What type of bolts to buy for homemade leaf shackles? - JeepForum.com
post #1 of 6 Old 02-25-2014, 09:08 AM Thread Starter
slightlycrazy
I planned on using 3/8" steel to make longer shackles but the stock bolts won't be long enough for them. I'm not sure using grade 8 because they the theit shear strength may not be up to snuff & that's the type of load it'll have. Anyone have input/suggestions?
slightlycrazy is offline
post #2 of 6 Old 02-25-2014, 02:16 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Grade 8 is fine for shackle bolts..
BESRK is offline
post #3 of 6 Old 02-25-2014, 03:21 PM
thantos858
1974 CJ5
When no shear strength is given for common carbon steels with hardness up to 40 HRC, 60 % of their ultimate tensile strength is often used once given a suitable safety factor. This should only be used as an
estimation.
Grade 8 bolts have a minimum tensile strength of 150,000psi.
Like Besrk said grade 8 will be just fine.
thantos858 is offline
post #4 of 6 Old 02-25-2014, 08:15 PM
chet44
That's what I used before I switched to M.O.R.E. shackles with the greaseable bolts. You may be able to buy a set of those bolts through M.O.R.E. Their shackles are 3/8" thick.
chet44 is offline
post #5 of 6 Old 02-26-2014, 02:21 PM Thread Starter
slightlycrazy
Cool. Needed reassurance. I've seen how grade 8 "snaps" and grade 5 "gives" and heat treatment etc. I'll hit tractor supply.
post #6 of 6 Old 02-26-2014, 05:01 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
A Grade 5 will fail before a Grade 8 even begins to bend..
BESRK is offline
