food sources for a cut should be carefully considered. You can go about a normal day, just minimize your meals and try to exclude fatty foods. You also need to increase protein intake to help minimize lean muscle loss.
The bottom line: Before you start a bulk/cut you first need to find your maintenance calories. That is the amount of calories it takes to maintain your current weight. I personally use this calculator http://www.calorieking.com/interacti...es-calculator/
In the gym
What are some common exercises for new lifters?
The most common routines involve free weights. If you are brand new, never been in a gym before lifter, I recommend you use a couple of the machines around to get a feel of where you are strength wise.
Here are some that involve free weights:
Arms
BarbellCurls
Dumbbell curls
Hammer curls
Dips
Tricep press
Bent over extensions
Tricep pushdown
One arm tricep extension
Chest
The Bench
Dumbbell bench press
Cable flys
Dips
Incline bench press
Shoulders
Delt raises
Dumbbell raises
Dumbbell shoulder press
Arnold DB press
DB raise
Machine military press
Side DB raises
Back
The basic pull up
V bar pulldown
Cable lat pulldowns
Wide grip lat pulldown
Bent over rows
T bar row
The Deadlift
-Jack
BamaJeepman21 is offline
post #2 of 28 Old 03-06-2013, 04:16 PM
B52dude
Hopping on for the ride.
Originally Posted by Ripper3494 View Post
i think we should chase him around with yjs, its like being chased by zombies, slow, crippled but for some reason still scary as heck lol
Red Jeep Club #614
B52dude is offline
post #3 of 28 Old 03-06-2013, 04:50 PM
bhoch
Cool. Looking forward to the FAQ
bhoch is offline
post #4 of 28 Old 03-06-2013, 05:09 PM
tyvanwie
Let me know when you need help, Jack.
tyvanwie is offline
post #5 of 28 Old 03-06-2013, 06:36 PM Thread Starter
BamaJeepman21
Y'all can post up any info you have and I'll add it to the OP. I won't be back on a computer until 10.
-Jack
post #6 of 28 Old 03-06-2013, 06:46 PM
tyvanwie
I will work on it tomorrow. I have all day free.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #7 of 28 Old 03-06-2013, 09:35 PM Thread Starter
BamaJeepman21
Updated with info on supplements and creatine.
-Jack
post #8 of 28 Old 03-06-2013, 09:39 PM
tyvanwie
Looks pretty good so far
tyvanwie is offline
post #9 of 28 Old 03-08-2013, 12:31 PM Thread Starter
BamaJeepman21
ttt for more info. I'm getting some, it's just taking me awhile.
-Jack
post #10 of 28 Old 03-08-2013, 12:45 PM
tyvanwie
I'll help out this weekend
tyvanwie is offline
post #11 of 28 Old 03-22-2013, 09:48 AM Thread Starter
BamaJeepman21
Need to add moar.
Maybe...
"How long should I wait between exercises?"
"Is it good to workout twice a day?"
"How do I find my maintenence calories?"
"What are some common exercises for new lifters?"
-Jack
post #12 of 28 Old 03-22-2013, 09:49 AM
tyvanwie
"What muscles should I do on what days?"
tyvanwie is offline
post #13 of 28 Old 03-22-2013, 10:24 AM Thread Starter
BamaJeepman21
Added some workouts.
-Jack
post #14 of 28 Old 04-30-2013, 09:21 PM
HurricaneRZA
Exactly the sort of thread I was looking for... Thank you for making this
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #15 of 28 Old 04-30-2013, 09:27 PM Thread Starter
BamaJeepman21
Thanks for bumping it; I had kinda forgot about this thread. It needs to be a sticky so people can see it and post some useful info to add...
Eugene!
-Jack
