Chest Workouts - JeepForum.com
post #1 of 32 Old 02-20-2013, 07:47 AM Thread Starter
Black Hills TJ
Black Hills TJ's Avatar
Chest Workouts
What are the gym rats of JF doing for chest workouts? I am just getting back into the gym, so I am a bit of a noob I suppose. Im trying a few different workouts to see what I likr best. I did chest last night as follows.
Ran a mile to get my heart rate up.
Dumbell press:
Two light sets of ten for warm up
Then kind of a pyramid...10, 10, 8, 8, 6 increasing weight as I go.
Down to medium weight for five sets of ten.
Inclined bench(bar)
Five sets of ten increasing weight for each set
Machine fly/pushup supersets burnout
5 sets of 12
Thanks for the help guys.
Originally Posted by Allenwr
My mouth still has funky taste in it, so I am doin alright.
Originally Posted by ImSuck
damnit i wish i could get bigger quicker
Check out
Black Hills TJ is offline
post #2 of 32 Old 02-20-2013, 08:57 AM
Andywear
Beer me?
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #3 of 32 Old 02-20-2013, 01:15 PM
curbcrawler
1946 CJ2A
The flat bench press is still king. Go heavy with a spotter 4 sets of 6-8 reps. I get good results from the dumb bell press as well because allows me to lower the weight even further. Incline dumb bell presses are a good to include to round things off. What ever you do, EAT. Diet is easily as important as the work out. This cannot be over emphasized. I know guys that work out like mad men and can lift heavy but never really gain size because their diet is lacking. Nutrition is huge and should not be ignored.
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. - Benjamin Franklin
-commit2013-
curbcrawler is offline
post #4 of 32 Old 02-20-2013, 01:21 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Try reverse grip on a flat bench to really get full recruitment of your upper chest.
A hex press is also good to target your inner pecs.
Mix up your presses and flyes every few weeks.
I usually end it on the pec deck. 4-5 sets increasing weight to super heavy still high rep. Then on the last set do a drop set taking your pecs past failure.
Remember: train harder, you'll pass out before you die.
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #5 of 32 Old 02-20-2013, 03:32 PM
curbcrawler
1946 CJ2A
excellent idea on the reverse grip. I gotta rotate this in on my next chest day.
-commit2013-
post #6 of 32 Old 02-20-2013, 03:56 PM
Indy
Indy's Avatar
Flat bench is always one of my favorites, cable fly's I like for a finishing exercise. I'm a big fan of reverse grip as well, but I'd recommend waiting until you've been in the gym a while longer. They work really well to bust through stagnant periods and can really crank on a well used chest. But they're also easy to do wrong and hurt yourself, not a newbie friendly exercise imo.
I've never been a fan of pyramids or anything like that, I just like to lift and I like going heavy. My usual workup is the 2 week 3 set complete. That is whatever your working weight is stays where it is until you can do 3 full sets 2 weeks in a row. If you end up failing on the last rep on the 2nd week, you start over again the next. And when you do fail immediately strip 10 off each side and try to finish the set. If you fail again, strip another 10. In any event you always finish the sets and your chest will be screaming by the end.
Once you can go 3 full sets (8 or 10 reps your choice) for 2 weeks running, add 10lbs to each side and start again. That 20 pounds will affect you a lot more than you think it will.
I use that method and have for years, it keeps things moving forward without going stagnant. At me peak I ended doing full sets at over 300lbs. Not bad for a 160lb guy. I determined this was about the max my structure could do without causing some joint/bone issues.
I'm the only gay eskimo.
Indy is offline
post #7 of 32 Old 02-20-2013, 03:59 PM
nwiTJdave
Push ups.
This is for fighting, this is for fun.
nwiTJdave is offline
post #8 of 32 Old 02-20-2013, 04:00 PM
Indy
Indy's Avatar
As a side note, when you're working do the work. Don't be one of those *******es that has a 10,000lb max, but only moves the bar 1/4" and counts it. As a gym guy I'd rather see you do good reps at 100lbs than see you being a tard at 500lbs. Ego doesn't help you get weight off your chest, suck it up and work to the big weights.
Indy is offline
post #9 of 32 Old 02-20-2013, 05:03 PM
EugeneTheTJ
Tar Heel
This! Also when you are benching your *** shouldnt be 15" off of the bench. I dont care if you have a pucker factor of 10 but keep your *** and back on the ****ing bench
2016 TJ of the Year
Founder,
post #10 of 32 Old 02-20-2013, 05:27 PM
EugeneTheTJ
Tar Heel
Just start lighter than you think. The grip takes some getting used to before you can go heavy.
2016 TJ of the Year
Founder,
post #11 of 32 Old 02-20-2013, 06:56 PM
jeepyj13
I do all 3 benches starting with flat. Warm up with 135lbs. Then I do a set of 225lbs, go up to 245lbs, then a set dedicated to a heavy weight. I then drop set. I do decline nxt starting with 225lbs and go up on weight doing less reps. Then I do incline with the same principle. Then I get some flys in usually 4 sets with either cables or dumbells. The workout works for me.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #12 of 32 Old 02-20-2013, 06:58 PM
EugeneTheTJ
Tar Heel
Bar only or throw in dumbbells?
2016 TJ of the Year
Founder,
post #13 of 32 Old 02-20-2013, 07:15 PM
jeepyj13
I alternate. One day it will be just barbell another day I throw dumbells into workout esp. on incline. There will be days I just do 4sets of dumbell incline. I do dumbell declines on some workout sessions and wont do a barbell bench. It works for me.
jeepyj13 is offline
post #14 of 32 Old 02-20-2013, 07:17 PM
EugeneTheTJ
Tar Heel
Yea I like to do dumbbell on incline and flat bench after I use a bar.
Really gets deep in the outer chest and takes the whole pec to failure.
2016 TJ of the Year
Founder,
post #15 of 32 Old 02-20-2013, 07:48 PM
jeepyj13
I agree. I mainly do dumbell incline also because I have bad shoulders as well. I have hypermobile shoulders which from what i read tends to be more prone to injury.
jeepyj13 is offline
