BHTJ's Mission to Get Fit - JeepForum.com
Go Back JeepForum.com > General > Fitness and Nutrition > BHTJ's Mission to Get Fit
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 05-06-2013, 10:45 PM   #1
Black Hills TJ
Little bit about me...I'm 23. I've always been pretty athletic. Played soccer and baseball through highschool. Little bit of soccer into college. Now that I'm out of college, I've found myself playing ice or roller hockey once a week.
I'm currently 5'8" and ~155...looking to trim some fat and gain some muscle. I've thrown some workouts that I do below, and some "stats" so to speak on some of the big lifts.
I don't want to get huge, but I do want to bulk a bit and work on my physique. Hopefully you guys can push me to get some. I take criticism well. Feel free to hack on my workouts, make suggestions, etc. Also, I'm not currently taking any supplements. I did just cut out fast food, alcohol, and soda. Working on eating 5 meals a day. Lots of chicken breast, rice, and steak
Bench: 135x10(est. 1rm=180)
Squat: 265x1
Dead: 200x10(est. 1rm=270)
Mile: 7 minutes and some change
Notes: Before every workout(except cardio) I run 1.5 miles. Every day is ab day(inclined situps, leg raises every day). Currently doing the 100 pushups, 200 situps, and 250 squats programs(droid apps)
Workouts
Back Day
Warm Up: 3x10 Pullups, 2x10 Deadlifts
Work: 5x10 Deadlifts, 10x10 Pullups
*My back is weaker than ****, so, yes, I do pullups on a machine for assistance.
Chest Day
Dumbell Bench
Warmup 2x10(light)
Work 2x10, 2x8, 1x6(heavy), 5x10(mid weight)
Incline Bench 5x10
Machine Flies 5x12
Squat Day
2x10
1x5
5x5
Final Set to burnout
Single Leg Squats-5x10
Bi's and Tri's Day
Machine Curls 5x12
Cable Tricept Extensions 5x12
Standing Bar Curls 5x12
Skullcrushers 5x12
Standing Dumbell Curls 5x12
Dips 3x12
Cardio Day
5 mile run
Originally Posted by Allenwr
My mouth still has funky taste in it, so I am doin alright.
Originally Posted by ImSuck
damnit i wish i could get bigger quicker
Check out www.blackhillsjeeps.com!
Black Hills TJ is offline   Reply With Quote Quick reply to this message
Unread 05-07-2013, 06:37 AM   #2
BamaJeepman21
Looks pretty good. Might want to add some rows for back like bent over rows, tbar rows...etc. Your bi's/tri's day looks pretty intense. Is it a fast paced style work day?
-Jack
BamaJeepman21 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2013, 08:40 AM   #3
blubaru2002
You're running prior to lifting is a great way to burn calories. But it is most likely tiring you out before your lifts. You may be able to go heavier with a light warm up and not running over a mile.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2013, 09:19 AM   #4
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Looks like you have a good start but here are some critiques/advice:
1) Don't run before workouts. If you want to continue running on lifting days do it either (i) first thing in the morning or (ii) after you lift. It burns more FAT (not calories, fat) and will help you tone up more.
2) Every day should not be ab day. Do it at the most every other day.
3) On back day, I would add in more lat exercises. Rows, pulldowns, etc.
4) You need to do more than just squats for legs. Add in hammies and calf routines.
5) Not working your shoulders is a HUGE mistake. Throwing in delt exercises will not only help your overall strength (especially with chest/back) but it will also give you nice broad shoulders and a slimming taper.
I'm not sure how much you have lifted before but if you are relatively new to it you will get noob gains and slim down. However, this will not last long. It is damn close to impossible to cut and bulk at the same time. I would focus on bulking for a month or two then get strict with cutting.
Good job on the diet by the way. It seems like you've got the fundamentals down but I would recommend tracking your food to have a better understanding of the quantity you eat.
Hope that helps!
EugeneTheTJ is offline   Reply With Quote Quick reply to this message
Unread 05-07-2013, 11:27 AM   #5
jeepyj13
Squat: 265x1
Workouts
Back Day
Chest Day
Dumbell Bench
Warmup 2x10(light)
Incline Bench 5x10
Machine Flies 5x12
Squat Day
2x10
1x5
5x5
Bi's and Tri's Day
Machine Curls 5x12
Skullcrushers 5x12
Dips 3x12
Cardio Day
5 mile run
You off to a good start. I agree with Eugene you have to add shoulders in there. Their essential to upper body strength esp. On chest day. Make sure you target all parts of shoulder(anterior delt, medial delt, posterior delt). Target the medial delt by doing military presses with dumbells, with some lateral raises, for front delt(anterior) upright rows will do. You can do them with dumbells, ez curl bar, or barbell. For posterior(rear delt) there's not many exercises that can be done to build them but different variations. I always do reverse pec deck or bent over reverse flys.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2013, 03:15 PM   #6
Black Hills TJ
I try to go 30-60 seconds rest between sets and no more. I'm sweating balls by the time I am done every day.
Unread 05-07-2013, 03:19 PM   #7
Black Hills TJ
Thanks for the heads up on running, guys. I will bump it to the end of my workout for a good cool down.
I don't hit abs hard every day. I try to work a different section each day(upper, lower, obliques)
Someone else also mentioned it...I'll throw in some bent over rows on back day.
Do you have some suggestions here?
Again, suggestions on lifts, and which day should I tack shoulders onto(back maybe?)
Thanks for all the help!
Unread 05-07-2013, 03:21 PM   #8
Black Hills TJ
Thanks for the suggestions! I can definitely throw some of that in. Is there a particular day that it would be best to mix them in with?
Unread 05-07-2013, 03:30 PM   #9
EugeneTheTJ
Tar Heel
I would just drop your cardio only day and do shoulders then. I like doing them at the end of my week because they're used in almost every training session and I don't want them to be over fatigued when I'm doing other stuff.
As for hammies/calves: lying leg curls, romanian deadlifts, calf raises, etc. A quick google search should help. Also check out the Workout Video thread for some ideas.
Unread 05-07-2013, 03:42 PM   #10
Black Hills TJ
What do you think of Furious Pete's Shoulder workout? How many reps per set...10? His video doesn't say how many reps he does for eachs et.
Warm-up - Smith machine partial press - 5 sets
Strict Shoulder Press - 4 sets
Push Press - 3 sets
Dumbbell Press - 4 sets
Side Lateral Raises - 3 sets
Dumbbell Shrugs - 4 sets
Plate Front Raise - 3 sets
Unread 05-07-2013, 05:44 PM   #11
BamaJeepman21
Are you working out to tone? That's almost no time to recover. I usually take ~2-3min breaks between everything. I also usually work out with 3 people everyday so that gives me plenty of time to recover and go do another set. I do lift heavy everyday so more rest is required.
-Jack
Unread 05-07-2013, 06:23 PM   #12
Black Hills TJ
Tone up, and a little muscle on the way won't hurt. I feel that if I rest longer, I lose the pump in the muscles that I'm trying to work. Generally, I increase the weight each set I do so that by the time I get to the last rep on the last set, I seriously have to work for it.
Unread 05-07-2013, 06:30 PM   #13
Black Hills TJ
So here's my workout for today
Casual half mile run for a warm up
Dumb bell press 15# dumb bells 2x10, 25# 1x10, 30# 1x10, 40# 1x10, 45# 1x10, 30# 5x10
Inclined bench 65# 1x10, 85# 1x10, 95# 1x10, 105# 1x10, 115@ 1x10
Machine Flies(no rest between sets) 20# 1x12, 30# 1x12, 40# 1x12, 50# 1x12, 60# 1x12...hold that last rep until muscle failure
One mile run/cooldown
My pecs hurt :/
Unread 05-07-2013, 07:51 PM   #14
Black Hills TJ
Grilled chicken breast, black beans, and rice for dinner.
Unread 05-28-2013, 10:11 PM   #15
Black Hills TJ
I've put on a few lbs(165 on a heavy day), and I've noticed some strength gains. Part of me wants to start cutting to see what's hiding underneath, but the other part of me wants to keep bulking to see bigger gains after my cut.
