ZJ - Rear Shocks Replacement Write up (18 Pics) - JeepForum.com
post #1 of 14 Old 04-20-2005, 05:52 PM Thread Starter
Ruffy
Well here we go. I bought some shocks many moons ago. They were cheap and sucky but hey i'm poor. After about 3 weeks they started leaking, So I went back to Advanced Auto and they gave me a new set. Sorry I dont have a Front shock replacement writeup yet as I've only changed them once. On to the Guide.
Difficulty Level : 2
Tools NEEDED :
- 1 Lug Wrench : Standard one that came with the jeep, 4 way, 1 way, Doesnt matter. DO NOT USE A IMPACT WRENCH
- 3/4" Wrench or Ratchet + 3/4" Nut
- 5/8" Wrench or Rachet + 5/8" Nut
- Knife, Scissors or wire snips to remove the Shocks plastic hold down clip.
- 2 Ton or Greater Jack. Bottle or Floor. Floor is easier to work with.
Additional Recomended Tools :
- 2 Ton or Greater Jack Stands. One stand is fine. Two is better.
- Can of PBlaster.
- 3/4" Extra Long Wrench
- 5/8" Extra Long Wrench
- Large Rachet with 3/4" Nut and 5/8". Rachet handle should be over 8 inches.
- Torque Wrench.
The first time I did the rear I didnt have the additional/replacement tools. Second time I did it, it turned into a 20 minute job. Not counting all the pictures I took.
On to the Pics.
First Stage of tools. Things being laid out
Removing the lug nuts. DO NOT REMOVE THE WHEEL. Common newb mistake is to jack up the car then trying to remove the lug nuts
Jack up the rear. Place jack stands on the axel tube or proper mount points. I tend use both jack stands whenever im lifting one side, Just to be "safe"
The first bolt. 3/4" Large wrench on one side. 5/8" Nut on other. You can do what I do first and use two large wrenches to break the nut loose. then move onto the ratchet to make quick work of it. Soak in PBlaster if needed.
Bolt Out
A Gander at the second one, Only the nut needs to be removed
Oversized 3/4" Wrench action. Your ratchet may or may not fit, The Wrench has better leverage.
Nut removed.
New Shock, The white clip holds the shock in a compressed state. once you cut it, it expands slowly.
Ruffy is offline
post #2 of 14 Old 04-20-2005, 05:53 PM Thread Starter
Ruffy
Place the Shock on the top part first. Go ahead and hand thread the nut on.
Aim the bottom of the shock towards the bottom mount and.....
Clip the White harness, Guide the shock home. Dont be afraid of it
Dont just let the shock expand all the way, be ready to push the bolt through. if the shock goes too far you'll have to hand compress it alittle to get the bolt in.
Get rid of the harness
Tighten Up all nuts. Torque to spec.
Remount the wheel. Add lugnuts, tighten them by hand. Check for any play in the wheel. Dont rush through this part.
After this all thats left is to lower the jeep. and Torque the wheels to proper specs.
Hope you Enjoyed My Write-Up. I have about 60 other pictures not posted. most are repeats.
1993 Grand Cherokee Laredo - White - 236k Miles
4.0L I6, Monroe GCY Shocks, BFG 235/75/R15 Tires
Ruffy is offline
post #3 of 14 Old 04-20-2005, 06:10 PM
PumaZJ
60 pictures on how to replace rear shocks?
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #4 of 14 Old 04-20-2005, 06:47 PM Thread Starter
Ruffy
i take alot of pictures. multiple angles, different ligthing. I have over 1200 pictures total for my jeep alone. and those are only the ones i've kept. I prob delete over 3/4" of all the shots I take.
Ruffy is offline
post #5 of 14 Old 04-20-2005, 08:45 PM
grandman97
grandman97's Avatar
nice write up... did u have a problem w/ the top mount or the rear shocks ?? mine dont fit on the sleeve that is on the bolt... i dont know what to do
grandman97 is offline
post #6 of 14 Old 04-21-2005, 04:40 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Great write up and pics.
Hint: Remove the wheelwell liner and you'll be able to see more.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 14 Old 04-21-2005, 07:44 AM
lambar
Thanks for the writeup. My ZJ needs new shocks, and this writeup will be a tremendous help. Keep em coming
Ron
1996 GC Limited 5.2L
2" Coil Spacer
30" General Grabbers
lambar is offline
post #8 of 14 Old 04-25-2005, 02:10 PM
BART CJ5
BART CJ5's Avatar
1979 CJ5
Is this for real???
'79 CJ5
4" lift, 4 corner DT3000's, 33x12.5R15 TSL on black steel 15x8's (2"b.s.), full cage, C.C. 4X4 3/16x2x4 rear frame, C.C. 4X4 S.R.S, stretched wheel base, C.C. 4X4 front and rear bash bumpers, work in progress.
BART CJ5 is offline
post #9 of 14 Old 05-19-2005, 09:15 PM
Jeep4x4nut
Jeep4x4nut's Avatar
ummm.....taking shocks off is routine for lifting any vehicle.....common sense..undo bolts.....then replace shock, put bolts on.....i did it in like 30 words and no pictures.....sorry for being mean
93 YJ | 2.5L | SOA |35 MT/Rs | 8.8/30 | 4.88s | Welded rear | Lockrite Front | Cage
95 ZJ for sale | 5.2L| F>R swap | 32 SSRs | 4.10s | Lockrite rear
Jeep4x4nut is offline
post #10 of 14 Old 12-07-2010, 11:12 AM
zj33
Old post, but I wanted to thank you for it. Just completed my rears in 15 degree weather.
zj33 is offline
post #11 of 14 Old 04-03-2012, 12:44 AM
Sandy97ZJ
Thanks for the post. Albeit it was almost 7 years ago, I'm disappointed at the people who boo-hooed you for posting this. I'd rather have too much information than too little. Yeah, replacing shocks might be simple for a lot of people, but if it helped even one person then it was worth it.
Sandy97ZJ is offline
post #12 of 14 Old 05-06-2013, 03:10 AM
chadcmb
I want to thank you as we'll.
chadcmb is offline
post #13 of 14 Old 05-27-2014, 08:07 PM
zappacat
Thanks from me as well. What's simple for some people isn't for others who haven't wrenched on their own stuff before. This is good information with nice pictures that was intended to help people. I commend you for doing it.
I put my pants on just like the rest of you - one leg at a time. Except, once my pants are on, I make gold records!
zappacat is offline
post #14 of 14 Old 06-20-2015, 06:11 AM
DjFlockaFlame
A thank you from me too. First car I've ever started repairing and restoring on my own, so having this much info helps a lot man. Thanks!
DjFlockaFlame is offline
AW4 Solenoid replacement..write up freemans97XJ Engines & Drivetrain 0 03-25-2009 06:31 PM
Write up for APN manifold install - w/pics atmos_sc Street Jeep Forum 24 05-07-2007 08:41 AM
Rear main seal replacement write-up ? TJ on the Rocks Engines & Drivetrain 1 08-03-2006 01:02 AM
NEW! Upgraded Headlight Harness Write-Up (w/pics)! C2U5H Audio, CB & Ham Radios, GPS, & Electrical 3 05-03-2006 12:20 PM
Rancho In-Cab Remote Write-up (lots of pics) KRAMONUT Fabrication Shop 10 04-12-2005 10:24 AM
