7 week lifting comparison. - JeepForum.com
Go Back JeepForum.com > General > Fitness and Nutrition > 7 week lifting comparison.
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail TJ, YJ and CJ A/T Fender Flares available @ Oconee Off-Roa*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*
Unread 06-18-2014, 11:07 AM   #1
Jetscuh
O rly?
Jetscuh's Avatar
2012
Bench press: 110lbs (5 reps)
DB press: 90lbs (5 reps)
Incline: 80lbs (5 reps)
Squat: 135lbs (5 reps)
Dead lift: 110 (5 reps)
Leg press: 375 lbs
Curling: 50lb easy curl bar inside grip.
40lb for outer.
20 dumbell for cross body curl and incline.
80lb shoulder press.
All of these are 5 reps. There are more I probably forgot about.
I need to up my dead lift but I just started those not too long ago and am watching my form, same with the squats.
So, I will leave this here and in 7 weeks compare my numbers. I may do a half way check in.
I've been running as well.
I'm also a female, so no laughing at my wimpy numbers
I like seeing others progress and I'd like to just leave this here so I can come back and see if I make more gains.
I've shifted over to a new lifting regimen.
Jetscuh is offline   Reply With Quote
Unread 06-18-2014, 04:15 PM   #2
AKABOB
Incredibly Handsome
AKABOB's Avatar
1989 FSJ Wagoneer
I am pretty impressed with your whimpy numbers. I thought you were a "fragile" girl.
Originally Posted by John Popper;
Sitting in clover looking for the fifth leaf. Something soon will come my way.
AKABOB is offline   Reply With Quote
Unread 06-18-2014, 04:34 PM   #3
Jetscuh
O rly?
Jetscuh's Avatar
2012
Haha, no. I've been into picking things up and putting them down for a little while.
Unread 06-22-2014, 10:35 AM   #4
BamaJeepman21
When I first saw DB press
But then I realized that you meant the total and not the size dumbbell you're using.
Atleast I think you do...
I want your used D30/D35 chromo shafts!
-Jack
BamaJeepman21 is offline   Reply With Quote
Unread 06-22-2014, 12:46 PM   #5
Jetscuh
O rly?
Jetscuh's Avatar
2012
It's 90 lbs total. Not 95. I'll fix that.
I just finished week 1 of Arnold Schwarzenegger's Blue print program and holy ****! I like it a lot and it's a good change up for me. Hopefully I'll see some gainzz. Buy srsly, if this workout doesn't give you gains I don't know what will.
Unread 06-24-2014, 06:46 AM   #6
tyvanwie
For help on your deadlift, if you need it, check out elliott hulse on YouTube (strengthcamp). He's a master at what he does. Watching his videos and techniques really helped my deadlift.
Your numbers are impressive.
MY BUILD THREAD
MY FITNESS LOG/TRANSFORMATION
JK AND TJ PARTS FOR SALE
I'm pretty sure I know what I'm talking about. I think...
tyvanwie is offline   Reply With Quote
Unread 06-24-2014, 10:29 AM   #7
Jetscuh
O rly?
Jetscuh's Avatar
2012
Thanks! I've been watching and reading a lot in general. I have it down good now and have already increased weight.
Unread 07-05-2014, 05:03 PM   #8
Jetscuh
O rly?
Jetscuh's Avatar
2012
Well, my deadlift has increased to 130lbs.
I have some occasional clicking, minor heat, swelling, and pain in my knee. I haven't been able to do any serious squats.
It doesn't bother me when I run, or do the rest of my leg workout really.
Unread 07-05-2014, 06:29 PM   #9
blubaru2002
Originally Posted by Jetscuh
Well, my deadlift has increased to 130lbs. I have some occasional clicking, minor heat, swelling, and pain in my knee. I haven't been able to do any serious squats. It doesn't bother me when I run, or do the rest of my leg workout really.
Pop an NSAID and ice that knee. Maybe also invest in some knee sleeves.
Also maybe your form on squats could improve? No insult intended.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline   Reply With Quote
Unread 07-05-2014, 06:45 PM   #10
Jetscuh
O rly?
Jetscuh's Avatar
2012
I have a sleeve I used to wear. I've been trying to find it. May get a new one.
My form is good. I've been really strict on that (why I wasn't worried about weight at first) and have some solid workout partners/helpful input. Going to go easy on the knee for a bit and see what happens.
