Quantcast Xj With A Frame Build!! - Page 5 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Xj With A Frame Build!!
Old 04-01-2009, 12:21 AM   #61
DC4W-93XJ
1990 XJ Cherokee
alrighty.. as promised.. more pictures..
here's some of the frame up on the table getting squared up and some crossmembers added to it..
heres some as it was going under the body..
and heres a couple of the body dropped down on the frame..
i gotta look through my photobucket, that may be all the major big steps i've made.. once i get my camera up and runnin again ill get ya guys some pics of the motor and tranny mounts.. i got the rest of the motor mounted tonight.. now i can remove the body and finish welding up all the mounts i just added to it
THIS AIN'T YOUR MAMA'S STATION WAGON!!
Built Jeep Tough With Chevy Stuff
"Tater 2" '91 2 door XJ chopped and bobbed, 4.0, AW4, dana 300, GM 60/70HD, 40" IROKs on H1s
SEE THE BUILD HERE
DC4W-93XJ is offline   Reply With Quote
Old 04-01-2009, 12:38 AM   #62
MisterO
Wow such amazing work!!! Its so cool to see this. I'm lovin it, along with many others
MisterO is offline   Reply With Quote
Old 04-01-2009, 12:46 AM   #63
wspastorbryan
That jeep is going to be sick. glad to see die hard xj lovers out there.
wspastorbryan is offline   Reply With Quote
Old 04-01-2009, 12:51 AM   #64
DC4W-93XJ
1990 XJ Cherokee
Heres some pics of the rear end i'll be using.. again it is a Dana 70HD, i chose to use this axle because it is a higher clearance diff than a 14B, not that the 14B ring and pinion aren't big enough, lol but the dana 70 has a bigger ring.. the dana 70 has 35 spline axles where the 14B has 30.. i read somewhere that the 70 was rated 30% stronger.. i dont really care, i think they're both awesome axles, this is what the truck i bought had for a rear end.. SO IM USING IT hahaha..
both front and rear axles had fresh brakes on them, but the drums just had to go..
here are some pictures of the rear disc brake conversion and truss.. i know trussing an axle with 4"x1/2" wall axle tubes is rendered pointless, but the truss is not for strength... its for my upper control arm mounts..
for the conversion i used these parts..
* 73-87 Chevy K20 front calipers - $9.99 each
- also not that these do not have a mechanical ebrake, which is needed to be legal, '77 Eldorado rear calipers have a mechanical ebrake lever.. those are about $50 each.. since this is a rock crawler and will never see the street.. no ebrake will be found on this ride..
* '73-'87 Chevy K20 front rotors - $28.99 each
* do i really need to say which pads to use?? lol - $12
* '78 Ford E350 rear wheel studs $.60 each
I drew the caliper mounting bracket and the mounting flange on autocad myself so - free??
* Having the bracketry cut out on an autocad driven plasma-table - $40
grand total - $140 ish - a heck of a lot lighter... - better braking power
heres some pics.. enjoy..
now these in these pictures the new mounting flanges for the caliper mounting bracket ARE NOT welded on..
thats why the calipers are hanging straight down.. you can see i have a few pictures with the calipers up where they belong
SEE THE BUILD HERE
Old 04-01-2009, 01:17 AM   #65
zippome
i dont even know what to say. aweosme project.
Im 20 with a 2000 Grand SOLD!
4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake
zippome is offline   Reply With Quote
Old 04-01-2009, 01:27 AM   #66
DC4W-93XJ
1990 XJ Cherokee
thanks buddy
SEE THE BUILD HERE
Old 04-01-2009, 01:45 AM   #67
DC4W-93XJ
1990 XJ Cherokee
Holy cow, thanks a million guys.. you really didn't have to do that.. i just received a PM from one of the administrators saying that my account has been upgraded due to donations from members..
now im the one that doesn't know what to say.. thanks so much to everyone that put that together..
SEE THE BUILD HERE
Old 04-01-2009, 07:40 AM   #68
SHAKEnBLAKE
SHAKEnBLAKE's Avatar
told ya...
Now you have no choice but to keep working and keep posting pics!
Shake & Bake with SHAKEnBLAKE - "Build Thread"
www.ohio4x4.com
98 pile o' parts: 4.0L, 3spd auto, 4", 35" KM2s, XRC8, 4.10s, MCE flatties, KOZ cage
SHAKEnBLAKE is offline   Reply With Quote
Old 04-01-2009, 08:24 AM   #69
jason m
love the dana 70HD. trust me if i didn't find a 14 bolt so cheap ( free ) i would of put one insteed. 4" tube's is what i really like about them. quick question why no rear steer? i regret not building a rear steer axle first insteed of a non steer.
for the 60 you doing chrome shafts or stock shafts with 35 spline 70 outers.
is that a TPI injection down tube i see in the background. thats what im building.
jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
jason m is offline   Reply With Quote
Old 04-01-2009, 08:43 AM   #70
jeepin_in_a_94
jeepin_in_a_94's Avatar
1994 XJ Cherokee
If your not going to do any SERIOUS wheelin, like competition rock crawling.. the unibody does just fine, and i've seen many XJs (with the unibody still intact) in rock crawls that have no problem holding their own..
my 1st XJ with the same motor, tranny, t-case, and axles weighs 1200lbs less than my buddies TJ and mine had more body armor on it..
oh yeah my holds its own but they stiull give me crap even though i end up out wheeling them most of the time. and may i say that you are one hell of a welder, i am jealous, project is lookin good two thumbs up!!!
'94 XJ Sport (my toy) - 5.5-ish inches of lift, 33/12.5/r15, locked in the front, custom armor, OBA
'86 MJ XLS (family toy/budget build) - 5-ish inches of lift, 32/11.5/r15
'99 WJ Limited (my DD) - 2.5 inches of lift, 255/70/r16, some go fast goodies
Only 22 and on a college budget, but loving every minute of the 'Jeep Life'
If you wanna know more about the rides or if you need something made just ask! :)
jeepin_in_a_94 is offline   Reply With Quote
Old 04-01-2009, 08:56 AM   #71
wyker
Amazing work so far...
Subscribed!
wyker is offline   Reply With Quote
Old 04-01-2009, 09:30 AM   #72
3xratedxj
It's like I forget how to speak when I look through this thread
3xratedxj is offline   Reply With Quote
Old 04-01-2009, 10:18 AM   #73
DC4W-93XJ
1990 XJ Cherokee
jason.
Some day it'll be full chromo but not right now.. im a 19 year old college student.. had to sell my first jeep to pay for this one.. workin with a 4900 dollar budget till i start workin again this summer..
and i didn't do a rear steer again for the budget aspect of the build and most of the competitions that i'll be runnin this beast in don't allow it..
and yup that it TPI injection down tube in the background.. HOWEVER it's not mine my brother is putting that on this truck, i tried buying it from him but all he had to say was 2 grand 2 grand.. he bought a WHOLE MOTOR witha spun rod that had the cyinder heads, all the fuel injection, even the complete harness and ECM for $365.. the motor had spun a bearing but he's using his bottom end anyways.. i might have to steal little brothers toys and hide them under the bed
and for the 60 outers.. im going to stick with the 35 spline inners 30 outers FOR NOW.. but probably this summer i'll get ahold of a 35 spline outer kit.. i think they're only 150 a side....
SEE THE BUILD HERE
Old 04-01-2009, 10:22 AM   #74
DC4W-93XJ
1990 XJ Cherokee
hey thanks a lot.. that's actually my major.. just like i was sayin jason just now.. im a 19 year old college student, im majoring in welding.. lookin to get my AS **associates of science** and all my certifications here and play football, then transfer to a university and get my BS **bachelors of science** hopefully on some kind of scholarship then ultimately become a pipe welder
SEE THE BUILD HERE
Old 04-01-2009, 10:31 AM   #75
jason m
for what its worth ive been on the stock 30 spline outers for 4 years now with 39's and no braekage to date. run them and just dont be stupid with the pedel and they will last.
maybe i missed it but what year 60 you starting with. are they neck down or non neck down shafts. ive seen neck downs last but nothing like the non neck downs.
ya its allways the buget that kills the rear steer, but keep searching for another cheap 60 front and just run it offset like it is. weld it and just get 35 spline outer stubs and your done for now, that's the plan i have for my jeep.
for the buggy i have rockwells so im set there, agin nice work and are you going full hydro with a single ended CYL or a double.
jason.
Glock Forum
