winch plate - JeepForum.com
post #1 of 11 Old 11-01-2004, 12:16 PM Thread Starter
WAC_Jeeper
WAC_Jeeper's Avatar
winch plate
Hey, I just got a 9000 pound winch, now I need to make a winch plate. Wondering what you guys with TJs did? I was thinking of using 1/4 inch angle iron. Any ideas? Thanks
12 JKR 2 door, MCE Gen III Flares, Teraflex 1.5" Perfomance Leveling kit, 35" MTRs, ARB bars front/rear, ARB diff covers, ARB Dual Compressor, AEV DOT-compliant beadlocks, Warn Zeon 8
97 TJ, MCE fenders and flares, heavily used and reliable on 35's.
WAC_Jeeper is offline
post #2 of 11 Old 11-04-2004, 06:32 PM
Scafone
Scafone's Avatar
I made a temporary one for mine before I made my winch bumper. I used a piece of 1/4"flat stock and welded a thicker angle to the front for the fairlead mount. It worked perfectly, but I didn't paint it, so it looked a bit rough.
Fairly easy to do...if fact, if you have the right peice of steel (channel), you won't even need to weld anything.
"Laws that forbid the carrying of arms...disarm only those who are neither inclined nor determined to commit crimes...Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man."
--Thomas Jefferson
Scafone is offline
post #3 of 11 Old 11-07-2004, 03:20 AM
Rubicon it
I actually made a bucket for my winch setup, 1/4 flat stock for the bottom then bent 1/4 flat for around the winch completely. alot of welding but it looks good. fastened it to the frame where the tow hooks used to be then bolted it to the bumper (fabbed up bumper).
Rubicon it is offline
post #4 of 11 Old 11-08-2004, 01:20 PM Thread Starter
WAC_Jeeper
WAC_Jeeper's Avatar
Thanks for the replies do you guys have any pictures?
post #5 of 11 Old 11-08-2004, 08:53 PM
Rubicon it
crapolas, WAC pm me and I'll come and show ya the bumper, your practically in the same neck of the woods. If your in sammamish right now
mo
post #6 of 11 Old 11-08-2004, 08:56 PM
psychedelicdawg
psychedelicdawg's Avatar
click this link, there are pics of the one I made out of C-channel
http://www.jeepsunlimited.com/forums...hreadid=573703
'95 YJ 4.0 5 speed.... on 35's
psychedelicdawg is offline
post #7 of 11 Old 11-09-2004, 06:25 AM
390fastback
390fastback's Avatar
Hey psychedelicdawg, just a suggestion, you should rewind your winch so you pull from the bottom not the top. They're not designed to pull that way. Other than that, where the hell was this thread when I made my plate?
2000 Cherokee
68 Mustang Fastback (in progress)
71 Mach 1
68 Wildcat (also in progress)
68 International 1200 4x4
78 F150 4x4 400 4spd
390fastback is offline
post #8 of 11 Old 11-09-2004, 07:02 AM
psychedelicdawg
yeah, I already did that.... Thanks for the heads up though.
post #9 of 11 Old 11-10-2004, 12:49 AM
Stricken
I used a piece of 33-1/4" long x 9" wide piece of 1/4" plate for my winch plate mounted directly to the frame. It's connect via the 4 bumper to frame bolts and the 2 front swaybar bolts and I just used a spacer to raise the rear swaybar mount up to sit level with the plate. After I got the winch perfectly spaced front to back I finished making my winch bumper and hoop. I've got some pics but for some reason I can't view them right now.
Stricken is offline
post #10 of 11 Old 11-10-2004, 12:16 PM Thread Starter
WAC_Jeeper
WAC_Jeeper's Avatar
Thanks for the replies. Nice pics physcodelic, I remember seeing those on JU a while ago, that is similar to what I had in mind.
RIPPN how did you mount the fairlead?
post #11 of 11 Old 12-11-2004, 06:21 PM
98JPTJ
98JPTJ's Avatar
WAC!!!!!!!!!
You gotta winch! Sweet!
Movin up in the world, what kind?
If I was back home, i'd bust open the fab shop and real quick like fab ya a real burly S O B...but I'm not home, damn.
Anything else new on the jeep?
Use Channel Iron like Phsycedelic did, thats the easiest and quickest and most HD for a quick and easy setup!
1998 TJ Sport Gunmetal Blue, lots o' mods and a few scratches.
1943 Ford GPW Flatfender Military Jeep
1945 Bantam BT3-C Jeep trailer.
1964 US Army Surplus M416 trailer.
98JPTJ is offline
DIY Winch Plate? sdlemaster General Jeep & Off-Road Equipment 7 09-18-2010 06:11 AM
Winch Plate (how to) sentinal02 Fabrication Shop 36 12-28-2009 11:23 PM
Warn Winch and Winch Plate Advice BigGreenTJ27 General Jeep & Off-Road Equipment 4 09-22-2009 01:35 PM
Winch plate on non winch bumper. Ski01xj Fabrication Shop 6 09-14-2007 08:26 PM
winch plate madmikey Fabrication Shop 2 12-18-2006 08:57 PM
