Windshield light bar - JeepForum.com
post #1 of 68 Old 02-04-2011, 04:59 PM Thread Starter
rinking
I've wanted to build this for a couple years, ever since I seen the DELTA bar. Thought maybe i'd throw this idea out there for the Jeepaholic's.
rinking is offline
post #2 of 68 Old 02-04-2011, 05:12 PM
badazztj
thats freakin tuff!!
badazztj is offline
post #3 of 68 Old 02-04-2011, 09:22 PM
Mudweiserjeep
Mudweiserjeep's Avatar
1970 CJ5
Great Job!
I am not big on lights across the windshield either but I do like yours.
Can you post up a rough material list? What kind of stock did you use to house the lights? Rectangular tubing?
- Tim
Tim - KC8UXU
1987 XJ (Evil) (Parting out)
1970 CJ5
231 V6
2.5"bds lift, 0.75" shackle lift, 4:88 gears
31" Old tires..... need newer ones....going 35"
Mudweiserjeep is offline
post #4 of 68 Old 02-05-2011, 06:48 AM Thread Starter
rinking
2x4x 1/8 rectangle and the side pieces are 3/16 plate, could use 1/8, I only had the 3/16. I built the bar first, figure out how long , I think I was shootin for 55"! I cut two notch's in the 2x4 and pulled it back together and welded it. This was so its not just a boreing straight bar! I bought a light kit for a Tough stuff hood light bar. And I bought the LED's locally. Lay all the lights out and measure two or three times!!! I used a few different size hole saws in my drill press, and a 4" cut off wheel to connect the dots. Dremal to clean it all up and flapper disc. wired it according to the light kit. LEDs tied into the running light switch!
rinking is offline
post #5 of 68 Old 02-05-2011, 07:24 AM
Jims-87YJ
1987 YJ Wrangler
Great looking Light Bar! Can I ask how you attached it to the windshield? (What did you use for nuts in the pillar)
Also how did you run your wires into the cab? Thanks
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
post #6 of 68 Old 02-05-2011, 09:55 AM
jatepper
Outstanding job! What did you use to make the bends? I'm assuming you have a press brake?
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #7 of 68 Old 02-05-2011, 10:00 AM
FragOut
It looks great, but i think it has to many unneeded mounting locations. 6 screw/bolts on each side little much my opinion but none the least still looks sweet. Like the low pro design and the actual rail to hold it in place nice not being just straight up to the light bar. Looks great.
FragOut is offline
post #8 of 68 Old 02-05-2011, 10:10 AM Thread Starter
rinking
Sorry, My wife was rushing Me out the door, so I could'nt finish the last post! I used a piece of cardboard to mock up the side parts. As in the pictures, I laid a couple 4' levels across the top of the hard top and clamped the light bar to it. I put a heavy piece of angle on the levels to hold them down. Had to get creative! I moved the bar around till I liked it. (angled down just a touch). Bending the side plates was a pain. Used My vise and some heat. The side pillers on the windshield are actually quite beefy, 3/16-1/4" I drilled and tapped the holes. 12 countersunk hex head (same as windshield and door hinges) were used so the boltheads wouldn't snag branch's.
rinking is offline
post #9 of 68 Old 02-05-2011, 10:24 AM Thread Starter
rinking
I then drilled a hole in the driverside upper corner of the windshield frame to pass the wires down through the inside, and out where the wiper wires go into the dash. I put alot of thought into this, and am pretty proud of how it came out! I would have never guessed that someone would say I have to many mounting points! To each his own! Where We wheel around here, it's usually pretty tight through the woods. Not uncommon to take a big branch in the windshield and plow through it!
rinking is offline
post #10 of 68 Old 02-05-2011, 11:14 AM
Jim1611
Jim1611's Avatar
Very nice work.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #11 of 68 Old 02-08-2011, 01:33 PM
XJTino
1979 J-Series Truck
I REALLY like the ways this looks when compared to roof rack light bars using large round light. The low profile design is nice.
But, with this style, it seems like you are limited on what kind of lights you can use. What lights are you using?
Do you have a picture at night with just the roof lights on?
-Tino
"Working with cars is a little like a really awesome date: you start out expecting this to be simple and straightforward; four hours later you're laying under her, panting and cursing, and things are a lot more complicated than you thought."
I drove okee ('92 XJ)
then I wrecked him...
So Then...
I drove rokee ('93 XJ)
then I rolled him...
Now...
I drive Clifford ('79 J-20)
XJTino is offline
post #12 of 68 Old 02-08-2011, 01:55 PM
firefighter315
I'm guessing the multiple cutouts on the 2x were to decrease some weight and give it some design aspects? Did you box in behind the lights themselves or are they open to the elements? Great job, by the way! I have a standard "tube" type light bar that I have gone back and forth on a million times on getting rid of it or not. I like the low profile boxed style much better, but like you, refuse to pay for the outrageous Delta bar.
Did you wire the lights to be all on/all off, or for multiple combinations like the Delta bar? i.e. 2 on, 4, on, 6 on..... Thanks for sharing your ideas!
My YJ Build Thread
firefighter315 is offline
post #13 of 68 Old 02-08-2011, 02:56 PM
Machinist
Yet another design I will be coppying for the scrambler!Thats tuff looking bud
Machinist is offline
post #14 of 68 Old 02-08-2011, 06:54 PM
green_jeep
now thats BAD ***!!!!! i love it
nice work!!!
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
Jeep, Bike, and Street Rod, i NEED MORE money
green_jeep is offline
post #15 of 68 Old 02-08-2011, 07:21 PM
green_jeep
i keep looking at this light bar and im wondering how u mounted the lights inside the 2X4 tube??
i really think im gonna make one like this, what a great looking light bar!!!
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
Windshield Light Brackets CHAYES911 General Jeep & Off-Road Equipment 6 12-24-2009 11:37 AM
Windshield Light Mounts kellerumps Audio, CB & Ham Radios, GPS, & Electrical 0 11-09-2009 06:53 AM
windshield light bracket KodiakBuzz General Jeep & Off-Road Equipment 3 12-27-2008 11:47 AM
bright windshield light mattman8706 Audio, CB & Ham Radios, GPS, & Electrical 11 10-10-2006 01:53 PM
KC windshield light mount? - TJ nikki Audio, CB & Ham Radios, GPS, & Electrical 0 04-15-2005 09:12 AM
