what kind of welder??? if you weld please look at this and give your input - Page 2 - JeepForum.com
post #16 of 45 Old 03-28-2011, 08:12 AM
notmyj
I went with a Hobart 140. It has done everything I asked it to up to 1/4"(with proper prep). I have done bumpers, axle brackets, misc brackets and parts during my SOA on my YJ. I have alot of trigger time with this welder and for teh money it welds VERY nice. I have reason to believe that the duty cycle is under rated as I have done some long beads with it maxed out and have yet to have it time out. If money was no object I would get the Hobart 210 for more power, but the 140 has done everything I need and since it runs on 110 it very portable.
Also, I just recently built a welding cart for it. The link is in my sig....
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #17 of 45 Old 03-28-2011, 10:13 AM
Fropleyqk
Fropleyqk's Avatar
2014 JK Wrangler
Originally Posted by happy_guy View Post
Not meaning this in a negative way; if you have never welded, I would suggest looking into a Votech program and get some hands on before taking on projects like suspension parts etc.
I dont disagree with this at all, however, with some practice, Mig is very forgiving. My first real project was my rear bumper/tire carrier (Ive had no formal training, just lots of reading). It turned out great. 3/16 all around and carries my 35" tire, hi-lift and Jerry Can with no problems. I used the clevis mounts to pull a 4 door JK over 2 obstacles last time we went wheeling. It was the make or break test for my welds. Passed with flying colors.
Practice and make sure youre getting proper penetration. I would be hesitant to weld 1/4" with anything 110v but trust it to do 3/16" all day long.
My bumper build is in my sig if you want to see how a novice welder with no experience, some research and a good Mig can turn metal into something useful.
Fropleyqk is offline
post #18 of 45 Old 03-28-2011, 11:13 AM
meatlord
Maximum Disaster
meatlord's Avatar
Miller Maxstar 150STL. 110v/220v auto sensing, stick and tig. Small, durable, and high quality. All you will need is a bottle.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" SOLD. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 12 Altima 3.5 SR CVT / 00 Suzuki DR650.
meatlord is offline
post #19 of 45 Old 03-28-2011, 11:17 AM
pcoplin
IF you have 220 in your garage, get a 220. The versatility will pay for itself in the long run. Lincoln, Miller, Hobart, they are all good. I have a Lincoln 175 with 75/25 gas. It's tuned very well and I'm very comfortable with the controls.
However, if you want a 110 only, get the Miller or Hobart 140, and run it with .030 wire and 100% Co2. Very nice machine, and will do most everything on your Jeep except weld inner Cs on.
FullStack MotorSports
pcoplin is offline
post #20 of 45 Old 03-28-2011, 11:21 AM
Fropleyqk
Fropleyqk's Avatar
2014 JK Wrangler
Originally Posted by pcoplin View Post
However, if you want a 110 only, get the Miller or Hobart 140, and run it with .035 flux wire. Very nice machine, and will do most everything on your Jeep except weld inner Cs on.
Thats better. Not as pretty but cheaper and more bang for the buck.
post #21 of 45 Old 03-28-2011, 11:25 AM
Tyler99TJ
I am just a hobbyist and really only work on my projects on the weekends, so if I need to buy something for my project I wanted to have a store that would have supplies in stock. I know Lowes carries Lincoln and Tractor Supply carries Hobart. I bought a Lincoln off craigslist that was almost brand new and really like it. I would go with Lincoln, Miller or Hobart but would no doubt set it up for a mig welding (with gas)
Tyler99TJ is offline
post #22 of 45 Old 03-28-2011, 11:40 AM
pcoplin
I've found the smaller units do better on .030 with gas wire. The thicker the wire, the more amps it takes.
pcoplin is offline
post #23 of 45 Old 03-28-2011, 11:45 AM
Sundowner
I've got a Miller 210 and I love it...it's more than I need, so I keep it dialed back pretty far, but I won't ever run out of welder capacity. I did a lot of research before I bought one, and decided that a simple MIG machine would do pretty much anything I really wanted to do.
My wife is actually better at welding than I am, and she wants a TIG machine. Gosh, it sucks to buy tools for hot women.
My suggestion: determine your realistic needs, check the fab threads, and read LOTS of reviews. Then get a machine from a reputable manufacturer that will handle 25% more than you think you'll be working with. Also, practice more than I do so your wife's work doesn't shame you.
Sundowner is offline
post #24 of 45 Old 03-28-2011, 11:50 AM
DallastheJeeper
Originally Posted by julietkilo View Post
180 amp will do pretty much all you need, i found a brand going out of business on ebay last year and bought a mig 180 amp built in italy and has all the same consumables as lincoln (easy to get parts) and craftsman makes the same unit and you can get parts through sears.
I bought the welder for 275, its a beast and a 220 unit. its called clarke 180en the craftsman is also 180en. I just checked they are on ebay for 280 still.
Do not get a Clarke they are out of business and will not be coming back.
Get a miller!!!
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|____________________/||__/----|
#5-06 Salvage Rebuild LJ
Metalcloak Bumper, Overline fenders and Corner guards.
3.5" Sus Lift
1'' Body lift and engine lift
#4-98 TJ Sahara RIP :(
#3-42 GPW Project. Currently on hold Sand blasted the body and it was held together by screen and bondo so new Tub needed
#2-88 Comanche Currently getting a frame off rebuild and a 4bt.
#1-1994 Power Wheels Wrangler
DallastheJeeper is offline
post #25 of 45 Old 03-28-2011, 11:57 AM
DallastheJeeper
You can also get a smaller welder and get a trimix gas that has oxygen. The oxygen raises the heat so you can do more with your smaller welder. My Fav welder is a millermatic 180. I was the first person in wisconsin to own one so i was pretty proud of myself. What I would look for in a welder is having infinite controls and having frequency that feels good to you. I have used a couple knock off brand welders and the frequency feels like crap. By frequency im talking about how fast and smooth the current alternates.
3.5" Sus Lift
post #26 of 45 Old 03-28-2011, 12:14 PM
Fropleyqk
Fropleyqk's Avatar
2014 JK Wrangler
Going by the chart that came with my HH, it says the thickest it can burn is with .35 flux. I cant remember all the science, its been a while since I read up on it, basically the flux burns hotter. I cant speak for 220v units though.
post #27 of 45 Old 03-28-2011, 12:28 PM
DallastheJeeper
If you are inside you are better of using a shielding gas.
Disadvantages of flux core: It can produce excessive, noxious smoke (making it difficult to see the weld pool); under some conditions it can produce welds with inferior mechanical properties; the slag is often difficult and time-consuming to remove.
3.5" Sus Lift
post #28 of 45 Old 03-28-2011, 12:31 PM
The_Blacksmith
1993 XJ Cherokee
i have a millermatic 180 and love it, for everything from roll cages down to sheetmetal, to 1/2 plate
Thanks Chris!
The_Blacksmith is offline
post #29 of 45 Old 03-28-2011, 12:40 PM
DallastheJeeper
X2. Its such a great welder. What are you using for gas? I has a tri mix of Argon, Helium and Oxygen.
3.5" Sus Lift
post #30 of 45 Old 03-28-2011, 12:51 PM
Fropleyqk
Fropleyqk's Avatar
2014 JK Wrangler
Yes it is. Completely agree on that one.
Please give me input here.. WTNFDXJ YJ Wrangler Technical Forum 10 12-08-2010 08:53 AM
OT: What kind of welder for Jeeps? GatorsUF YJ Wrangler Technical Forum 15 01-09-2010 11:09 AM
transfer/ tranny leak someone give me input becker21603 TJ Wrangler Technical Forum 7 06-23-2007 09:37 PM
is it ok to tack weld the muffler with J&B weld? losfreddy TJ Wrangler Technical Forum 9 04-02-2006 11:22 PM
Narrowed my engine problems down, can someone please give me some input Pkibugu TJ Wrangler Technical Forum 9 08-15-2003 01:31 PM
