XJ Transmission Crossmember - JeepForum.com
post #1 of 1 Old 10-19-2013, 01:05 PM Thread Starter
Kettles
HI!
To make a long story short, im installing a SYE and new rear shaft next weekend, and I need a new transmission crossmember. I have been playing with a few ideas, and I wanted to throw them out there in case anyone had any suggestions.
FYI, I am designing these based on what I can feasibly make myself, in a reasonable amount of time and minimal expense. Also, these are made to scale in reference to the frame mounting locations. The transmission mounting location off center and bolt pattern are just estimates, I have not measured them yet.
First off was my first idea, which looked better in my head until I modeled it.
Its made from 1/8" plates and 3/4" pipe
Next up is a singe 1" pipe crossmember, super simple design.
ANd third is the hardest to make but by far the most factory type and strongest. 3/16" plate. I would have to make it from 6" wide plate and possibly could use a break at work, but probably would be slot/bend/weld.
So if you have any suggestions or alternatives, I would love to hear it!
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
