YJ front bumper tips - JeepForum.com
post #1 of 7 Old 05-16-2012, 10:10 PM Thread Starter
zachsjeep
I recently found out the hard way that the stock bumper doesn't full protect your fender. The tree totally missed the bumber. Before I replace my fender, I plan on putting a DYI trapezoid front bumper on the width of my YJ. I'm looking for tips and advice for a tree proof(at crawl speed I know) front bumper. I plan on having spots for my D-rings and wonder if I should weld the post through the front to the back. I also wonder 4x2 or 5x3 and thinkness. Last is mounting ideas. If it is homemade(trape zoid or not) post pictures. Tips are most helpful. And yes I have scoured all week for info and if you know where helpfull threads are, post them to please.
zachsjeep is offline
post #2 of 7 Old 05-17-2012, 09:14 PM
allmopars
two words, "tube fender" fab them into brush guard
allmopars is offline
post #3 of 7 Old 05-24-2012, 11:25 AM
04WJny
1987 YJ Wrangler
if your using any steel plate, make that part out of cardboard first just so you see how it fits and looks.
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #4 of 7 Old 05-24-2012, 12:11 PM
timatoe
timatoe's Avatar
I would and did weld the recovery points front and rear. Here's mine, pretty basic and not nearly as wide as you're talking about, but I made it shorter cause I just don't like the look way out to the side.
timatoe is offline
post #5 of 7 Old 05-24-2012, 09:05 PM Thread Starter
zachsjeep
Is that square tube or bent/welded sheet metal? If tube how did you take the mounting brackets?
post #6 of 7 Old 05-24-2012, 10:26 PM
timatoe
timatoe's Avatar
It's 2x4 rectangle tubing. I used some 2" wide 1/4" flat bar for the mounts and welded them top and bottom then ground the top smooth. Because the frame is basically the same size, the top fit's fine but the bottom needed a little extra space to fit, so I cut about a 2 1/2 in long piece and then put it between the bottom of the bumper and the mounting strap then welded it all in place.
timatoe is offline
post #7 of 7 Old 10-06-2012, 10:26 AM
wickedoffroad
1987 YJ Wrangler
Quick tip. Use your stock bumper to make the mounting brackets. It is already the perfect size to slide over the frame....plus you already own it so no out of pocket expenses.
wickedoffroad is offline
front bumper , homemade , jeep yj
looking for advice and tips on bumper building... transmaro93 Fabrication Shop 2 10-05-2011 07:25 PM
TJ Front bumper TreverTJ Fabrication Shop 52 06-25-2011 12:13 AM
Does anybody have design plans for an XJ front bumper or rear bumper RescuedJK Fabrication Shop 1 03-15-2010 05:58 PM
Front TJ bumper UTmike Cheap Tricks & Fixes 6 07-05-2006 12:54 PM
94 ZJ homemade rocker guards, front bumper, rear bumper? haywood Fabrication Shop 1 12-17-2004 04:11 PM
