weldless diy safrai rack questions - Page 2 - JeepForum.com
post #16 of 24 Old 06-12-2013, 09:05 PM Thread Starter
cnacowboy
sounds like it how did you miter ur brackets???
cnacowboy is offline
post #17 of 24 Old 06-12-2013, 09:36 PM
Cherokee95kid
I made a little centering jig out of wood then clamped it to my drill press and every 4 inches drill down with a 1" hole saw
Cherokee95kid is offline
post #18 of 24 Old 06-13-2013, 09:17 PM Thread Starter
cnacowboy
I don't have that so I was thinking of making poster board template and messure and cut my holes, then cut my emt down the middle of the hole.
post #19 of 24 Old 06-13-2013, 10:54 PM
Cherokee95kid
It can be done with a hand drill and a hole saw just make a pilot hole all the way through your emt and make sure it is exactly strait then use your hole saw and drill again. It's just going to be a little tricky getting everything strait.
post #20 of 24 Old 06-13-2013, 11:39 PM
AtTheHelm
Mark a center line down the tube to use as reference to keep the notches lined up.
You can also notch with a grinder, bandsaw or even a sawzall.
AtTheHelm is offline
post #21 of 24 Old 06-14-2013, 05:44 PM Thread Starter
cnacowboy
ok ill be finishing up everything sunday and will post pics next week. what paint should I use?? I was thinking grill paint, or rustoieum
post #22 of 24 Old 06-14-2013, 08:14 PM
Cherokee95kid
Dooooooooo nooooooooot usssseeeee ggrillll paint that stuff sucks so bad. I used it cause it said high temp and it is and all but it turns white over time and it is dusty when you touch it and turns everything black. When it's time to paint mine I'm going to prime it with self etching primer then go at it with a few coats of the rusto premium protective enamel. It's good stuff and comes in a big can.
post #23 of 24 Old 06-14-2013, 09:27 PM Thread Starter
cnacowboy
thanks for the heads up ill use that paint. what size jig did you use to miter ur side poles
post #24 of 24 Old 06-14-2013, 10:38 PM
Cherokee95kid
It was just a board with two strips of wood parallel to each other so u can wedge the emt inbetween them and clamp it so it won't move.
