where to buy: tire swing spring loaded pin? - JeepForum.com
post #1 of 9 Old 03-18-2010, 06:59 PM Thread Starter
lakailimited06
in the middle of building my tire carrier and ive been lurking the TJ rear carrier build by bersrk, and i notice some guys used a spring loaded pin to keep the swing arm from coming back..
anyone know where to buy this? did you have to piece it together at a hardware store/lowes etc or does it come in a kit of some sort?
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline
post #2 of 9 Old 03-18-2010, 07:24 PM
crcj7
northen tool . ag. supply you may have to change it a little bit i could have used the one that would have fit right in to my 2x2 tubeing but got the 3'' cause it was beefy 5/8
geter done goter did flipeder over didit agian
i need an nv3550 any one need a hardtop
crcj7 is offline
post #3 of 9 Old 03-18-2010, 10:13 PM
Bigbob
Bigbob's Avatar
IMHO you are better off with a latch like the De-Tas-Co. More secure and easy to open. The spring pin does not add tension like a latch does.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is online now
post #4 of 9 Old 03-18-2010, 10:20 PM Thread Starter
lakailimited06
im talking about a pin that prevents the swing arm from swinging back into the jeep once its already open...for the latch im using AtoZ's T handle setup...
99WJ 4.0
post #5 of 9 Old 03-18-2010, 10:24 PM Thread Starter
lakailimited06
Buyers 1/2in. Spring Latch Assembly | Hinges + Fasteners | Northern Tool + Equipment
something like this yes but not what im looking for...
99WJ 4.0
post #6 of 9 Old 03-19-2010, 02:48 AM
timatoe
timatoe's Avatar
I think BESRK will sell you one of his set ups.
timatoe is offline
post #7 of 9 Old 03-19-2010, 08:35 PM
dmgiff
I made mine. Used some 3/8" rod inside some steel tubing which was slightly larger inside diameter than the rod. Cut the tubing into two pieces about 1.5" inches long. Used 3/8" washers to capture the spring between the two pieces of tubing which I welded to the spindle carrier. Bent the rod in an "L" shape after heating it with my torch. Bought all the pieces at Lowe's. I would like a tighter fit between the rod and the tubing it slides in, but it does the intended job, so I'm not worried about it.
dmgiff is offline
post #8 of 9 Old 03-20-2010, 08:07 PM
Xtremjeep
Any place that sells swing up trailer jacks will have them in a kit. It's the same spring pin for locking the jack. They are like $5, I used the 1/2" pin.
Build Thread:
1980 CJ-7 Mall crawler (RIP 2010)
1983 CJ-8 Scrambler Full resto in progress
1988 YJ Fully Built but never Done
Xtremjeep is offline
post #9 of 9 Old 02-15-2011, 09:11 AM
00JGC00
Anyone else find these for a good price? I'm curious to see the different designs people are using...
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
tire swing out idea green_jeep Fabrication Shop 6 01-28-2009 02:42 PM
another tire swing, XJ this time skullver Fabrication Shop 4 01-31-2007 03:55 PM
Tire Swing, Gerry can? Bigbob Fabrication Shop 3 04-05-2006 10:46 AM
swing out tire carrior V8wrangler_idaho Fabrication Shop 28 11-12-2003 10:10 PM
Swing out tire carrier SAJeep Fabrication Shop 2 11-10-2003 06:13 PM
