XJ bumper build (other models also) - Page 5 - JeepForum.com
post #61 of 164 Old 09-14-2012, 02:05 PM Thread Starter
8pitcher
8pitcher's Avatar
Originally Posted by straightsixjeep
Just because your a big bad 17 year old now doesnt mean you can go around hurting peoples feelings Happy Birthday tho
Haha thanks man.
8pitcher is offline
post #62 of 164 Old 09-14-2012, 06:54 PM Thread Starter
8pitcher
8pitcher's Avatar
Here is the start of cimmers Jk bumper. I am using 2"x4"x1/4" tube steel. I cut the angles at 2"down and 6" across and just drew an angle across. And cut the triangles out.
I beat the cut out down to be almost flush with the cut out. Then I clamped them down.
And this is how I sit right now before I start welding.
8pitcher is offline
post #63 of 164 Old 09-14-2012, 08:11 PM
straightsixjeep
That bumper already looks awesome. On another note, is there anywhere to wheel down near your area?
straightsixjeep is offline
post #64 of 164 Old 09-14-2012, 09:19 PM Thread Starter
8pitcher
8pitcher's Avatar
Text me about wheelin.
8pitcher is offline
post #65 of 164 Old 09-14-2012, 09:27 PM
straightsixjeep
You have officially been texted.
post #66 of 164 Old 09-14-2012, 11:29 PM Thread Starter
8pitcher
8pitcher's Avatar
Got a prelim mounting of my Jk bumper.
This is all my welds before grinding then rewelding and then regrinding and repeat til there is no more holes in the welds.
Here is the bumper while building.
8pitcher is offline
post #67 of 164 Old 09-14-2012, 11:32 PM
straightsixjeep
Attachment 472497
Attachment 472499
Attachment 472498
Do you weld in a C pattern? It looks really good man, you seem to know what your doing!
post #68 of 164 Old 09-14-2012, 11:36 PM Thread Starter
8pitcher
8pitcher's Avatar
C pattern? I will show you tomorrow how I weld I don't know how to explain it.
8pitcher is offline
post #69 of 164 Old 09-15-2012, 12:02 AM
cimmer
Attachment 472497
Oh wow...hadn't realized how much null space that plastic bumper was taking up! Quite a recess below the door. Wonder if I can get an onboard air compressor in there somewhere...
cimmer is offline
post #70 of 164 Old 09-15-2012, 12:21 AM Thread Starter
8pitcher
8pitcher's Avatar
Ya I didn't realize that either. How do you like it though?
8pitcher is offline
post #71 of 164 Old 09-15-2012, 12:32 AM
cimmer
So far so good. Tough to tell how it will sort out aesthetically with the recess and all (guessing the frame will be showing from above?). Not too concerned about that, however. So long as she hooks up solid, the stock tow receiver is unmolested and the dring mounts hold up under recovery, mission accomplished.
Serious about trying to use that new space for a compressor, though. The engine compartment with the 3.6L is tighter than you'd believe. Hard to tell how much space is really there?
Btw, picked up a couple of 1.75" spacers for the front coils. We can talk about that tomorrow.
cimmer is offline
post #72 of 164 Old 09-15-2012, 12:40 AM Thread Starter
8pitcher
8pitcher's Avatar
Ok sounds great. Just give me a call anytime tomorrow that works for you.
8pitcher is offline
post #73 of 164 Old 09-15-2012, 05:37 AM
rugsucka
You have a lot more work to do than just slapping that bumper on. You should really to something about the gap - it looks terrible and makes a brand new jeep into a hack job.
If you have a tight enough gap and use the right size rod and technique you shouldn't need to weld and grind and weld and grind to get rid of occlusions.
If you plan on putting clevis mounts into that bumper for recovery, make sure they are pass thru and not surface mount so that they won't pull off with your suspect welds.
rugsucka is offline
post #74 of 164 Old 09-15-2012, 07:35 AM
cimmer
How would you approach closing the gap?
Definitely my biggest concern. Safety above all else. Dumb question...what's a pass thru mount? Guessing drill through the bumper and insert an anchor of some sort?
Thanks in advance
cimmer is offline
post #75 of 164 Old 09-15-2012, 09:30 AM
nwpipelayerxj
1997 XJ Cherokee
I'm putting Clevis mounts on mine today, what "I" am doing is cutting out a tight exact fit hole for my Clevis mounts then welding them from both the front and back of the bumper to double up and make sure it's much stronger. That's what I "think" he's talking about bud. Keep up the good work.
nwpipelayerxj is offline
all jeep vehicles , build , building bumpers , jeep , xj
Help me build this bumper theblackjeep98 Fabrication Shop 9 08-16-2011 12:00 PM
looking for a shop to build my bumper for my zj I have build plans FLboy4x4 Fabrication Shop 6 08-02-2010 08:56 AM
Bumper build... Stang5lgt Fabrication Shop 15 03-29-2009 06:46 PM
Another TJ Bumper Build RubiconTed Fabrication Shop 12 03-11-2007 06:26 PM
bumper build help frumpy Fabrication Shop 6 11-20-2006 06:25 PM
