would you trust these welds for cage? - JeepForum.com
post #1 of 14 Old 07-04-2013, 07:56 PM Thread Starter
willyb8
willyb8's Avatar
just welded up front add on cage and wondering how i did. used Hobart 187. with .035 wire with gas.
[/URL]
91 YJ 4.0 HO,
3.5" BDS, 5/8 MORE Booms, 1" BL, MML
AA SYE & CV,
35" Maxxis Bighorn
Smittybilt XRC8 Winch,
8.8 W/Elocker, D30 W/Aussie
Genright tube fenders
willyb8 is offline
post #2 of 14 Old 07-04-2013, 08:16 PM
Redneck92
I'm not welding expert at all so this might be wrong but it looks like the weld wasn't hot enough causing poor penetration.
86 4Runner "The Turtle" - 22RE 5spd, duals, Dana 60, 14 Bolt SAS on jackstands
02 Tacoma - 3.4 5spd TRD
Carolina Trailblazers
Redneck92 is offline
post #3 of 14 Old 07-04-2013, 09:13 PM
AGDubyaJ
Looks like your wire speed was up a bit too high, but it looks like you got adequate penetration, if your that worried just grind it out and put another pass on it. I would think that weld will hold though, I've seen nastier welds hold up to crazy abuse.
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #4 of 14 Old 07-04-2013, 09:15 PM
BCrawford64
These look just fine lol. I think you were really just trying to show off your welds haha.
BCrawford64 is offline
post #5 of 14 Old 07-04-2013, 09:49 PM
AtTheHelm
Should be fine. Why so much grinding on the tube though?
AtTheHelm is offline
post #6 of 14 Old 07-04-2013, 10:46 PM Thread Starter
willyb8
willyb8's Avatar
Prepainted tube and didn't want to much to bubble and make a mess. Well that and not paying attention.
Just asking cuz pretty new to welding and first time welding something for safety
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
willyb8 is offline
post #7 of 14 Old 07-05-2013, 07:41 PM
wheelie387a
That should hold, but i would turn the heat up another notch and leave the wire feed speed where its at...
wheelie387a is offline
post #8 of 14 Old 07-06-2013, 09:51 AM
Ironworker709
Ironworker709's Avatar
I agree with others,it should be OK...and..like others said,learn to weld a little hotter for better penetration and strength...AND..get out of that Downwhill habit..run uphill,downhill causes several lack of fusion and penetration problems unseen
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #9 of 14 Old 07-07-2013, 08:34 AM
NalinMFG
How thick of material?
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #10 of 14 Old 07-07-2013, 08:42 AM
wjjgctommy
Looks like wire speed was too high. Also Turn the heat up a bit for better penetration.
wjjgctommy is offline
post #11 of 14 Old 07-07-2013, 10:43 AM Thread Starter
willyb8
willyb8's Avatar
.120 wall and stock thickness ??
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
willyb8 is offline
post #12 of 14 Old 07-07-2013, 10:52 AM
wjjgctommy
Leave wire feed where it was. Turn heat up a little and do another pass after a little grinding. Just grind smooth then do another pass
post #13 of 14 Old 07-07-2013, 12:53 PM
NalinMFG
It'll be fine.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #14 of 14 Old 08-11-2013, 08:01 PM
andrewmacc
Looks like wire was fine to me, just needed to go a little slower and hotter on the flat and not go downhill on the vert. IMO that's what makes it look like too much wire, the downhill spreads out and sits on the tube instead of punching in like the flat.
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
