YJ Rockcrawler Front Bumper - JeepForum.com
post #1 of 10 Old 11-03-2012, 06:38 PM Thread Starter
Pawjob
So after a year of getting made fun of cause my front bumper looked like a muststash. And cause i keep getting hung up while making tight turns. I decided to build me a new bumper.
So the before pic.
So trip to the local steel shop.
3/16 8x36 plate
3/16 4x36 two of those
3/16 5x16
3/16 2x36
3/16 4x14
3/4 3x4.5
Total cost with getting the hole drilled for the shackle tabs $90
Shackle tabs
Used the large 8x36in plate for up top and used my harbor fright winch plate as a templet. I over hung the plate past the frame 2"
Made two tabs that bolt on to the lower bolt underneath and ran the 2x36 across it. Then welded the two 4x36 plates at a 90degree and lined it up with the top plate. This did over hang underneath.
Cut out light holes
Boxed them in and drilled a 3/4 hole for the wires.
Fab the fairlead plate and burned it in. I know my welds dont look good there but all will work out.
Worked a little magic with a flap disc and some paint.
Pawjob is offline
post #2 of 10 Old 11-04-2012, 07:15 AM
Photog2000
That is so much better!!!!! I like the mounting of the clevis tabs. Most people just cut them straight and weld them on flat where they can fail. Hope you welded everything on the inside as well since you ground off all the weld on the outside.
Photog2000 is offline
post #3 of 10 Old 11-04-2012, 07:27 AM Thread Starter
Pawjob
Hmmm well i did some welding inside lot alot. You made a good point that I over looked Ill take care of that asap.
Pawjob is offline
post #4 of 10 Old 01-19-2013, 10:04 PM
Carlos14
Definitely a fan of this!
Luck Favours The Prepared
Carlos14 is offline
post #5 of 10 Old 01-20-2013, 09:42 AM
'92 vegas YJ
Looks great
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #6 of 10 Old 01-20-2013, 10:12 PM
Unii
much better, stubby bumpers are always great looking
Unii is offline
post #7 of 10 Old 01-21-2013, 11:39 AM Thread Starter
Pawjob
Thanks, Im selling it too Carlos14 here in a couple months he will be stoked once he gets it put on.
1994 Grand Cherokee Daily Driver
7" IRO Long arm, 35" Cooper Discrover STT. And more
1993 Wrangler, Rock Smashing Jeep, and November 2012 YJOTM...
1.5" SOA, Stak 3 speed Tcase, 37" Swamper M16's...ALOTS of extras
Pawjob is offline
post #8 of 10 Old 01-21-2013, 12:24 PM
Carlos14
Most definitely! I just need to get a winch and some duallys now to dress it up!
Carlos14 is offline
post #9 of 10 Old 01-21-2013, 02:38 PM Thread Starter
Pawjob
Id hook you up but I got the warn 9.5ti brand new $500 I love it and cant part with it. And the lights are too good to give up.
Pawjob is offline
post #10 of 10 Old 01-21-2013, 06:45 PM
Carlos14
Hopefully I'll be able to scoop one up come tax time!
Carlos14 is offline
