What joints are you using for your homemade long arms? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > What joints are you using for your homemade long arms?
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 03-02-2011, 12:08 PM   #1
brett3xx
for those of you that have built your own longarms similiar to T&T, RCX, and claytons, what rubber bushings/sleeve are JJ did you go with? Ive looked at Johnny joints, Rustys flex ends, and balistics forged joints. Which joints do most of you run, what size, and where did you get them?
Also Im planning on using 2" DOM with 0.25" wall for the lowers, but what size should I use on the uppers?
Any help is appreciated! Thanks
brett3xx is offline   Reply With Quote
Unread 03-02-2011, 02:46 PM   #2
brett3xx
how would these work for the lower arm to axle link?
http://qualityairride.com/4-link-par...w-zerk-fitting
Unread 03-02-2011, 03:08 PM   #3
jpony645
Trail Gear Creeper Joints and Rusty's bushing rings with OEM rubber bushings on the other end.
jpony645 is offline   Reply With Quote
Unread 03-02-2011, 03:45 PM   #4
brett3xx
Thanks, I hadnt looked at trail gear yet, they seem to have great prices. Should I use a creeper joint or factory style bushing in the upper arm where it attaches to lower arm?
Unread 03-02-2011, 03:48 PM   #5
jpony645
Creeper Joint.
Check with Jim at Foothill Motorsports. I got mine from him and it was an excellent price.
http://www.pirate4x4.com/forum/showthread.php?t=681143
Unread 03-02-2011, 04:04 PM   #6
brett3xx
Thanks for the info, I just sent him a PM on Pirate. Are these the correct bushing rings at Rustys?
http://rustysoffroad.com/mm5/merchan...ry_Code=BP-CNC
Unread 03-02-2011, 07:22 PM   #7
26679cj5
What do you guys think of the joints that ruffstuff specialties makes? I was set on those til I checked out the creeper joints. I really want a grease fitting and didn't see that the ruff stuff were available with them.
26679cj5 is offline   Reply With Quote
Unread 03-02-2011, 07:36 PM   #8
brett3xx
from what Ive seen the creeper joints seem to have the best price.
Unread 03-08-2011, 06:53 PM   #9
motox168
ruff stuff cryo heims
motox168 is offline   Reply With Quote
Unread 03-09-2011, 08:33 AM   #10
jpony645
Yes, that's them. A stock OEM lower control arm bushing fits in that ring.
Unread 03-09-2011, 10:28 AM   #11
00JGC00
My buddy built some for his WJ:
http://www.jeepforum.com/forum/f197/...l#post10653946
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Other Money Pit: '00 Modded Pontiac Grand Prix GTP | Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline   Reply With Quote
Unread 03-09-2011, 12:01 PM   #12
jpony645
Not the best choice for a rig that's gonna see much street time. Heims transmit alot more vibration that a flex joint/bushing combo. They usually don't last as long either.
Unread 03-09-2011, 02:53 PM   #13
skullver
Tarpitz
1991 XJ Cherokee
Another Vote for the Ruffstuff heims. And they last plenty long!! Serious???
Blah blah blah blah.
my Jeepspeed build thread:
http://www.jeepforum.com/forum/f37/dez-racer-xj-build-367176/
skullver is offline   Reply With Quote
Unread 03-10-2011, 03:57 PM   #14
motox168
heims have not proven to be a a hars jount and last real long not a problem with them ever
Unread 03-10-2011, 04:26 PM   #15
shrubeck
Ummmm.... what?
That's what she said.
shrubeck is offline   Reply With Quote
