When to drop the gas tank - JeepForum.com
post #1 of 11 Old 03-12-2011, 07:07 PM Thread Starter
Jon_Alex
I've got some UCA frame mounts and LCA axle mounts to reinforce, as well as a rear trackbar axle bracket to reinforce.
Do you drop the tank when you weld that close? Mostly the trackbar axle bracket is what I'm asking about...
KJ6HYE
"Convictions are more dangerous enemies of truth than lies." -Nietzsche
Jon_Alex is offline
post #2 of 11 Old 03-13-2011, 07:24 AM
TDRILL
Maybe its safer to drop it, but I never have and I've welded in all those areas. I just try to stick something between what I'm welding and the tank or fuel lines. Normally its thin steel plates but occasionally a non flamable blanket also helps if I can't get a plate in there for some reason.
Jeep parts available, $30 each:
Camo seat covers
Passenger side window OEM soft top
TJ rear drum brake pads
TDRILL is offline
post #3 of 11 Old 03-13-2011, 08:26 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Most everyone gets nervous making hot sparks around the gas tank, but remember, it's the FUMES you're worried about.
You're not welding right on the tank. As long as there are no fumes coming from nearby, you should be okay. This is a time when it might be okay to have a fan set back a behind you a bit and running on "low"......just to keep a bit of airflow. Obviously you don't want it blowing right where you're welding, but just enough to get rid of any fumage.
Pacfanweb is offline
post #4 of 11 Old 03-13-2011, 08:53 AM
dodger889
Fill the tank all the way up. Less chance of fumes being here. Due the welding outside not in a garage. This allow the fumes not to collect in where you are welding.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #5 of 11 Old 03-13-2011, 09:00 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Not to mention that if you DO blow it up, you won't blow your garage and house with it.
post #6 of 11 Old 03-13-2011, 12:34 PM Thread Starter
Jon_Alex
Ok, thanks for the replies. I'm not so worried about the fuel lines... just shield them from damage, etc. The tank also has a skid around most of it. I guess I could get a welding blanket and try pinning it up under there to shield everything from sparks.
KJ6HYE
Jon_Alex is offline
post #7 of 11 Old 03-13-2011, 02:04 PM
Bigbob
Bigbob's Avatar
I've been looking at doing the outboard rear shock deal and I think dropping the tank is a good idea. I had my tank off to install the Kilby skid and it ain't that big of a job. Good time to get all that muck and ire cleaned off as well.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #8 of 11 Old 03-14-2011, 02:58 PM
MO2500
x2.
Support it, unbolt (I think it's like 7 bolts), unplug sender, fuel line, return line, and then move it out of the way. Should take less than a 1/2 hr IMO
Instagram: @omsmike
MO2500 is offline
post #9 of 11 Old 03-14-2011, 06:40 PM Thread Starter
Jon_Alex
Yeah, I guess I'll wait and drop the tank and do all the welding at once.
KJ6HYE
Jon_Alex is offline
post #10 of 11 Old 03-15-2011, 07:22 AM
yarmish
Fwiw I just did my shock outboard this past sunday and didn't drop the tank. I put a welding blanket up around where the fuel lines were and didn't have any issues
In a ZUK now....
yarmish is offline
post #11 of 11 Old 03-21-2011, 01:56 PM
BlackBellamy
BlackBellamy's Avatar
Yeah same here, I outboarded the shocks with tank in place.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
OBA: Tank or no tank? Build a tank? UnsanePyro General Jeep & Off-Road Equipment 16 03-06-2009 08:00 AM
drop down muddy72 Tires & Wheels 2 03-25-2007 09:03 AM
Tank skids or tank replacement, how to? Challenge TJ General Jeep & Off-Road Equipment 13 03-06-2007 06:46 PM
XJ gas tank tank skid plans needed lazyxj Fabrication Shop 1 11-05-2004 07:38 AM
TC drop???? TellyDSP Tires & Wheels 2 08-15-2003 10:53 PM
