What do you think about this model HF bender? - JeepForum.com
post #1 of 13 Old 06-02-2010, 05:02 PM Thread Starter
jatepper
Looking to buy this bender for $40 from someone locally. Whatcha think? Basically, I plan on making the occasional stinger bumper, rock sliders, and eventually making my factory CJ cage in to a full cage. I understand this is HF stuff, and I generally stay away from ALL HF stuff, but for the price I think it is hard to go wrong. It will get very slight, occasional use. Thoughts???
12 Ton Hydraulic Pipe Bender
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #2 of 13 Old 06-02-2010, 05:05 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
if you want to bend PIPE, its fine. if you want to bend TUBE, it's the wrong tool. smart people build cages out of TUBE.
these are TUBE benders:
JD Squared, Inc.
Pipe Bending Machine, Tube Benders, Square Tubing Bender
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 13 Old 06-02-2010, 05:07 PM Thread Starter
jatepper
JD Squared, Inc.
Gotcha! Glad I didnt buy this yet! Thanks!
jatepper is offline
post #4 of 13 Old 06-02-2010, 06:02 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Yea, you would be swearing up a storm after the first bend leaves a nice kink in the tube.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 13 Old 06-02-2010, 06:35 PM
Ironworker709
Ironworker709's Avatar
JD Squared, Inc.
Fill us in on the difference between PIPE and TUBE besides the I.D. and O.D. measurements and why only "smart" people use TUBE
The only difference in being smart or not is buyin PIPE dies for PIPE,and buying TUBE dies for TUBE,,they are both made of the same process and material....
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #6 of 13 Old 06-02-2010, 06:41 PM
Unlimited04
So you're saying Schedule 40 is the same as Drawn Over Mandrel? I know you know better, but thats basically what you just stated.
Useful Write-Ups:
Funny:
post #7 of 13 Old 06-02-2010, 06:56 PM
Ironworker709
You never mentioned DOM tubing?
There is welded tubing out there that some people use on a budget too..and there is DOM PIPE used for high pressure pipe applications in mild steel,stainless and other material,i'm kind of like a Marine at times..IMPROVISE.. as long as the material is just as strong or stronger when it can be bought or had cheaper,or better yet..FREE ,when it's sitting in a scrap bin
To the OP..i have the HF pipe bender i use at times for just property gates i build for farmers and hunting property owners around here,yes it will kink the pipe unless using the old sand method which is time consuming and a PITA to do.
Never forget 9/11
post #8 of 13 Old 06-02-2010, 10:21 PM
chet44
I bent this with a HF pipe bender:
Of course, there were no 90's in this, but the pipe had minimal kinking. It worked for me, and I did not do the sand or water or oil packing. I think it depends on what you want to do with it. This worked for me.
Edit: I used sch40 pipe for this. We had it laying around work, so I figured, what the heck?
chet44 is online now
post #9 of 13 Old 06-02-2010, 11:00 PM
baldeagle1
use a hf bender for bumpers,sliders,and a stinger. just use sand and it doesn;t kink. would use a jd2 but just cant afford it.
baldeagle1 is offline
post #10 of 13 Old 06-03-2010, 07:07 PM
dwilliams35
It's meant for sch. 40 pipe: it's not meant for DOM: It doesn't kink pipe, with or without sand (at least not much)... it's fine for what you used it for, but when it comes to a life safety issue (cages) the stakes go way up...
dwilliams35 is offline
post #11 of 13 Old 06-03-2010, 07:56 PM
Kettles
not to mention none of the dies are the right size for tubing.
You can make a cage fine out of sch40 pipe, many people do. Many sanctioning race bodies allow it also. If you want to make bumpers sliders, tire carriers and all that it will work ok with pipe. If you want to bend it further or make race legal cages you want a better bender, either a plain rotary draw, or any mandrel bender. For casual cages and such out of pipe, it will probably work, just not be as pretty, or quite as strong.
If you want to bend tube, get a bender with tube dies, if you want to bend pipe get pipe dies. You can get fine results from a pressure bender with the right dies. The HF bender has cheap(er) dies and they will not be as good as others, and the stationary bars really need to be sized dies also for good results.
Just remember to get the right material for the bender, or visa versa.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #12 of 13 Old 06-03-2010, 08:14 PM
chet44
Yep, it is for pipe only. But if the OP can get one for $40, why not?
post #13 of 13 Old 06-04-2010, 01:43 AM
tangotag
You could use it for running pipe air lines in your garage too.
Years back I made some safari racks for XJs with black pipe they turned out highly functional.
There are safer but more expensive options for roll cages.
Pipe is not as strong as HREW tubing, DOM is even stronger.
Chromoly DOM 4130 is even stronger but has to be welded correctly and is the more expensive option.
I use the cheap pipe for non-load bearing applications in general fabrication around our shop.
The expensive DOM tubing is used for things that protect me when I roll at high speed.
Buying tube dies alone suck at generally $250 each.
tangotag is offline
Bender jeepsta Fabrication Shop 2 02-22-2010 09:33 PM
JD2 Model 3 Bender and stand build... ChiliPalmer Fabrication Shop 5 03-14-2009 11:35 PM
has anyone ever used this bender? 157061 Fabrication Shop 1 05-12-2008 12:17 AM
Bender?????? Stan99 Fabrication Shop 39 03-03-2008 11:33 AM
Where Can I Buy A Bender? bigsteve3184 General Jeep & Off-Road Equipment 16 02-16-2003 05:09 PM
