Why did I blow this hole through my frame while welding? - JeepForum.com
post #1 of 13 Old 04-28-2013, 08:36 AM Thread Starter
Alheim
Photo below.
So I'm welding my relocated frame motor mounts on my frame during my 4.0 swap, and things are going pretty well. I'm a novice welder with maybe ten hours of practice, and countless hours of welding study & research under my belt.
I'm welding with a 110v Lincoln MIG, using 0.035" flux core (Lincoln Innershield NR-211).
I stop welding to check out my progress, and for the first time, I see that I blew a 1/8" hole right through the frame! The frame is 1/8" thick. This has never happened before, even while practicing and intentionally pushing the machine to the limits (moving too fast, too slow, wire feed too fast, too slow, etc). I also had already welded the other motor mount with no issues.
Any idea why this happened?
I think the weld looks alright. What do you guys think? Is a second pass necessary?
Cheers,
Alex
'95 YJ 123bhp 4-banger powerhouse.
UPDATE: 2.5L ENGINE RETIRED; she was still running strong at 212,000mi.
4.0 swap in progress.
Alheim is offline
post #2 of 13 Old 04-28-2013, 10:35 AM
AGDubyaJ
just stitch it shut and run 2 more passes on it. there may have been a thin spot in the base metal (rust), or your travel speed was a little slow/ machine settings to high. its an easy fix, it shouldnt compromise the weld if you fix it properly.
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #3 of 13 Old 04-28-2013, 01:45 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I would've run the bead uphill though. See how you're bead is thin and "sunk in". Running uphill will deposit more filler. Just gotta be mindfull not to sit still too long, or the puddle can fall out.
BESRK is offline
post #4 of 13 Old 04-28-2013, 05:51 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
X2 on what besrk said. vertical up is much stronger than vertical down, though takes more practice and is harder to get a pretty weld going up.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #5 of 13 Old 04-29-2013, 07:34 AM Thread Starter
Alheim
All, thanks for the replies and for the confident boost. I skipped past the hole, welded the rest, and stitchedit up after.
The picture doesn't do the shape of the weld justice - it's actually less "sunk in" that it appears, and is more of a proper filet.
I was apprehensive about doing this welding myself, but in retrospect, I'm glad I did and confident in the results. All the prep work made for an easy weld. Anyway, we'll see what happens once I get her started and dump the clutch!
Alheim is offline
post #6 of 13 Old 05-03-2013, 12:55 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Originally Posted by Alheim View Post
The picture doesn't do the shape of the weld justice - it's actually less "sunk in" that it appears., and is more of a proper filet.
I have to agree with others. The weld seems a bit "thin" to me. And the mention of up hill is stronger is not just someone commenting it is a fact man.
Not bashing, but you basically told us you were book smart, not practice smart in this situation.
I personally would cap all of your vertical welds with an uphill pass.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #7 of 13 Old 05-03-2013, 08:38 AM Thread Starter
Alheim
No worries, the input is appreciated. I'll try to post another picture later, if I can.
Alheim is offline
post #8 of 13 Old 05-03-2013, 02:57 PM
spward
But if he is going to go uphill, he needs to watch his temp as the heat will rise and might have other holes to fill.
Scott
spward is offline
post #9 of 13 Old 05-07-2013, 02:09 PM
jaspepp
A good rule of thumb is run up if it has flux. Most stick rods as well as flux wire doesn't solidify quick enough and can trap slag in the weld if you weld downhill
jaspepp is offline
post #10 of 13 Old 05-07-2013, 08:12 PM
Ironworker709
Ironworker709's Avatar
It doesn't matter which wire it is..fluxcore or hard wire..downhill is a big no no for the fact you are not penetrating,you are only at most getting a surface fusion with no kind of penetration for strength and a great possibility of just a cold overlap and no fusion,in other words it just poured metal over it and never fused,but looks good....
I would also be the one to recommend cleaning that down hill up with a grinder and run an uphill for insurance,you'll just have to practice your uphills a little more to get the heat and wire speed and hand speed right.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #11 of 13 Old 05-08-2013, 03:00 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I tell my son that "Welding downhill is like pouring Lava over the steel." It just flows over the surface..
BESRK is offline
post #12 of 13 Old 05-08-2013, 03:25 PM
Ironworker709
lol..thats actualy a good way to put it
Never forget 9/11
post #13 of 13 Old 05-08-2013, 07:00 PM
hmantractors
2004 KJ Liberty
Welds
I would have back grinded some. It's not what you get on it as much as what you get into it. I would run a root pass then capped it. May be over kill but I'm used to pipe welding. My opinion, I thought you did fine for as little hands on experience you have. It is hard to weld rust. Grind it out, fill it, grind out again until you get a solid weld joint. Its all part of the game. Have fun with it.
hmantractors is offline
