Yj Frame Dimensions - JeepForum.com
post #1 of 14 Old 04-20-2012, 07:24 PM Thread Starter
Shoelessboi
Yj Frame Dimensions
Ive searched and searched and cant locate the dimensions to the rear part of the frame. Have a buddy thats going to fix my frame rot around my rear shackles. Does anyone know dimensions? Plan on cutting a bit off after making a new piece and welding it up.
Originally Posted by dillonjm View Post
:The fact you even asked this question makes me want to punch myself in the face.
1991 Jeep Yj. 4cyl. 33x13.50x15 TSL Thornbirds, Super Wader Snorkel, 4" Rough Country Suspension Lift, Uniden Pro520xl Cb, 1000W Amp, 12" Rockford Fosgate P2 Sub.
Shoelessboi is offline
post #2 of 14 Old 04-24-2012, 04:12 PM
Copperhead89
Here you go. This drawing was very helpful when I was rebuilding the rear section of my YJ frame.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is offline
post #3 of 14 Old 04-24-2012, 05:30 PM Thread Starter
Shoelessboi
Ahh ill see if i can make that work. Im trying to figure out the angle.
post #4 of 14 Old 04-24-2012, 07:29 PM
Copperhead89
If you mean the angles of the rear axle hump, maybe this will help. This is how I built the frame rails.
The finished product, prior to priming and paint. I took some design liberties with regard to the shape of the crossmember in front of the gas tank.
post #5 of 14 Old 04-25-2012, 12:37 AM
oalali
nice !
oalali is offline
post #6 of 14 Old 04-27-2012, 01:13 PM Thread Starter
Shoelessboi
Have you thought about making frame repair parts?
post #7 of 14 Old 04-30-2012, 10:47 AM
Copperhead89
No, but if I ever lose my day job, I might consider it.
post #8 of 14 Old 01-03-2013, 08:28 AM
79jeepincj7
1979 CJ7
Copperhead, what size square stock did you use to fix the rear of the frame? 2x3 or is that 2x4? Also what thickness did you go with? Gotta fix my YJ in the next couple weekends.
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
post #9 of 14 Old 01-04-2013, 12:02 PM
Copperhead89
I PM'ed you, but I'll repeat it here. I used 4" x 2.5", with 1/8" wall thickness. This size is a perfect match to the YJ frame rails.
post #10 of 14 Old 01-07-2013, 07:39 AM
79jeepincj7
1979 CJ7
Thanks! That fit over the frame? Or did it butt up against it?
post #11 of 14 Old 01-08-2013, 10:25 AM
Copperhead89
The frame measures 4" x 2-1/2", so it butts up to it.
post #12 of 14 Old 02-25-2013, 04:29 AM
Flyntrock
Can anyone Please tell me the measurements of a jeep YJ hood.. ?? I only need the top(flat) section of the hood; width and length.. I sure would appreciate it.. I'm @ work & can't get to mine..
Flyntrock is offline
post #13 of 14 Old 03-26-2017, 09:44 AM
KipperKRB
yj frame dimensions
I have a 1995 yj frame and I want to use this frame for my 1994 yj. The problem, is the 1995 has 4.0l mounts and the 1994 has 2.5l mounts? Looks like you move frame motor mounts? Will this work? Do not have exact dimensions, figured exact dimensions would be than just measuring old frame. Anyone have a print preferably with standard dimension rather than metric?
KipperKRB is offline
post #14 of 14 Old 03-26-2017, 12:14 PM
StanF
Because of the frame angles measuring with any accuracy would be difficult. My suggestion is to install the transmission to the skid plate and use it to determine where the engine frame mounts should be located. This is a foolproof way to locate them, but it requires more labor.
Or find a 4.0l frame...
StanF is offline
