Wiring for a welder - JeepForum.com
post #1 of 11 Old 11-22-2008, 04:09 PM Thread Starter
JeepMKcomin
Wiring for a welder
It seems most welders are 3 prong 220/230v plugs that are high amperage. I'd like to use my dryer plug to run my welder so I wanted to make an extension. Unfortunately my dryer plug is 4 wire (2 hot, 1 ground, 1 neutral). How can I make an extension cord to go from 4 wire to 3 wire?
I realize dryers use bonding straps for 3 wire applications and they are removed for 4 wire. Can I hook the neutral to the ground with a wire and run the 2 hots and ground to an end plug... or how should I do this?
Thanks ahead of time. Hopefully an electrician can chime in.
06TJ Silver Ruby - REBB w/DT3000s, Quick Discos, Superwinch EPi9.0, Warn engine skid, PS Box Skid, Diff Guards, IPF Lenses, x51s soon
92YJ White - Slight Shackle Lift w/30x9.5 BFG ATs, Custom Beefy Bumpers
06TJ Khaki Sport - Traded in
JeepMKcomin is offline
post #2 of 11 Old 11-22-2008, 04:15 PM
Ballard
welder
This kind of depends on the welder. Some ac/dc stick welders need a 60 amp breaker,whereas a straight ac doesn't need this much. Your typical electric dryer is usually protected by a 30 amp . Ballard
Ballard is offline
post #3 of 11 Old 11-22-2008, 04:27 PM Thread Starter
JeepMKcomin
My dryer is protected by a 30 amp, I will not require more than 30amps of input at the rated output of the welder.
post #4 of 11 Old 11-22-2008, 05:07 PM Thread Starter
JeepMKcomin
Neutral wire on a 4 prong goes to the chassis of a dryer. Can I add a screw to the chassis of the welder to accept a neutral wire? (and thus convert the welder to a 4 wire plug)
post #5 of 11 Old 11-22-2008, 05:10 PM
Ballard
welder
You can make an adapter for your welder from your dryer plug. I would make an extension cord using 10 gauge 3 conductor stranded copper S.O cord with a four plug on one end to a three prong receptacle on the other. The 10 gauge cable will carry 30 amps . Ballard
Ballard is offline
post #6 of 11 Old 11-22-2008, 06:00 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Use the two hot leads and ground, leave the neutral disconnected and insulated with a wire nut secured in place by electrican's tape. 10-12 gauge is fine for a typical 220v welder, it usually draws less current than a 110v welder does.
Jerry Bransford is online now
post #7 of 11 Old 11-23-2008, 05:25 PM
Fastbeeatch
I'm using a 10\3 wire the nice flexible kind like an extension cord, don't worry about the extra prong on the male plug. What I did with mine is I took the prong out so that I only have three prongs +, -, and ground, that is all the welder need you don't need to ground the welder chassis which would be the fourth prong.
95 4L Auto D300 TC
103" Wheelbase
D60 Front 14 Bolt Rear 4.10 Gears
H1 Wheels 36" GoodYear OZ Tires
Fastbeeatch is offline
post #8 of 11 Old 11-23-2008, 05:37 PM
mylittlecj5
1974 CJ5
I couldn't tell you what size it is, but I've had a 70 foot extension for my 230 amp welder for many years. Plugs right into the dryer outlet.
If I use the welder turned up high, it will blow the breaker. then I know its time for a break...
Default Jeepers Club #10
mylittlecj5 is offline
post #9 of 11 Old 11-23-2008, 05:43 PM
Fastbeeatch
Yeah 70 feet for a 230 amp welder is a lot for a 30 amp breaker, you must have a decent size wire going to the welder to be able to run it at high amps for any amount of time.
95 4L Auto D300 TC
103" Wheelbase
post #10 of 11 Old 11-23-2008, 05:50 PM
mylittlecj5
1974 CJ5
yea its 4 wires in a sheath about 1 1/2" in diam.
post #11 of 11 Old 11-24-2008, 05:08 PM
Ballard
The S.O cable that I mentioned earlier in this post is what you want. It is flexible even in the cold it is Sunlight and Oil resistant hence S.O. it is even used on circulating water pumps under water .Three conductor red,white,and black and you are ready. As mentioned in an previous post It is a good idea to keep it to a minimum ,so just use the shortest length as you can get by with. Ballard
Ballard is offline
New welder, wiring question bluesman423 Fabrication Shop 10 07-25-2009 07:39 PM
Another welder wiring question........... rustywrangler Fabrication Shop 15 05-19-2009 09:12 PM
wiring welder to dryer outlet help willyb8 Audio, CB & Ham Radios, GPS, & Electrical 6 02-04-2009 08:01 AM
Quick Welder Wiring ??'s timatoe Fabrication Shop 7 12-09-2007 09:20 AM
Wiring my garage to run a welder for my jeep...:) bigstinger Fabrication Shop 12 09-29-2007 04:57 PM
