What size breaker for 220v Welder - JeepForum.com
post #1 of 6 Old 01-25-2008, 12:39 PM Thread Starter
RedMountainYJ
Im going to install a dedicated 220v receptacle in my garage. I was planning on using a 30 Amp breaker but i really dont know if that would be sized correctly. i have an old (looks really really old), borrowed welder but am planing of buying something in the Hobart Stickmate flavor soon (maybe a mig depending on my tax refund). if i read the specs right the Hobart Stickmate 205 AC can hit 47.5 full load amps (but im not sure if thats draw or what).
1. should i expect to hitting full load amps on any welder when using it?
2. would 30 amp service do me well or should i jump into 50 amp service? (i have both space and capacity in my panel for either).
EDIT: 3. do all welders share a common style plug?
Thanks!
ED
'95 YJ
RedMountainYJ is offline
post #2 of 6 Old 01-25-2008, 01:10 PM
kencaz
from the Specs:
NEMA 6-50 style plug included
Go with a 2 Pole 50A breaker Two #6 and one #10 Ground in 3/4 EMT. If the main panel is not within visual range of the welder you'll need to install a 2pole 50 disconnect as well.
Good Luck
KC
"I say we dust-off and nuke the site from orbit... It's the only way to be sure!"
kencaz is offline
post #3 of 6 Old 01-25-2008, 02:21 PM
jfiscus
jfiscus's Avatar
1993 XJ Cherokee
I used 60 amp breakers & stick weld a lot of thick stuff for long periods, no problems. My garage breaker box is also 150'+ from the house/main box.
97 ZJ Limited, all power V8 AWD (wife's DD)
93 XJ Country 32" TSL Radials, 4.5" Rough Country Lift
91 XJ Laredo 33x15.5 TSL SXs, Homebrew 3" lift
Local to Cincinnati, Ohio? Check out our club!
jfiscus is offline
post #4 of 6 Old 01-25-2008, 04:04 PM
Bigbob
Bigbob's Avatar
Thanks!
ED
I have the 6/3 romex for mine, but my run is about 85 feet. 50 amp breaker. If your run is short you can use 8 gauge wire.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #5 of 6 Old 01-25-2008, 04:08 PM Thread Starter
RedMountainYJ
my run is going to about 3' (directly below my MDP).
should put a 50 amp set up in? what do 90% of 220v welders require?
'95 YJ
post #6 of 6 Old 01-25-2008, 05:39 PM
Bigbob
Bigbob's Avatar
50 amp breaker is correct. But I would just run 8 gauge wire. Here's a chart.
http://www.jhlarson.com/ind_tables/v...c_wiresize.htm
6 Speed, Hardtop
Bigbob is offline
Extension cord for 220v welder. Flingit1200s Fabrication Shop 13 11-06-2009 06:25 AM
Help with breaker for Welder Stan99 Fabrication Shop 11 08-18-2008 09:31 PM
Welding More YJ Rear Shock extensions to my frame with lincoln 220v stick welder bigstinger Fabrication Shop 4 05-30-2008 05:29 AM
Outlet and breaker size for welding... rustywrangler Fabrication Shop 66 06-14-2007 09:57 PM
220v Pipedrummer Fabrication Shop 3 03-06-2007 09:44 PM
