Attn: Gym Rats - Squats - JeepForum.com
post #1 of 39 Old 02-08-2013, 10:35 PM Thread Starter
Black Hills TJ
Black Hills TJ's Avatar
In terms of % body weight...what's considered a strong/healthy squat?
I'm 155-160 lbs. I haven't really lifted heavy lately, and I wanted to find my 1 rep max after a new squat workout today. Here's how it broke down...30 seconds or less between sets.
10 @ 95lbs
10 @ 115lbs
5 @ 135 lbs
5 x 5 @ 155 lbs
then I started bumping weight until I couldn't push it anymore
1 @ 185 lbs
1 @ 205 lbs
1 @ 225 lbs
1 @ 245 lbs
1 @ 255 lbs
I gave 265 a shot, but couldn't pull it off. After today I know that I can increase my warm up and workload up by quite a bit. I may have been able to pull of 265 with fresh legs, but couldn't make it happen today.
total weight lifted=7,765 pounds
Originally Posted by Allenwr
My mouth still has funky taste in it, so I am doin alright.
Originally Posted by ImSuck
damnit i wish i could get bigger quicker
Check out
Black Hills TJ is offline
post #2 of 39 Old 02-09-2013, 12:35 AM
SnowYJ
1988 MJ Comanche
255 is a solid squat for your weight. Just make sure you're form is on point and keep putting weight on the bar
I go to college and I drive a Jeep.
SnowYJ is offline
post #3 of 39 Old 02-09-2013, 06:52 AM
bigred33
You're wasting reps on the lower weight and smaller bump ups. Circuit style leg w/o isn't the way to go if you want to try to max out, definitely take some rest in between.
bigred33 is offline
post #4 of 39 Old 02-09-2013, 08:31 AM Thread Starter
Black Hills TJ
Thanks, like I said. I wasn't sure of my ORM, and didn't want to push it until after the workout that I was trying. Now I know that I should have done that workout with quite a bit more weight on the bar.
Check out
post #5 of 39 Old 02-09-2013, 08:52 AM
moses21
Are you doing the full squats? I remember that people in my high school football team could squat over 400 pounds, but when you saw them squat you could tell they were doing nothing right.
moses21 is offline
post #6 of 39 Old 02-09-2013, 09:24 AM Thread Starter
Black Hills TJ
Secret to gains on your squats is going deep! If I'm not going deep enough, I'll drop down weight and work on my flexibility. I'm just starting to push towards really lifting heavy. So if nothing else, at least I have good technique right off the bat.
Check out
post #7 of 39 Old 02-09-2013, 10:16 AM
jeepyj13
I haven't max on squats in forever. Yeah important thing on most compound legs workouts squats, deadlift, etc is form. When the weight gets heavy the stress on lower back increases. One bad move that back is gone. I already injured my lower back many yrs ago doing deadlifts. When I maxxed on squat I warmed up with 135 prob two sets. Bump it to 225 for two sets, then 315lbs for 1 rep, and then I put the real deal on it and go for it. Idk if my techinque leading to a max is correct, but I don't want to tire my legs out before hitting the heavy stuff. 255lbs is not bad for your weight, at least your squating and doing legs period. You'll be amazed on how many people do not do legs at all.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #8 of 39 Old 02-09-2013, 10:21 AM Thread Starter
Black Hills TJ
Now that I know I'm sitting around 255 for my max, I really want to push for 315. That'd be damn close to 200% of my body weight.
As far as doing squats, I always suggest squats to everyone. If I could only do one lift, I'd do squats. I should probably say cleans as my one lift, but I hate those damn things.
Check out
post #9 of 39 Old 02-09-2013, 10:24 AM
jeepyj13
I nvr attempted cleans, I need to though. I never rule out squats on legs I also never rule out the deadlift too.
jeepyj13 is offline
post #10 of 39 Old 03-20-2013, 06:48 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Pulled off 405 today.
I think I can do more but I did that after leg pressing 1,200 pounds so I was pretty damn tired.
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #11 of 39 Old 03-20-2013, 07:39 PM
jeepyj13
Good job. The most I ever squat was 365. I would like to cross the 400 club, but recently messed my right knee up and I prob won't be able to pull it off
jeepyj13 is offline
post #12 of 39 Old 03-20-2013, 07:59 PM
EugeneTheTJ
Tar Heel
Just give it time to recover properly and you'll be back at it before you know it!
2016 TJ of the Year
Founder,
post #13 of 39 Old 03-23-2013, 04:04 PM
TheBlueKJ
2003 KJ Liberty
405 is pretty darn impressive. I've never maxed on squats since I'm just starting to go into the heavy weight (my knees were troubling me so I took it easy for a while). I just keep adding on weight every week to slowly build up. Last leg day I was at 275 for 8 reps. I also weigh 168-170 lbs
Blue 2003 Jeep Liberty Sport 4x4 Lifted, Front OME 790s/Bilstien, Custom Rear; 245/75/16 A/Ts KC Daylighters
thread)
TheBlueKJ is offline
post #14 of 39 Old 04-04-2013, 03:22 PM
streetpro
1978 CJ7
Looks like you're doing well so far. Remember as you add weight make sure to pay attention to form, knee stability (hamstring strength/tension) lower leg and ab strength.Hip mobility/flexibility will go a long way to helping you squat pain free as well.
streetpro is offline
post #15 of 39 Old 04-04-2013, 05:16 PM
BamaJeepman21
I started out squatting on the Smith machine. That's an easy way to get some weight in AND get perfect form.
-Jack
BamaJeepman21 is offline
