YJ Front Bumper Build - JeepForum.com
post #1 of 3 Old 07-28-2017, 07:36 PM Thread Starter
jcourt667
I thought I'd share my front bumper build. I had some 10 gauge steel from electrical cabinets I've been saving. Perfect for a bumper fab or whatever. I wanted a bumper somewhere in between a shorty and full fender coverage. I plan to get some tube fenders in the future, so a full coverage bumper just looks too long IMO. I also wanted to get a winch mount(no winch yet) mounted. For the winch mount I went with the Harbor Freight universal mount. It was $38 with a coupon, cant beat it. 1/4 inch steel already bent with a fairing mount. I comes with some extra holes but the unused holes can be filled in.
Since this is 10 gauge steel, I knew the bumper wouldn’t be totally a functional rock crawling, hang the Jeep upside down from it, but more of a cosmetic bumper. If I bend this one up, I’ll reuse the cardboard template and make it out of ¼ inch.
I started with some cardboard to get a template.
I wanted some coverage under the bumper.
Final Template:
Here’s the winch plate from Harbor Freight, $38. Not bad.
Start cutting, welding and grinding. Lots of grinding:
Here’s the inside. Again, not too much function here, but solid when mounted:
Fully welded and mounted. I wanted to use the hooks instead of trying to figure out how to get D rings anchored to the frame. So, I cut the front corners off the winch plate so the hooks could be mounted flush on the top of the frame(no spacers).
“Go Prepared” No Warn winch yet(soon!)
94 Sahara YJ 4.0L HO. 255k miles! Been down for 8 years, time to get this out of the barn!
jcourt667 is offline
post #2 of 3 Old 07-28-2017, 07:41 PM Thread Starter
jcourt667
Fully primed and painted with rattle can Rustoleum:
One thing about Jeeps is, the fab doesn’t have to be perfect down to a mirror finish paint job. Blemishes and grind marks are there, but it’s a Jeep. The project went well, took a couple a weekends to accomplish. The goal: I’m on the hunt for a winch.
post #3 of 3 Old 07-29-2017, 06:41 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
You've duplicated the conventional look of a catalog bought bumper, but with less function since you used 'on hand' steel. Buying the right steel isn't that expensive.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
