What is the average cost to build a rear bumper tire carrier? - JeepForum.com
post #1 of 11 Old 03-24-2008, 05:11 PM Thread Starter
rescue6
I am trying to decide if I should build a tire carrier/bumper or buy one. I have a welder and a drill press, chop saw and a grinder. I was just wondering what you guys aveage cost for materials was. I am looking to get a rear bumper with reciever and two clevis mounts and a swing out carrier with at least a cb mount and highlift mount.
I figure I will have to buy:
steel 2x4 and 2x2 3/16ths
2" flat stock 3/16ths - Already have
4" flat stock 3/16ths - Already have
hinge - $50
latch - $30
shackle mounts - $20
reciever hitch tube - $20
bumper mounts - $40 just easier to buy
So that is up to roughly $160 plus the Steel
Anything else?
In your opinion was it worth the build or should I just buy one?
rescue6 is offline
post #2 of 11 Old 03-24-2008, 05:26 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I think home brewed (done right) far beats the cost of a big name co. I am up to about $150 in cost for my planned bumper/carrier.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 11 Old 03-24-2008, 06:03 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I just cut/pasted off an old spreadsheet. This was done about a year ago.. my cost in steel has gone up almost 40% in the past 2 months!
TJ/YJ Basic Bumper
Item Material Qty Price Each
Bumper Blank 2"x4"x3/16" wall 58 $26.58
Bumper End 3/16"x2" flat 16.5 $1.97
Bumper Standoff 3"x3"x3/16" wall 4 $2.08
Bumper Mount Plate 1/2"x3" flat 18 $6.02
Bottom Bracket 3/16"x2" flat 12 $1.43
Chain Plate 1/4"X2.5" flat 8 $0.82
2" Receiver 1 $12.31
Clevis Mount 1 "x2 " flat 9 $4.20
7/16" Mounting Bolts $4.00
7/16" Locking Nuts $3.00
7/16" Washers $1.00
$63.42
Additional Items for Mounting Swingarm Material Qty
Item
Spindle 1 $12.00
Spindle Circle Plate 5 $1.46
Swingarm End Stop 2"x2"x.120" wall 2 $0.49
Swingarm Latch Hook
Swingarm Foot Base 3/16"x2" flat 3 $0.36
Swingarm
Item Material Qty
Swingarm Tube 2"x2"x.120" wall 42 $10.32
Upright Tube 2"x2"x.120" wall 18 $4.42
Diagonal Tube 2"x2"x.120" wall 48 $11.80
Short Swingarm Tube 2"x2"x.120" wall 5 $1.23
Latch End Mount Plate 3/8"x3" flat 4.5 $1.13
Spindle Tube 2.75"x.500" DOM 4.5 $10.63
Spindle Bearings/Seal $12.00
Spindle Cap 3"Diameter Aluminum 1 $2.36
Set Screw $0.40
Zerk $0.20
Spindle Stop Squares 1 "x2 " flat 1 $0.47
2" Receiver 1 $13.50
1/2" Bolt (anti rattle) 1 $0.50
Receiver Gusset 3/16"x2" flat 2 $0.24
Hi Lift Mount (angle) 2"x2"x 3/16" angle 8 $1.12
Hi Lift Mount Post 2"x2"x.120" wall 6 $1.47
Hi Lift Mount Bolts
Hi Lift Mount Gussets 3/16"x2" flat 4 $0.48
Tire Mount Tube 2"x2"x.120" wall 8 $1.97
Tire Mount Circle Plate 1/4"x7" flat 7 $2.04
Tire Mount Studs 3 $0.90
Lug Nuts 3 $0.90
5/8" Hitch Pin 1 $4.00
1/2" Hitch Pin 1 $3.00
Spring 1 $1.00
Roll Pin 1 $0.02
Swing Stop Tube 3/4" tube 4 $1.67
Latch 1 $40
Latch Bolts 4 $0.60
$142.67
Consumables
Welding Gas $5.00
Electricity $2.00
Welding Wire $5.00
Grinding Disk $5.00
Plasma Consumables $5.00
$22.00
TOTAL $228.09
BESRK is offline
post #4 of 11 Old 03-24-2008, 06:05 PM
JJs99TJ
Mine has about $200 in it and its like a tank, main bumper is 4x6 1/4".
When you go to buy steel if you have some local welding/machine/fab
shops, ask them if they have any scrap of what your looking for. Some
places will give it away, or sell it uber cheap. In the long run, sometimes
its not always cost efficient, but has been in my experience plus you have
the self satisfaction of saying you built it yourself versus buying (insert
name here)'s product.
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline
post #5 of 11 Old 03-24-2008, 06:43 PM Thread Starter
rescue6
Thanks guys I am trying to decide if I can afford to buy one now or just try to build it on the cheap.
rescue6 is offline
post #6 of 11 Old 03-24-2008, 09:25 PM
joe's_yj
joe's_yj's Avatar
paid 50 bucks for my rear bumper so far, no swing but bought plenty metal that i could make a swing if i needed to. Mad from 1/4 steel
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #7 of 11 Old 03-25-2008, 08:08 AM
Bigbob
Bigbob's Avatar
First one I build without a swing cost about $40-$50 including consumables. The one I am building now with a swing will run about $200 or so. If you figure in my labor at $7.00 an hour then it will cost about $23,456.00 more or less.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #8 of 11 Old 03-25-2008, 08:30 AM Thread Starter
rescue6
Thats what I am worried about is having enough time to do it with everything else I have going on right now.
rescue6 is offline
post #9 of 11 Old 03-25-2008, 05:12 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
My approx build times...
Basic Front Bumper w/Pair of Clevis Mounts... 1hr
Add a winch hoop... additional 15 minutes
Basic Rear Bumper w/Clevis Mounts and 2" Receiver... 1hr 45min
Basic Rear w/Tire Carrier.. 6-7 hours (if I hussle).
Keep in mind that I "mass produce" my brackets, clevis mounts and other pieces.
BESRK is offline
post #10 of 11 Old 04-04-2008, 05:37 PM
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
And your experience probably out weighs the occasional fabricator!
FunkSkunk is offline
post #11 of 11 Old 04-04-2008, 06:50 PM
76flh
i have been building one this week at work in my spare time. i am building it from the plans that besrk put in his write up. great work by the way. all the steel was free from the scrap bin in the metal shop.all i had to buy was the latching and spindle,and bearing kit.
76flh is offline
YJ rear bumper/tire carrier build in back yard Ironworker709 Fabrication Shop 31 03-03-2012 01:12 PM
Rear bumper / Spare tire carrier... Lunchbreak build! Kenbo-Slice Fabrication Shop 71 02-12-2010 07:23 PM
Parts to build tire carrier bumper? sjd78 Fabrication Shop 6 07-16-2007 06:24 PM
Rear Bumper/Tire Carrier Build Bikertrash Fabrication Shop 38 12-23-2006 06:06 PM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
