XJ Front Bumper Plans - JeepForum.com
post #1 of 5 Old 12-13-2010, 11:54 PM Thread Starter
btait1
1992 XJ Cherokee
Hey Guys,
I have always wanted a functional cool looking rock bumper on my 1992 Cherokee Limited. But they are too expensive. so My brother has decided to buy a welder for multiple reasons, and i need some plans/measurements/advice on welding up my own set of bumpers.
i want to keep it kinda simple and cheap.
i was thinking this for the front:
Olympic 4x4 Products 533-151 - Olympic Rock Front Bumper with Hitch for 84-01 Jeep® Cherokee XJ - Quadratec
and this for the rear:
Garvin Industries 34800 - Garvin Industries Rear EXT Series Swing Away Tire Carrier Bumper System for 84-01 Jeep® Cherokee XJ - Quadratec
If anyone has done something like this before, please chime in! I mainly want to have hitches front and rear for a future winch mounted on a hitch reciever
1992 Jeep Cherokee Limited 4.0l HO [Brand New Rebuilt by ATK]
Dana 30 [front] & Dana 35c [Rear], 4 Speed Automatic, Selec Trac Transfercase
3" Rough Country Lift, IRO Double-shear Track Bar, JKS Discos,
Michellin 31X10.5XR15
btait1 is offline
post #2 of 5 Old 12-13-2010, 11:59 PM
Green4dr
look here for some ideas if you plan on recovering make sure you look at the jcr tie in brackets and make something similiar.
www.rigidco.com Jeep Cherokee XJ Offroad Bumpers, Rocker Panel Guards & Vehicle Armor
JcrOffroad, Inc.
http://www.jcroffroad.com/xjuniframe.html
98 Green Cherokee Classic 4.0
3'' Rough Country II 33x12 bfg at
Spring Break Build thread/ makeover
http://www.jeepforum.com/forum/f22/98xj-classic-springbreak-makeover-1344754
Green4dr is offline
post #3 of 5 Old 12-14-2010, 03:53 PM
XJTino
1979 J-Series Truck
Well, if you have a welder, you are off to a good start. If you don't already have these, get them:
Angle grinder - get at least 1 good one. You'll use this tool SOOO much.
Good corded 1/2" Drill - Again don't get a cheap one, a nice one will last you years and years
Drill bits - Either go with a nice set of Black Oxide ones or Cobalt.
Jig Saw w/ metal blades
With these tools you can fab most things.
Use cardboard cut outs to mock up your pieces. If you want something more rigid, and if you have access to it, use scrap sheet metal or aluminum.
As far as ideas for the bumper:
Use Tube - sure they may not look as cool as some of the plate ones, but they are easy to build and super strong. I would go with a 2" x 5" or 2" x 6" with 1/8"-1/4" Wall
Through Tube Shackle Tabs - don't be lazy and weld your shackle tabs to the front surface of your bumper. Any lateral load on the tab will pull it off. Cut a hole through your tube on both sides and weld that sucker in so it won't go anywhere.
Tie in brackets - Don't only mount your bumper to the stock mounting location. Go all the way back and grab the bolts for the steering box. The JCR tie-in plates as mentioned above by Green4dr are perfect
Here are some drawings of my winch bumper
The large green piece is the stock front crossmember. You can see how many bolts hold it in place to the uniframe
The smaller green pieces help protect the the uniframe from crushing by spreading the load out
Here is a shot of almost what it turned out to be
Here it is finished and in use. I added a small hoop (wish I had made it bigger to I could actually see it from inside...)
I can't afford a winch yet, so I use it as a place to hold...stuff
-Tino
"Working with cars is a little like a really awesome date: you start out expecting this to be simple and straightforward; four hours later you're laying under her, panting and cursing, and things are a lot more complicated than you thought."
I drove okee ('92 XJ)
then I wrecked him...
So Then...
I drove rokee ('93 XJ)
then I rolled him...
Now...
I drive Clifford ('79 J-20)
XJTino is offline
post #4 of 5 Old 12-14-2010, 04:36 PM
PAFirefighter11
Quadratec Live Chat Rep
PAFirefighter11's Avatar
2015 JK Wrangler
I LOVED my OR-Fab bumper - so much so I ran it on both my XJ's! I hate tube bumpers but I beat the piss out of them and they held up great!
Shots of my other XJ are blocked here at work so I can't link it
-Rick R
-2015 JKU - 3.5" JKS JSPEC Kontrol, 315/70R17" MTZ's, 17x9" Quadratec Rubicon Xtreme's, JCR bumpers & skids, JW Speaker tails, Dirty Dog netting/screens, Quadratec Auto Mirror Movers, etc
-03 VW Golf TDI - Diesel
-FDNY 9/11/01 - All gave some. Some gave all.
PAFirefighter11 is offline
post #5 of 5 Old 06-20-2013, 07:41 AM
emresarac
is it possible to share these 3D's with me?
emresarac is offline
bumper build , xj
Does anybody have design plans for an XJ front bumper or rear bumper RescuedJK Fabrication Shop 1 03-15-2010 04:58 PM
Looking for front bumper plans crazycollinz Fabrication Shop 5 09-21-2009 07:21 PM
Looking for rear and front bumper prints(plans) Heavysausage Fabrication Shop 3 04-21-2008 10:58 AM
Looking for front bumper plans/dimensions wwiihistory Fabrication Shop 3 05-14-2006 02:27 AM
