The Personal Best Thread - JeepForum.com
post #1 of 155 Old 05-30-2013, 10:36 PM Thread Starter
Black Hills TJ
Black Hills TJ's Avatar
Figured it'd be interesting and possibly motivating if we all shared our personal bests here. Post the lift, exercise, etc...and your one rep max or time!
Ready, set, go!
1 Mile Run: 7 minutes and 12 seconds
Flat Bench: 185 lbs
Squat: 300 lbs(finally joined the 300 club )
Originally Posted by Allenwr
My mouth still has funky taste in it, so I am doin alright.
Originally Posted by ImSuck
damnit i wish i could get bigger quicker
Check out
Black Hills TJ is offline
post #2 of 155 Old 06-01-2013, 10:50 PM
tyvanwie
Well hopefully the next time I do chest I'll join the 135 club
Sent from my iForum using JeepPhone
tyvanwie is offline
post #3 of 155 Old 06-02-2013, 08:39 AM
blubaru2002
Body weight 189.8 lbs
Bench press 365 lbs
Squat 415 lbs
Dead lift 445 lbs
Trying to cut down to 185 lbs. :-)
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #4 of 155 Old 06-02-2013, 10:23 PM
jeepyj13
Weighted around 180lbs doing the following:
flat/incline/decline bench press-315/265/315
squat-365lbs
deadlift-385lbs
Haven't lifted heavy in months these were my best numbers between last summer to beginning of this yr when I was lifting heavy.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #5 of 155 Old 06-05-2013, 01:40 AM
NYGLT56
Your Local Body Builder
NYGLT56's Avatar
Weight: 195
Bench: 350
Squat; 4something (don't remember)
Best dumbbell curl weight: 70 (2reps, and I'll admit I swong a little on the second rep)
My pt scores are what matter most to me.
2 mi: 12:13
Push ups (2min): 112
Sit-ups (2min): 89
2014 TJOTY Winner
A Daily Driven Lowrider TJ on 40s.
NYGLT56 is offline
post #6 of 155 Old 06-05-2013, 12:34 PM
REDLYNER
REDLYNER's Avatar
6'1" 187lbs
Bench: 335lbs
Bench: 225lbs for 20 reps
Squat: 315lbs (*** to heels)
Deadlift: 425lbs
Challenges or stupid bets completed:
Push Ups: 1001 in 90 minutes
300 Work Out: 18:00 minutes
1000lb club lift (bench 315lbs, squat 305lbs, deadlift 405lbs: back to back to back)
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #7 of 155 Old 06-05-2013, 12:40 PM
tyvanwie
You beast...yesterday, my second time deadlifting I got 155. Pretty happy about that. Also 185 on leg press.
Not nearly as impressive, but hey
DEM GAINZ
tyvanwie is offline
post #8 of 155 Old 06-05-2013, 12:52 PM
REDLYNER
REDLYNER's Avatar
DEM GAINZ
It's all relative, the guys I lift with warm up with my max some times . I had the gym owner work on my form and it added 40lbs to my deadlift. Same thing with squats... except it was the opposite . I used to "squat" like 335lbs, but after the gym owner laughed at me and my form, he corrected it and had me dropping below 90 degrees, which killed my max, but improved my growth.
REDLYNER is offline
post #9 of 155 Old 06-05-2013, 12:56 PM
tyvanwie
Yep. I started squatting a couple month ago in my weight training class. Then I watch some YouTube videos and realized I was being a ***** in my squats. Now I drop all the damn way down, sometimes hitting the bar on the rack. And I did RDLs in class, then added rack pulls a couple weeks ago to match my RDL. Now I can do a damn good one. Not perfect, but better than 99% of the people doing them in the gym here.
Saw a dude barely bending his knees when he was squatting 185. He was looking at me like I was a *****. I was so tempted to say "touch your *** to your heels and tell me how much weight you can do." Chicken ****...
tyvanwie is offline
post #10 of 155 Old 06-05-2013, 05:39 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Here's my all-time PRs
6'4" currently 238 pounds
Big 3:
Squat...1x405
Deadlift...1x525
Bench...1x315
Leg Press...3x1,543 pounds (32 plates + stated sled weight of 103 pounds)
DB Curl...3x85
not sure what else.
BTW, welcome to the section Jay. I was wondering if you were ever going to post in here!
2016 TJ of the Year
Founder, Offroad NC
Follow our journey:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
EugeneTheTJ is offline
post #11 of 155 Old 06-06-2013, 08:09 AM
stogie25
stogie25's Avatar
In 2006 my left biceps tendon came off the bone. I stopped lifting after the surgery until about a year and a half ago. I donít go as heavy as I used to, so I am giving my max weights for before and now.
All time max.
Weight 240lbs
Bench press 505x1
Dumbell curl 100x3
Squat 600x3
Max now.
Weight 215lbs
Bench press 405x1
Dumbell curl 80x3
Squat 405x5
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #12 of 155 Old 06-06-2013, 01:32 PM
jeepyj13
Originally Posted by stogie25
In 2006 my left biceps tendon came off the bone. I stopped lifting after the surgery until about a year and a half ago. I don’t go as heavy as I used to, so I am giving my max weights for before and now.
All time max.
Weight 240lbs
Bench press 505x1
Dumbell curl 100x3
Squat 600x3
Max now.
Weight 215lbs
Bench press 405x1
Dumbell curl 80x3
Squat 405x5
Gosh dang man you beasting. Even after your injury your still putting up good numbers.
jeepyj13 is offline
post #13 of 155 Old 06-06-2013, 09:59 PM
BamaJeepman21
5' 11" 170lbs
Bench: 185lbs
Leg press: 528lbs
DB press: 60lbs for 6
Really need to do squats and DL's.
-Jack
BamaJeepman21 is offline
post #14 of 155 Old 06-07-2013, 09:34 AM
blubaru2002
Originally Posted by BamaJeepman21
5' 11" 170lbs
Bench: 185lbs
Leg press: 528lbs
Squatting and dead lifts make everything stronger.
I regret not starting these exercises sooner. Once you nail the technique, they'll be your favorite exercises. :-)
post #15 of 155 Old 06-07-2013, 09:35 AM
tyvanwie
I can vouch for this
tyvanwie is offline
